Muz's Escort RS Turbo TRACK CAR. Lancia Integrale bonnet on
Re: Muz's Escort RS Turbo. 9 NOV. Back on all fours.
Great update, loads of decent bit's going into this project
Should handle like a dream with that set-up
- Brammer
- Your car: Sierra Cosworth
Really like this car, So many good parts going into it, it's going to be great.
I will have one, one day
- FiestaBen
- Your car: Vauxhall Astra Sport
Car: 1995 Vauxhall Astra
looking spot on mate
youve done alot of hard work
keep it up and will be back on the road in no time
- jonboisescort
Car: 1994 Ford Fiesta
I got my injector sandwhich plate throught he post so could get on with modifying it to accept EFI injectors.
The ports when I started. Much too small for the injectors.
Then I drilled the ports out in 3 stages to accept the nozzle, seal and body of the injector at different stages to end up with this.
Sweet.
I still need to make a mount to hold the fuel rail securely but I'm happy with my handy work.
Then I couldn't do much so I desided to paint my block and sump.
Turbo and manifold.
And then my rocker cover.
I've gone for matt black, with polished ford logo and red motorsport logo.
Then with all of these freshly painted parts lying around I couldn't help a dry fit
Sweet.
Turbo and manifold.
- muz
Re: Muz's Escort RS Turbo. 12 NOV. Custom Inlet + Painting
liking the rocker cover mate
that setup looks the nuts!
- bakewell001
Rocker cover does look good
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
hows things going now mate?? any closer not seen you in ages!? cossie's back off the road again more changes!
- MAD_Adamski
Loving that set-up mate
- Brammer
loving that sig chris
Looks the dogs conkers mate, can't wait to see it in the car ready to go!
Escort GTI Turbo
- LeePFRST
Car: 1990 Ford Fiesta RS Turbo
Cheers guys. Waiting for my fancy new head that modified to use a focus RS Zetec headgasket and my gearbox to come back from CTS and I can pop her in. Took the sump off and checked the pistons and they are Accrilite, after someone said they looked like standard skimmed jobs and I got worried.
Yeah haven`t seen you since Ford Fair? I also hate to admit you were right as well. No wonder my car was running hot racing, I mean, FOLLOWING you to Silverstone. The pistons in the CVH bottom end were hanging on for dear life. Theres pitting in the middles and corners missing out of every piston
Whats up with the EsCos then? You`ll have o pop up the barn and take a look.
I`m hoping to have it done by the New Year. Theres not much left to do.
adamski frst :hows things going now mate?? any closer not seen you in ages!? cossie's back off the road again more changes!
- muz
- muz
i assume you have braced the rear struts to take the extra load from the coilovers?
looks great though muz and once again cheers for the roof
Formally Andyswidefez
Yes, i have a fat RS! lol
BIASmotorsport
- AndysFatRS
Yes Andy. Looking for some suitable steel tube as I`m going to have a weld in rear brace across the turrets with some seam welding.
Have you got the roof on yet? Send us the link and I`ll take a gander.
- muz
yes mate its been on since the day it arrived
its on;
http://www.fordtorque.co.uk/viewtopic.p ... highlight=
(page 4)
or if you cant be bothered signing up;
http://i218.photobucket.com/albums/cc24 ... e004-1.jpg
one of the best bits i have ever bought
its on;
(page 4)
BIASmotorsport
- AndysFatRS
It was honestly the only part of the Fiesta I regretted selling.
Its by far the nicest peice of carbon fibre I`ve ever seen.
- muz
Cheers guys. Got my new head Yesterday. Its an MFI Stage 3 head. Perfect for me as the inlet I'm using is MFI based, so no need for an adaptor plate. Its got huge ports, Stainless oversized valves, and as it didnt come with a cam I've fitted it with my old Kent CVH34 and vernier. Not ideal but the cars costing way more than I budgeted so a new cam will have to wait
Cam doesn't seem to be in bad shape.
