monster 350mm 6 pot brakes
1 post • Page 1 of 1
ive got for sale a set of 350mm 6 pot brakes by compbrake
comes with
350mm x 32mm discs with alloy bells
6 pot brake calipers
pads with 9-10 mm left
brackets and bolts
these are massive brakes but very light weight
you will need 18" wheels but some 17" may fit
these were fitted to a mk6 escort so should bolt straight on to a fiesta
a couple of points to note
two of the bleed nipple ends have broken off but wont affect the bleeding as they are the lower nipples so dont get used.
you will need to make up a small adapter pipe to mate to your brake lines
im looking for £575 ovno collected
can be collected from ox183lx or cf37 3lb by prior arrangement
comes with
brackets and bolts
- big g1985
- Your car: mk2 xr2
