More Power Arrr Arrr Arrrr!!!!!!
9 posts • Page 1 of 1
I have now got a 165 superchip & actuator. Fezzie reckond i may need a better head gasket and i have also seen the i may need better spark plugs.They also need different settings! Is there anything else that needs sorted?
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
The standard head gasket is ok to about 15psi, but if it hasn't ever been changed, then it would be best to do it.
Spark plugs - Standard ford, or NGK, set to 0.7mm as apposed to the standard frst 1mm gap.
Mark
Mark
- MarkFRST
Carl,
Yeah, get the people to fit the chip and actuator, it should NOT take them long, watch out for labour costs.
Whats the mileage of your car ? and is it on the original head gasket ? original cam ?
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
cars done 67k - i dont know if the head gasket or cams have been replaced. the guy i bought the car off was obsessive though - hed replaced the rad,alloys,exhaust,steering wheel,gear knob,brakes,discs,pads & more all original ford RS parts. So it may have been done.
- 007
Dont guess about whats been done. Unless the previous owner tells you when and where it was done, then shows you a reciept, it might be true.
67k is pushing it for the original cam. I would recommend getting the head off, new head gasket, new cam and anything else needed for the head and then get it "chipped" and set-up.
"Reliability is most important"
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