All built up.
Ports
Its also been modified so I can use a Zetec headgasket. Just so people can see what needs doing I've taken a few photos.
Here is the Zetec gasket on my old CVH head compared to the new modified head.
As you can see, the much beigger Zetec oil gallerys run off the end of the head.
And on this one, you can see just how much has been added to the head.
You can also see why the top oil gallerys need blocking off, as they go straight into the water gallerys.
My block though has 3 oilways blocked off, but not the last one, so I need to do it. Does anyone make brass bungs to do this?
Also when removing the sensor forn the back of the inlet it snapped off
Is this a Cosworth sensor or CVH turbo?
Also I've notced my FPR has had a hole drilled in it??? Any reason for this?
All built up.
Ports
- muz
Re: Muz's Escort RS Turbo. 23 NOV. NEW HEAD!
thats where the inlet vacume hose should go to adjust the fuel pressue either a BAS POWER (MAX POWER) Mod or where the pipe has snapped off unfortunatly at least the car still looks sexy
- HCS PIMP
looks like a cossie one becuase its blue.
the hole thats been drilled is only in the cap, under that cap is a allen drive grub screw for adjusting fuel pressure
HCS PIMP :thats where the inlet vacume hose should go to adjust the fuel pressue either a BAS POWER (MAX POWER) Mod or where the pipe has snapped off unfortunatly at least the car still looks sexy
The inlet vaccum outlet is still attached. Its the outlet on top, above the whole.
Jay your probably right. I couldn`t see any grub screw underneith hence why I asked. I`ll have a closer look tonight.
- muz
yeah pop the cap off mate, it will be a bit tight but will come off
- FRSJON
FRSJON :which strangely is now going on a 2.1 s2 and i have to paint the rocker cover satin black
An Imposter!!!
Yeah done the carbon myself. Its only stick on carbon sheet. Real cabon fibre with 3M backing. Needs lots more laquer and then I can polish it.
I'm really hoping to have the engine in the bay Sunday.
My inlet set up looks very DIY compared to that jamsport item
- muz
your inlet looks good mate... .. the only part supplied from jamsport is the alloy part i covered in carbon... the hassle i had to make it any where near good enough to used was unbelievable.. .. first off it was bowed ..
.the inlet was drilled for a s2 tb... .. and there are were no vacuum take off 's at all...
jamsport said it would bolt straight on a efi engine... ..the bloke who bought it new gave it to me for nothing..(cost £400 with charge pipe) cos there was no way it would fit... now he's BOUGHT it back...
- FRSJON
That looks some sort of shoddy
Mine is also drilled for a series 2 TB so I have to get it welded up. Also need to find some way of mounting the fuel rail.
All is well at CTS with the gearbox. Apparently it has a rare a close ratio gearset in it which the chap said would be usuful for them to have as they are hard to get hold of and did I want to swap it for a standard, more road friendly gearset free of charge....
...no thanks Top blokes at CTS though. Very helpful. They could have whipped it out without telling me and I'd never have known.
So will be interesting to see how this box performs. I'm told not to expect any speedscover 100MPH, but it'll get there plenty quick enough.
- muz
just quickly about the tb's... look how my one's mounted as the frst one wont sit on a flat surface...you might need to space it out like i have... nice one on the ratio's..hopefully some bloody quick 0-60 times...
- FRSJON
- muz
fcuk me, £160
I know. The mounts aint cheap
The new Ford bolts for the underside came to about £200
- muz
always cost loads for the little inane bits ecu is apartently 500 pound for a 2.0 mk1 argg anywho goo progress
- HCS PIMP
- muz
Re: Muz's Escort RS Turbo. 7 DEC Leather GONE! New Recaros...
were you not tempted with cossie leather?
Are your stickers still on your alloys ?
Cruisers dont die they just keep cruisin
- CrAzY kAyLL
- CrAzY kAyLL
