Muz's Escort RS Turbo TRACK CAR. Lancia Integrale bonnet on : Member's Gallery - Page 14 | Fiesta Forums
Re: Muz's Escort RS Turbo. More bits painted. 18feb
Postby jonboisescort on Sun Feb 20, 2011 9:46 am
looks great mate
cant go wrong with matt black :Q :Q
jonboisescort
Car: 1994 Ford Fiesta
Postby muz on Mon Feb 21, 2011 10:33 pm
Fitted up the parts I've painted. Its coming together.
Still loads of bits to paint, dizzy, strut brace, eadlights etc and need to get it down AH Fabrications for a charge pipe to be made.
Will take it outside and wash the dust off the bay Wednesday.
muz
Re: Muz's Escort RS Turbo. New inner sills and rollcage mounts
Postby muz on Fri Feb 25, 2011 8:20 pm
Started today looking at my charge piping. I have just enough room to use the old set up. Just need to get some black silicon hoses to replace these.
It's not an ideal set up though with the bends so will be something to assess later.
I also have just, just enough room to use a group A filter.
I then looked at making up a return pipe for the turbo oil. I ended up using a Subaru impreza water hose, welded to a standard T3 return pipe base.
I've also been looking at the floor and the inner sills were looking a little tired. They didn't seem too bad, but rather than patch them I've decided to fully replace them.
Looing at the insides and the inner sills after I removed them I think it was the right choice. Thankfully the inner sills are still solid and only needed a wire brushing and 3 50p sizes Krust rust treatments. I then cold galvenised them before fitting the new sills over the top.
I could only do the one side as the other sill is on back order :(
I then looked at mounting the roll cage. I'm using a bolt in cage, but I have decided to weld it to the car. I remembered about 4 years ago I made some floor plates to put a cage in my Fiesta but never used them. They fitted perfectly and only needed the front section extended 10mm to meet the floor.
(I really should have cut out the crap repair patch that was done before I had the car but after grinding it back its solid and will be seam sealed anyway)
Other side
Also going to do the same with the fronts. Cut the feet off and sit them on little platforms
Pretty productive day...
muz
Postby Ratspeed on Fri Feb 25, 2011 8:59 pm
That mount for the cage looks bloody good :Q
Ratspeed
Postby muz on Fri Feb 25, 2011 9:11 pm
Cheers mate. It was a bit hit and miss with the welder as I don't weld that often and the car body panels seem very thin compared to the 4-5mm thick rollcage mount so was a bit of playing with the wire speed and amps so it penitrated the mount and was a good strong joint without blowing through the car. Got there though. :Q
muz
Postby muz on Wed Mar 02, 2011 7:24 pm
Got another one of the bigger jobs out of the way today. The downpipe. I made my own out of a Mongoose 3inch. The 3 inch bores looks alot bigger next to the old 2.5 inch
I had to competely cut it to peices and re angle everything.
Tacked in place.
All welded up. Conveininetly, the 3 inch bore slipped tightly over the flexi pipe and the 2.5 inch bore slipped nicely inside giving good seams to weld up.
All wrapped up.
Also got my new top hats for the fornt suspention from Gaz, so got these fitted.
And managed to get some more bits in paint.
Fitted my carbon cam belt cover, needed a little trimming, just needs laquer now.
And also done done my strut brace. Only, the chap at the fastners gave me the wrong length bolts!
muz
Re: Muz's Escort RS Turbo. HOMEMADE 3 INCH DOWNPIPE
Postby FRSJON on Wed Mar 02, 2011 8:16 pm
great work muz :Q
FRSJON
Postby Excursion on Wed Mar 02, 2011 8:35 pm
Very good work Muz, look how far you've come.
Postby Razer on Wed Mar 02, 2011 8:44 pm
Looks awsome :D
FORD = First On Racing Days
Razer
Your car: MK3 RS1800
Postby - Danny Boy - on Wed Mar 02, 2011 9:29 pm
Awesome stuff as usual, keep it up! :Q
- Danny Boy -
Your car: Fiesta Si 2.0
Postby muz on Wed Mar 02, 2011 11:25 pm
Excursion :Very good work Muz, look how far you've come.
Tell me about it, Mark. If you told me back in June 2008 when I bought the car that it would be the spec it is now, built by me, running an engine I'd assembled I'd have laughed. I love the downpipe. I'm so proud of that.
muz
Postby knuckles on Wed Mar 02, 2011 11:53 pm
Looking good under that bonnet !
What inlet is that ? ubber cool :)
bit of advise regarding the oil return hose. I used a water hose on my t3 when i first fitted it years back. The oil slowly degrades the rubber as it isnt made from a specific oil resistant rubber. Mine went all saggy and eventually split with a poke or two.
So i would get onto samco or roose to see how much a proper oil resistant hose.
Last thing you want is a split hose dumping all the oil from turbo on the floor :oooh:
knuckles
Your car: Fiesta Rs turbo
Postby Excursion on Wed Mar 02, 2011 11:53 pm
muz :
You're a good lad.
