Muz's Escort RS Turbo TRACK CAR. Lancia Integrale bonnet on : Member's Gallery - Page 13 | Fiesta Forums
Re: Muz's Escort RS Turbo. 27/01 Rollcage,carbon bits,track prep
Postby jayrs on Thu Jan 27, 2011 3:06 pm
coming on nice mate.
that wire on the cam end, looks a bit out of place mate, could ot not be run next to a pipe or something?
Postby muz on Thu Jan 27, 2011 3:22 pm
I thought that myself, Jay, if I'm honest. I have a carbon cambelt cover on the way though so might clip it to the cover. :Q
muz
Postby MAD_Adamski on Thu Jan 27, 2011 4:45 pm
does it even drive now? :lol: serious drive the thing! and after getting all that work done you decide to weld a cage in and wreck the paint :P your a boy! im down hereford sunday getting a few bits sorted!
my gearbox and manifold land here tuesday so hopefully my car maybe on the road end of feb!
MAD_Adamski
Postby muz on Thu Jan 27, 2011 5:18 pm
:lol: The inside still needs painting. I was going to do the whole inside anyway after I replace the inner sills.
I haven't started it yet. Still need to make a downpipe and actuator bracket.
Bugger I don't think I'm in Hereford untill about 3-4PM on Sunday, but I might be passing Kinver if your about around 2-3?
be good to see the EsCos back on the road!
muz
Postby jonyb4 on Thu Jan 27, 2011 6:33 pm
looking good, id finish the mirrors in a gloss myself
Postby MAD_Adamski on Fri Jan 28, 2011 4:52 am
muz ::lol: The inside still needs painting. I was going to do the whole inside anyway after I replace the inner sills.
ill be out bro but if im there later ill call u!!
MAD_Adamski
Postby muz on Wed Feb 02, 2011 1:07 pm
Few more bits.
I've got a Collins Engine Monitor, and wanted it mounted properly in eye slight so I could keep an eye on things, so a quick chat to Twins and he sorted this for me.
Will look like this when fitted
He also re finished my twin gauge holder for free to match.
muz
Re: Muz's Escort RS Turbo. Collins Monitor and Custom Surround
Postby - Danny Boy - on Wed Feb 02, 2011 4:16 pm
Lovely stuff!! :D Ive always liked this car over other ERST's... dont know why. This just stands out and looks smart, where as others... dont lol
- Danny Boy -
Your car: Fiesta Si 2.0
Postby muz on Wed Feb 02, 2011 4:45 pm
- Danny Boy - :Lovely stuff!! :D Ive always liked this car over other ERST's... dont know why. This just stands out and looks smart, where as others... dont lol
I know. I think I've mentioned it before, but I don't actually like MK4 Escorts, even RS Turbos :lol: 99% of them I think look crap. Much prefer MK3's.
muz
Postby jonyb4 on Wed Feb 02, 2011 9:07 pm
muz :
i agree with both of the above, not too fussed of the mk4, but yours looks great
Postby muz on Thu Feb 03, 2011 10:47 pm
Only had a small amount of time on it tonight so went and fitted my Wideband Lambda kit. Still using an Innovate Motorsports LC-1. Spot the chip I put in the inner wing :tiff:
My wiring clips aren't big enough for the wiring on this so need to order some bigger ones to pin it back to the inner wing.
and this is where the fusebox is. I've got some 1.5mm carbon fibre sheet on its way so I can make a little box to surround it.
Now I know all the electrics work I need to fit the alarm and then I can tape it all up.
muz
Postby Dave G fsi on Thu Feb 03, 2011 10:55 pm
Not looked at this thread for a while mate, some really good progress been made, nice one :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby muz on Sun Feb 06, 2011 7:13 pm
Well did a few odd jobs mainly today. Started off my cleaning the floor pans, inner wings etc on the inside the car as it was bloody filthy. Then I moved on the the last little wiring jobs.
Bolted up the alternator and finished off the little wiring jobs.
Had to make this charming little braided wire to join the alternator and starter motor, braided of course.
This is the grounding point from the engine block (alternator bracket) to the chassis. I perposely left one of the ARB bolts 20mm too tall. It also acts as the radiator mount.
Then I moved on to mounting the radator (after painting it matt black), which wasn't as straight forward as you would imagine. I'm running a standard ERST radiator, but my intercooler is moutned very far forward with the fans on the front, meaning I had to butt the radiator right up to the intercooler.
I did this by cutting off the 'spike' on top of the rad which locates into the front panel so it would fit. I then got the dremel out and cut the origional plastic mount untill I had a hole which lines up to the grounding bolt I mentioned earlier and bolted the bottom down to this.
I then drilled a hole through the top af the radiator and bolted it through the front panel.
On the otherside I have left it like this for now with a bolt holding it in, but I will be welding a small peice in here to act like a guide to stop the rad moving, although it's very secure how it is.
You can also see on the above pic just how forward the rad has been moved. I need a hose joiner to extend the hose, which I'm actaully quite glad about as I can now cut out the turbo water cooling section which I dont need.
And finished
lastly, a carbon foot well panel from a WRC car. It was my brothers but he's no longer using it so I have 'aquired it'. It's amost a spot on fit. Just needs very slight trimming in the top right corner to fit the shape of the floor line.
