modify 1.0, or 1.6s ???
5 posts • Page 1 of 1
Just wondering about a few things, firstly what is the best and easiest way to get more power from my 1.0 hcs??? and secondly how easy is it to fit a 1.6s engine and gear box in mine??? are the mountings the same etc??
- Nashy
Nashy,
Best way to get more power out of a 1.0 is to use it to get you down a scrappys and buy a bigger engine.
For the 1.6s conversion, I will soon have the XR2 engine and box knocking about, although it needs a rebuild to be honest.
Have a search through the forums, as there are about three of us who have converted from an HCS (1.0, 1.1 or 1.3) engine to a CVH (1.4 ort 1.6).
Although...
I honestly recommend you tidy it up and sell it for a profit, and buy yourself a basically sound 1.6S or 2i instead, as the amount of heartache and money you will spend in the end is far greater than buying a ready made one.
Sorry to be a misery but I've just put the 2i 8v 1600 engine in mine - my 5th engine in 12 months
Al
Although...
Al
- Project
- fiftyoneCL
As Al said, it does cost alot more to change an engine than to get the new car!!!
However, it does give u alot of mechanical experiance if you do change the engine yourself!!! - as well as pleasure to see all of your sceptical friends faces when it works after saying "it wont go in" or it'll never work" or "theres no way that u will be able to do that" bellieve me it's great!!!!! especially when i can point out that it's an escort engine!!! even though they are the same engine apart form the ignition system - they dont know that though
If you still want to do it read the post in the tuning section headed escort engine by beeman - has all of the details of how to do the 1.6 conversion there!
Hope this helps
James
Hope this helps
James
- xrsi
- XR(ustyAtTheMo)SI
dunno about you but I had more fun modifying the 1100 than any other engine yet, dosent matter if you screw up the ports just go down scrappie and get another.
i did a 1300, use flat top KA pistons, shape the ports a bit (i didnt do much dont know enough about it), front exhaust was a 1300cfi cat (nice and large) into a 2i 8v system - went well!!
