Muz's Escort RS Turbo TRACK CAR. Lancia Integrale bonnet on
Re: Muz's Escort RS Turbo. 3 INCH DOWNPIPE + Custom cages Rollca
Postby muz on Thu Mar 17, 2011 11:16 am
Cheers Chris.
Picked up the new intercooler core to check the size. Its almost as big as the GRS including endtanks :lol:
muz
Postby jonyb4 on Fri Mar 18, 2011 12:48 am
:Q
Postby muz on Fri Aug 24, 2012 9:30 am
Wow, things have moved on a little since I updated this!
Cars fully stitch welded
One times rollcage
Trimmed and painted
Fitted
Painted
Rad and intercooler made
Fitted
muz
Re: Muz's Escort RS Turbo. Loooooads of work done 24/08/12
Postby Smo on Fri Aug 24, 2012 10:14 am
Wow! Glad you've still got this :D
That cage looks great!
Smo
Postby - Danny Boy - on Fri Aug 24, 2012 10:58 am
Looking good! As said, the cage looks awesome! :D
- Danny Boy -
Your car: Fiesta Si 2.0
Postby MAD_Adamski on Fri Aug 24, 2012 11:56 pm
one day it might turn the wheels on its own :bonkers:
MAD_Adamski
Postby jonyb4 on Sat Aug 25, 2012 1:35 am
wow good to see its still being built!
Postby Excursion on Sat Aug 25, 2012 11:28 am
Excellent, Muz! As above I thought this may have stopped.
Postby muz on Sat Aug 25, 2012 11:11 pm
Nah, I may live 250 miles away from the car but I'm still finding time to do bits and bobs... :wink:
muz
Postby Dave G fsi on Sun Aug 26, 2012 8:03 pm
Excellent work mate, glad to see its still being built :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby mikeymikeyp on Sun Aug 26, 2012 9:30 pm
Welding looks good mate U using coilovers and how the fek did U get the cage in ;)
mikeymikeyp
Postby boeb on Sun Aug 26, 2012 10:47 pm
U done away with the sunroof mate ?
boeb
Postby muz on Fri Aug 31, 2012 8:33 pm
Cheers lads. :Q
mikeymikeyp :Welding looks good mate U using coilovers and how the fek did U get the cage in ;)
Yeah, Leda Group A coilovers. The cage I cut in half through the middle, put the one side in then the other, then welded it back together using internal sleeves. Was hard work, but worth it.
muz
Postby EUFez on Fri Aug 31, 2012 9:30 pm
Don't usually like these Escorts, nor the RS Turbo's etc. But this is brilliant. Cage looks awesome :Q
EUFez
Postby muz on Sat Sep 01, 2012 4:42 pm
Cheers, mate.
Had a few hours this morning so got the fuel lines, brake lines and wiring put in with the sable tie saddles. Just waiting now for some fittings, hose finishers, lift pump, fuel pump brackets, cable trunking and some braided hose so I can finish it all off and get the dash back in.
muz
Postby jayrs on Sat Sep 01, 2012 7:18 pm
looking really good muz :Q
Postby jonyb4 on Sun Sep 02, 2012 11:27 pm
some brilliant fabrication on that roll cage
Postby muz on Sat Sep 29, 2012 6:31 pm
Got the fuel system plumbed in and had a little tidy up.
muz
Postby Malin91 on Sat Sep 29, 2012 6:38 pm
Looks stunning :)
Will have to have a look through the full thread after my dinner ;)
"If In Doubt, Flat Out"
"Old Fords Dont Die, They Just Get Quicker"
Malin91
Your car: mk2 Mondeo & 1.6 Xr2i
Postby Malin91 on Sat Sep 29, 2012 9:42 pm
Well that was one way to kill time when xfactor was one, read the thread. This is bloody beautiful :) Where do you keep the keys at night :lol:
Malin91
Postby muz on Sat Oct 13, 2012 4:21 pm
Cheers, mate. :aviator:
Got the next fuel loom sorted with a built in relay. I still need to tidy the wires up but untill I know its wired in correctly they are just in loose.
Hopefully it will be ok wired in this way with the lift pump being piggy backed off the Bosch pump terminal. The relay and fuse are both 30 amp, all the wiring is brand new from the ECU back and the current draw on the tow combined is less than 30 amps.
