Mondeo brakes
5 posts • Page 1 of 1
Mondeo brakes
hi, as i will be doing a 2.0 converion on my Si next yr, i was wondering if these would be any good, and all i will need to get is a pair of callipers,
http://cgi.ebay.co.uk/FORD-MONDEO-MK1-2 ... dZViewItem
:: blade ::
:: blade ::
- :: blade ::
i should of put, im wondering if they would actually fit the fiesta Si. if they do then i will get them.
:: blade ::
:: blade ::
- :: blade ::
If you want to go 'just' to 260mm .. take the MK5 RS2000 brakes
If you want to go bigger.. get the cossie 4x4 (or granada/scorpio cosworth, Mondeomk1/2 V6, Cougar V6) callipers..
these are ment for 278mm discs
*note .. not al Mondeo MK1/2 V6's have 278mm callipers
I've used mondeo/cougar discs (278mm) and spaced them out using a 4mm spacer between the hub and the disc to space out the disc itself..
15" is mandatory for this..
If you're using the cossie 4x4 discs .. you will have to space the calliper out.. with change that the calliper will hit the spokes of your wheel .
- Jur
