Mk6 RS2k Wheels over Cossie brakes ????
11 posts • Page 1 of 1
As title suggests
Std Mk6 15" RS2000 Alloys + 4x4 Cosworth Callipers - Will the they fit over ok?
Many thanks
Many thanks
Renault Sport Megane 250 Cup
Ford Fiesta XR2i 2.0 trackcar
- Project_XR2i_Trackcar
- Your car: Xr2i
Re: Mk6 RS2k Wheels over Cossie brakes ????
whats the ID of the wheels ?
- Ruishy1
Pass
Next question ??
Thought you lot would know
Next question ??
- Your car: Xr2i
I dont think they will. I had the earlier MK5 RS2000 wheels on mine with a cosworth brake set up. Fitted perfectly until I changed the pads on the cossie calipers. Couldn't get the wheels on after. You maybe able to if you run a spacer.
AndyKam
- AndyKam
- Your car: 1991 Red FRST
maybe have to grind a little off the caliper to get them to fit
- Ruishy1
I have 5mm spacers as i am using R888's
- Your car: Xr2i
use Fiesta st150 discs, then no need for spacers on the caliper carriers so the calipers sit further in.
- 0010
- Your car: BMW E30 318is
why not design your won brake kit, il help you mate, some 4 pots and discs
- Ruishy1
I dont need any more brakes really, i just happen to have a set of RS2k wheels which maybe spare but in need of a refurb and was wondering whether they would be of use.
- Your car: Xr2i
im sure with some tweaking you could get them to fit
- Ruishy1
10mm spacers but i wouldnt advise it unless you have spacers with spiggots.
- 0010
