mods........
6 posts • Page 1 of 1
mods........
were is best place for beige injectors and what should i be paying?? £200 ish???
also will my std fmic off my frst be ok?? it has a t3 hybrid on it and a 165 chip i want the 195 but have been told i need the biege injectors before hand fuel pressure regulator has also been upgraded is there anything else i should/need to do?? i want it reliable also
mods so far are....
1 full mongoose exhaust
2 t3 hybrid
3 piper x filter
4 baileys dv
5 uprated fpr
6 a piller with boost gauge (to keep an eye on things)!!!
mods so far are....
2 t3 hybrid
3 piper x filter
4 baileys dv
5 uprated fpr
listening for costly strange noises????
- RS GEZ
Aup mate
I currently own a mk 3 fiesta rs turbo on a j plate and it seems like im in the same position as ive got a 165bhp chip and am currently looking into the stage 2 chip, i believe that for the stage 2 you require
1) Remap of your ECU
2) An uprated fuel pump
3)Beige injectors (roughly £55 each x 4)
Ive had a quote for the stage 2 at around £400 am i being ripped off?[/u][/b]
- timmy turbo
Re: mods........
RS GEZ :1 full mongoose exhaust
2 t3 hybrid
3 piper x filter
4 baileys dv
5 uprated fpr
Get a standard fuel pressure regulator back on the car. The standard item is more than capable and is adjustable anyway and changing it for a so called performance item causes problems rather than curing any. You can't just up the fuel line pressure. Give the person who told you it was a good idea a damn swift slap to the chops.
If you're going to 195 it it is also strongly advised you change the fuel pump for a standard Escort Cossie item.
You can pick the up for around £50 second hand and they will go well over 200bhp and are the best type they look the same as the frst oneRS GEZ :ok cheers how much is cossie pump should i not geta walbro one?? any other mods needed??
- j7aoc
