Mods needed to take big shot of NOS?
16 posts • Page 1 of 1
ive been thinking of what im gonna do to get more power out of my car.
zetec turbo is a very tempting option but [ERRR] about going 2.0 then addin a 75 shot of nos to give me the big power. [ERRR] wud need to be done to the engine to run that amount of nos safely and relibly? and how much wud it cost?
also [ERRR] effect does nos have on ur insurance?
- Sunil_FiestaRS_16V
Man, I'd never thought of trying to insure with NOS! Dunno what they think about that, considering that legally, you're supposed to have a sticker on your rear windscreen saying something to the effect of "I've got NOS" , and it's supposed to be disconnected while on public roads I've seen a few cars who've simply made a false floor hiding the bottle cunningly. Fairly cunning stunt IMO
AndyBlackFRST :You talking about a pregressive feed, or a big shot?
umm not sure i was just gonna get a Zex kit i have seen. it comes with everything u need including a controller ,3 jets and bottle.
you won tneed any mods except setting the NOS up, but remember it is costly to refill if ur gona be using it alot.
- chumkila
- Dirty Post Whore!
NOS, as with anything, increases your combustion (that's how you get power ya know).. Just like a turbo, there's a certain amount of boost you could get away with on standard compression before it starts detonating.. the same applies to NOS.. On a 1.6-1.8, i wouldn't want to run more than 50bhp worth of NOS (actually is around 30bhp).. anything more than that and you're likely to det.. and goodbye pistons and/or rods..
- saqmaster
- Your car: Focus ST
I thought NOS itself doesn't cause detting - it just damages the engine in the same way high boost with the correct fuelling would?
NOS is a very good idea for turbocharging because it cools the charge air temps.
- Project
- fiftyoneCL
Of course NOS can cause detonation. That's what can destroy your engine with Nitrous.
Lower your ACT is a bad thing? Ha ha ha. Nitrous is very, very beneficial to turbocharged cars, as long as you don't go silly.
- saqmaster
No, there was no editing, otherwise it would say at the bottom that he had edited it. Detonation doesn't necessarily bugger everything up, but you lose power. "Knocking" and "pinking" are both terms for detonation, which you heard as a series of "knocks" coming from the engine. Saying it's gonna blow your engine up is all a bit extreme methinks. Detonation's to do with the timing of the spark, so I think you might be falling into the large category of people that say "Yeah, if you use NOS your engine'll blow up man", but it doesn't have to be the case as far as I know. I'm not claiming to be an expert, but that's the impression I have anyway.
Actually, you're wrong.
You won't hear detonation. To really hear it, you need to use a set of "det cans".. Basically a stethoscope you bolt onto the block somewhere.. And no, detonation is not just caused by bad timing..
I'm not fitting into the category you claim, I know exactly how NOS works.. I said it was beneficial to turbocharged applications.. anyway, i'm not arguing.. maybe I misread what the other guy said..
- saqmaster
Why can some people just not have a civilized discussion about things? It always turns into a big argument when we're all just trying to get a solution! AFAIK, detonation is caused my the mixture igniting before TDC and burning in the chamber before the exhaust cycle
I am being civil
Anything that increases cylinder temperatures can cause det, but nitrous is pretty cool (pardon the pun) in that it does actually lower temperatures.. but my point above was to 'not go silly' because there's always a limit to when det will start..
- saqmaster
That's what I was wondering, because nitrous has a cooling effect I'd have thought premature ignition as a result of excessive heat would be out of the picture, but as I said, I'm no flippin expert! I wonder how many years it'll be till cars come with NOS fitted as standard/optional extra from the factory? BP stations with petrol, diesel, LPG and NOS mwahahahaaaaaa!