Also squared the other sides wiring away
muz
Postby Maxwell on Sat Oct 13, 2012 7:16 pm
looking good murray you f**k bag xx
Maxwell
Your car: FRST - 2wd SAFF COS
Postby jonyb4 on Sat Oct 13, 2012 8:50 pm
oh yes!!
Postby Ratspeed on Sun Oct 14, 2012 5:30 pm
Awesome work, i completely forgot about this build! :lol:
Ratspeed
Postby Rs Adz on Thu Nov 01, 2012 6:11 pm
ive just read this from the start brilliant work very well put together and thought out carnt wait to see it done
Rs Adz
Your car: xr2i and mk1 fiesta
Postby xr2imetalhead on Thu Nov 01, 2012 7:44 pm
fantastic work dude coming together nicely :-)
xr2imetalhead
Postby Dave5300 on Tue Nov 13, 2012 8:44 pm
Love the work gone into this, epic :)
Dave5300
Postby muz on Sun Jan 06, 2013 2:52 pm
So my box of fusebox bits has arrived from Polevolt.
Loom trunking, cable braid, battery cable for the kill switch, relay holders, fuse boxes etc.
I've decided to go with a different set of fuseboxes. 12 fuses on the Bluesea item was slightly limiting and because of the built in negative bus (which I don't really need) was also quite bulky given I don't have much available space where I want it all mounted, where the radio, cig lighter and ashtray were. It also has front mounted connectors so the wiring would be visible from the front and have to pass through holes in the panel. Again, not good.
Here's the panel with the available space marked out.
And here is the Bluesea.
Relay boxes mounted with space for 12 relays. No space left for switches etc.
New 8 fuse boxes giving me 16 fuses and much more space left for switches for fuel pumps, fan override, battery kill switch and extinguisher pull.
I'm also going to cut the middle mounts off and glue the two boxes together so they will fit inside the space.
I've worked out which circuits and relays I need.
High Beam R
High Beam L
Low Beam R
Low Beam L
Sidelight R
Sidelight L
Hazards and Horn
Radiator Fan
Wiper motor and washer pump
Taillights and Dash lighting
Indicators and reversing light
Fuel Pump - From Cossie loom
Ecu - From Cossie loom
Alarm fuse 1
Alarm fuse 2
Gauges and Collins Monitor
- Central Locking (not sure if I'm keeping this but might do because of the alarm)
- Electric mirrors (not sure whether to keep them or not)
and relays
I've simplified the existing Escort system as it uses 5 lighting relays for a dim/dip function which is pointless so going over to a simple 2 relay system.
High Beam Relay
Low Beam Relay
Horn Relay
Ignition Relay 1 - Escort loom
Ignition/ECU Relay 2 - Cossie Loom
Fuel Pump Relay 1
Radiator Fan Relay
Wiper Relay
Alarm Relay 1
Alarm Relay 2
Alarm Relay 3
muz
Postby FRSJON on Sun Jan 06, 2013 5:39 pm
looks good mate :) one thing i wish i did when i started mine was make a new car loom..having nightmares connecting things to mine :x
FRSJON
Postby muz on Sat Jan 19, 2013 4:59 pm
Panel is finished and ready to be installed and linked to the car loom.
Edges were all filed flat and 600 wet sanded to finish. All boxes fitted as well as a battery kill switch and a fire extinguisher pull. There's still plenty of room under the fuses to fit the switches for the horn, fuel pumps and fan etc when they arrive from Polevolt.
And my Sparco seat rails arrived so I can fit my seats.
muz
Re: Muz's Escort RS Turbo. Fusebox dash panel finished.
Postby fiestarsturboblack on Sat Jan 19, 2013 6:01 pm
looks muz, b good to see more updates :)
fiestarsturboblack
Your car: fiesta rs turbo
Postby jonyb4 on Sat Jan 19, 2013 6:05 pm
dont understand why the relays needs to be there though, but looks very good
Postby Excursion on Sat Jan 19, 2013 6:56 pm
Looks great, Muz!
Postby Dave G fsi on Sat Jan 19, 2013 8:15 pm
Looking really good :Q
Dave G fsi
Postby FRSJON on Sat Jan 19, 2013 9:26 pm
nice one mate,something i wish id done :)
FRSJON
