mondeo rear disk setup on mk3 fiesta
9 posts • Page 1 of 1
hi,
I have a full donor mondeo that im taking the engine out of so my question is will a mk2 mondeo rear disk set up go on my mk3 rs1800?
any mods needed
like handbrake cable?
fitting of disks etc?
thanks mark d
any mods needed
thanks mark d
- hpiv
Re: mondeo rear disk setup on mk3 fiesta
hmm cant see why not i guess? try it..
my mates managed to fit st150 fiesta rears on his, when he got told they wouldnt.
- happypaul
happypaul :hmm cant see why not i guess? try it..
whats involved in the conversion. are there any guides on here?
thanks mark d
- hpiv
hpiv :happypaul :hmm cant see why not i guess? try it..
thanks mark d
look for rs2000 rear conversion. look at the mondy brakes and see how things work, and figure it out.
- happypaul
Apparently rs2000 fit straight on, not sure about cables and such tho. I've got a rs2000 set up in my shed, i've just ran out arsed to fit em.
- Ratspeed
mondeos have independant rear wisbones on each side at least the st24 does so u might struggle with the brakes a mk1 would though
- HCS PIMP
What has the rear suspension set up got to do with the brakes?
- Ratspeed
the mounting pattern is different on the ones with independant rear wishbones as the bolt pattern differs well at least i think so
- HCS PIMP
HCS PIMP :the mounting pattern is different on the ones with independant rear wishbones as the bolt pattern differs well at least i think so
ummm, no
what brake do you have in the front mate ?
As tbh unless your running decent fronts, rears will not be needed right now
- Ruishy1
