Moondust FRST
17 posts • Page 1 of 1
Moondust FRST
Here are some pics of my Fiesta RS Turbo. Some of you may remember it as it was on ebay at the end of last year. Pics from the ebay advert.
To be honest it looks better in the pics, and I should have probably walked away at the time as I knew I was in for some problems, but it was a decent price, silver, tax & mot’d, low owners and had tons of receipts etc. There is a bit of rust on the bodywork, but nothing too major. It also looks like it has all its original panels.
The main problem with the car was it was only running on 3 cylinders and was a bit smokey. Got the car back home & after a few days it started smoking quite bad. Got someone to look at it & the running problem was due to a lifter that had stuck & in turn worn the cam lobe down. A new cam & valve stem oil seals & the car was back running on 4 cylinders but still smoking, so Ive not really used it much since. I have been busy collecting a few parts to get it back standard’ish.
As soon as I got the car back home I was on ebay seeing what parts I could find. First purchase was a set of standard rear lights, and some amber indicator lenses, which was swapped over along with the door cards which had some aftermarket speakers fitted.
Engine Bay when bought.
Since then it’s just been a case of keeping an eye on ebay for other parts I wanted, and over the last few weeks here’s a few things ive bought.
I removed the dump valve (not working right) so as a temporary measure there’s gear knob in its place!!! I also put a standard intercooler back on along with a cambelt cover, and fitted the standard airbox & pipe, crankcase breather and ht lead holder.
Next job on the list was wheels but all the sets for sale seemed miles away, however yesterday managed to pick up a set locally. Not too bad condition, but could do with a bit of tidying.
Wheels now swapped over, so here is the car as it is at the moment.
Once funds allow I will be looking at getting some new hoses, and also getting the turbo swapped or rebuilt as there is some play in the shaft & probably the cause of the smoke.
Hoping to get the car tidied up and also get it out & about in the next few months.
- Nunnsy
Re: Moondust FRST
very nice that, remember seeing it on ebay! the bits and bobs that go wrong are inevitable, theres always something! keep on at it, the silver ones are worth keeping, if i could have justified it i'd be keeping mine, but the sensible head kicked in!
- Gmc
Re: Moondust FRST
Before you going down the car is smoking could be the turbo route have you ruled everything else out like the breathers etc. Was tempted to have a look at this just for the simple reason of the price but the travel was too much. Anyway good luck with sorting it fella
- rsturbonutter
- Your car: Fiesta RS turbo
Re: Moondust FRST
Gmc :very nice that, remember seeing it on ebay! the bits and bobs that go wrong are inevitable, theres always something! keep on at it, the silver ones are worth keeping, if i could have justified it i'd be keeping mine, but the sensible head kicked in!
Cheers. Shame yours needed quite a bit of welding, but hopefully someone may save it. Looks like you got a decent replacement
- Nunnsy
Re: Moondust FRST
rsturbonutter :Before you going down the car is smoking could be the turbo route have you ruled everything else out like the breathers etc. Was tempted to have a look at this just for the simple reason of the price but the travel was too much. Anyway good luck with sorting it fella
Initially I was hoping the valve stem oil seals would sort it out with the car been stood years but they made no difference. Was then hopeful it could have been something to do with the breathers but checked pipes etc & everything seems ok. There is a bit of play in turbo shaft, so just presumed that would be most likely cause. I'll double check everything before splashing out on a turbo though. Cheers for the advice
- Nunnsy
Re: Moondust FRST
remember this a while back
looks like youv'e done very well to set it straight, hope the smoking isnt anything deep such as the rings
good luck with the rest of it, its looking so much better!
dont know what the last owner was thinking having everything silver! (lights indicators)
Re: Moondust FRST
Thats nice that
- Fraggle
Re: Moondust FRST
Looks brilliant mate! when is it smokey? start up, normal running or under boost?
- Dave5300
Re: Moondust FRST
Dave5300 :Looks brilliant mate! when is it smokey? start up, normal running or under boost?
Car doesnt seem too bad when driving normally.
Most smoke on tickover or under acceleration
- Nunnsy
Re: Moondust FRST
nice mate, nice to see it going back to std, im not a massive fan of the std look but its deffo a winner over them lights and wheels it had
what colour is the smoke?
blue - engine (maybe cold side of turbo but your see loads of oil inside the intake pipes)
white - head gasket
whitey grey- turbo
black - over fueling
white - head gasket
whitey grey- turbo
Re: Moondust FRST
Glad to see my old airbox is being put to good use, car looks smart. always fancied a silver frst.
If you need any other random bits drop me a PM, have quite a few bits i no longer have a use for!
Aaron.
Aaron.
- nearly17
Re: Moondust FRST
jayrs :nice mate, nice to see it going back to std, im not a massive fan of the std look but its deffo a winner over them lights and wheels it had
white - head gasket
whitey grey- turbo
Its a thick white/whitey grey smoke. It had the head gasket done when the cam was changed so hopfully that should be ok. Took the turbo & manifold off today & there was oil in the downpipe
- Nunnsy
Re: Moondust FRST
nearly17 :Glad to see my old airbox is being put to good use, car looks smart. always fancied a silver frst.
Aaron.
Ok cheers mate
- Nunnsy
Re: Moondust FRST
Nunnsy :jayrs :nice mate, nice to see it going back to std, im not a massive fan of the std look but its deffo a winner over them lights and wheels it had
white - head gasket
whitey grey- turbo
Defo sounds like ya turbo mate, mine done the same thing, i love me T2 but they are a weak unit and costly.. Likeing the moter tho mate, good to see ya putting it right...
1600cc T2= 220bhp 222 lbs/ft
- Russ FRST
Re: Moondust FRST
white - head gasket
whitey grey- turbo
exhaust seal on the turbo has gone then mate, only way out is new turbo.
once a new ones is fitted, it may still product smoke for a little while while it burns off whats left in the exhaust, how much and how long depends on how bad the turbo was, so bear that in mind when you restart after replacment
Re: Moondust FRST
if the exhaust seal is away then it will look like this...
thats how mine went a few years ago, replaced the turbo and that was that! but boy was it smokey before!!
- Gmc
Re: Moondust FRST
Cheers to everyone for the advice.
Should hopefully get the turbo sorted in the next couple of weeks. Will just need get it taxed & then hopefully get out in it
- Nunnsy