It conveiniently has a little section on the side which will stop my kicking my wiring loom and fusebox!
muz
Re: Muz's Escort RS Turbo. 6 FEB more done and carbon floor pan
Postby Excursion on Sun Feb 06, 2011 7:49 pm
Looks made for the job!
Postby - Danny Boy - on Sun Feb 06, 2011 7:57 pm
Very nice :D
- Danny Boy -
Postby rsonblackwheels on Sun Feb 06, 2011 8:17 pm
gr8 progress dude
really like the carbon foot well panel
:aviator: :Q
rsonblackwheels
Postby Dave G fsi on Sun Feb 06, 2011 9:37 pm
Really good progress there mate :aviator:
Dave G fsi
Postby jonyb4 on Sun Feb 06, 2011 10:00 pm
looking good :)
Postby muz on Mon Feb 07, 2011 9:58 am
Cheers lads. Hopefully get abit more done Thursday. Will be ready to start up before long. :Q
muz
Postby jayrs on Mon Feb 07, 2011 2:31 pm
coming on nice since i last stopped in mate :Q
Postby muz on Fri Feb 11, 2011 12:05 pm
Got a new oil catch tank. Bit nice than the Bailey item that myself and about every Ford owner in the world has.
muz
Re: Muz's Escort RS Turbo. New AH Fabrications Catch tank.
Postby MAD_Adamski on Fri Feb 11, 2011 9:47 pm
that needs coating black ask lars he can get it done for you he just did my bits...
MAD_Adamski
Postby muz on Sat Feb 12, 2011 1:25 pm
MAD_Adamski :that needs coating black ask lars he can get it done for you he just did my bits...
It's already in Etch primer awaiting the matt black treatment :lol:
muz
Postby MAD_Adamski on Wed Feb 16, 2011 7:05 pm
good girl xxx
MAD_Adamski
Postby muz on Wed Feb 16, 2011 8:54 pm
MAD_Adamski :good girl xxx
xxx
Actually got round to mounting my fuel pressure regulator. The manifold means I can't have it directly on the fuel rail as it fouls the throttle body, so needs to be mounted remotely.
I mounted it by making up a small mount and welding it to the bias box. I also had to knock up some spacer tubes to mount the fuel adapter
I also did want to mount the fuel filter on the gearbox so it was out of the way, but I had some custom braided lines made up to fit exactly the old set up which meant nothing would fit were I wanted. I didn't want to have new lines made right now, so I have modified a fuel filter bracket and am mounting it on the inner wing.
My old set up also kept the accumulator, which means I would have to find a union to join the two lines to bypass this, and my fuel lines would also be far too long, looking very untidy. So I have decided to keep the accumulator, mounted on the bulkhead like so. Hopefully you can mount them horizontally rather than vertically?
Also sorted out my breather hosing so thats more discrete. Rather than running two separate hoses, they join together into a 'Y' splitter in the middle then this goes to the top out let on the Bailey. The other outlet is fed by a breather hose from the block.Breather will be mounted on the strut brace.
Now all I got to do is whip the fuel stuff off and paint it up nice.
muz
Postby rs-tom on Thu Feb 17, 2011 11:02 am
gorgeous :bonkers: :bonkers: :bonkers:
rs-tom
Postby muz on Thu Feb 17, 2011 11:52 am
I've remembered that Series Ones and RS1600i's have the accumulator mounted horizontally, under the car, next to the fuel tank, so mounting it there will give me no problems. I think it looks quite "Motorsport" sat there with its braided lines. :lol:
I'll see if I can put the parts in paint friday night and fit them on Sunday.
muz
Postby Turboboy67 on Sat Feb 19, 2011 12:32 am
Good work Murry, not long now until start up,
unless you decide to rip it all apart again before its done of course :P :lol:
Turboboy67
Your car: 911GT3 RS
Postby muz on Sat Feb 19, 2011 12:53 am
Carbonboy67 :Good work Murry, not long now until start up,
Not now, Shaun. This will be it! I promise. I haven't got it in me to do it over again. :lol:
Got bored tonight so decided to get in the shed and do some painting..... Matt black of course.
Header and oil catch tanks
Fuel accumulator and bracket
Bailey oil separator
Even the fuel filter wasn't safe :cry: painted this up along with the modified fuel filter bracket.
Also got the group A filter trumpet done.
All together now....
muz
Postby jonyb4 on Sat Feb 19, 2011 12:58 am
they look great, great choice of colour, great finish.......
...Great! :lol:
Re: Muz's Escort RS Turbo. More bits painted. 18feb
Postby muz on Sat Feb 19, 2011 1:10 am
:lol: I love matt black, it's erm....... great?
muz
Postby Dave G fsi on Sat Feb 19, 2011 1:24 am
All looking eally good mate :aviator:
Dave G fsi
Postby rs-tom on Sat Feb 19, 2011 10:48 am
u cant beat matt black nice work mate and nice car
rs-tom
Postby emblem on Sat Feb 19, 2011 10:51 am
Such a cool car, if mine was just a bit as good as this id be well happy. :D
Matt black is defo a win in my books, im going down the same route. :aviator:
Rs Turbo........Rebuild happening! SLOWLY
emblem
Your car: White 1990 Escort RST
Postby jonyb4 on Sun Feb 20, 2011 2:57 am
emblem :Such a cool car, if mine was just a bit as good as this id be well happy. :D
sure is nice, but i prefer satin black :Q