Postby muz on Thu Mar 03, 2011 12:17 am
knuckles :Looking good under that bonnet !
The manifold is an MFI XR3i manifold, modified to use EFI injectors. It was made by Christain Major who had the 170MPH 350BHP CVH.
Don't worry, it's proper oil hose. I've also learnt the hard way using Silicon hose offcut. :lol:
muz
Postby jonyb4 on Thu Mar 03, 2011 1:47 am
thats some bloody neat looking welding mate, great job doing the exhaust, takes some careful planning to pull that off, with only an inch of two room for error in that sump passage!
:Q
Postby muz on Thu Mar 03, 2011 10:55 am
jonyb4 :thats some bloody neat looking welding mate, great job doing the exhaust, takes some careful planning to pull that off, with only an inch of two room for error in that sump passage!
:Q
Quite. I had to build it on the car a section at a time, but wanted the peices as big as I could with the least welded joints I could manage. Last thing I want is it cracking. :lol: The weldings really coming on, but I don't mind taking my time with it as I really enjoy welding.
muz
Re: Muz's Escort RS Turbo. 3 INCH DOWNPIPE + Custom cages Rollca
Postby muz on Thu Mar 03, 2011 5:23 pm
Slight change of plan. Custom Cages climing frame rollcage. :Q
muz
Postby muz on Thu Mar 03, 2011 8:48 pm
Not much done, but a few little jobs. Boost hosing all finished and K&N filter on. The filter fits!.....just. Had to buy a massive hose for the turbo to air filter and cut it down to nearly nothing :cry: As this charge set up is temporary I didn't bother to buy new black hose, I wrapped it in SFS silicon tape. It did a real good job! Just need to put some more can gasket all the way round when the tops dried to cover the red and blue hose ends.
muz
Postby jayrs on Thu Mar 03, 2011 9:38 pm
coming on really well mate, your have it at ford fair yeah?
i wanna look round this beast :Q
Postby muz on Thu Mar 03, 2011 11:05 pm
jayrs :coming on really well mate, your have it at ford fair yeah?
It should be there mate. Just depends on if I'm on exercise or not :(. Start May 1st with no time off for 12 weeks!
muz
Postby jayrs on Thu Mar 03, 2011 11:16 pm
exercise??
you joined the forces?
Postby muz on Thu Mar 03, 2011 11:25 pm
Yes mate. I'm a Paratrooper May 1st onwards. :Q
muz
Postby jayrs on Thu Mar 03, 2011 11:29 pm
muz :Yes mate. I'm a Paratrooper May 1st onwards. :Q
bloody hell mate, well, hat off to you mate i would do pretty much anything, but thats one thing i couldnt do even if i wanted too, respect to ya fella
Postby jonyb4 on Fri Mar 04, 2011 12:46 am
good on ya mate, you have my respect and not just for your car and craftsmanship :P
Postby muz on Fri Mar 04, 2011 1:32 pm
Cheers guys. I must be mad leaving my job to do what I am, but then again, I've never been right. :lol:
muz
Postby - Danny Boy - on Fri Mar 04, 2011 1:51 pm
Looking good mate :)
- Danny Boy -
Postby jayrs on Fri Mar 04, 2011 7:52 pm
if your happy in ya work mate, thats all that matters fella
Postby Rhinopower on Fri Mar 04, 2011 8:30 pm
Silly question but i cant see a lambda boss on the downpipe :P
Rhinopower
Your car: Volvo FH330
Postby muz on Sat Mar 05, 2011 1:38 pm
Rhinopower :Silly question but i cant see a lambda boss on the downpipe :P
Ryan with his eagle eyes :P It hasn't arrived yet.
muz
Postby muz on Thu Mar 10, 2011 10:47 am
Just sorted the drivers seat out so at least I can drive it around for now.
I was using the Cosworth runners initially, but wasn't happy with the home made mounts, so sourced a set of MK4 Escort runners.
Old, heavy Cossie runners off.
RST items on
Fitting them in the car to position the seat, the original holes on the right of the picture sat the seat perfectly centered to the steering wheel without fouling the trim or gear stick, so these were re used. The RST runners are about 12mm narrower than the cossie holes didn't quite line up on the left
SO, I knocked this up.
Now, it fits perfectly.
While I was there I thought it would be a good idea to renew the steering column bush. :shock: :lol:
and just for Danny, I gave it a wash.
Badly needs polishing though. It's scratched all over :cry:
muz
Postby jonyb4 on Thu Mar 10, 2011 11:46 am
oh yea, im liking that
Postby - Danny Boy - on Thu Mar 10, 2011 4:19 pm
Beautiful mate. Progress is coming along nicely too :Q
- Danny Boy -
Postby AndyKam on Fri Mar 11, 2011 2:30 am
Lovely mate, love the engine bay :aviator:
AndyKam
AndyKam
Your car: 1991 Red FRST
Postby muz on Tue Mar 15, 2011 12:56 pm
Cheers guys.
Got a few more bits in paint last night ready to fit tomoz.
Driveshafts
Also lacquered the carbon fibre mirrors. They have had about 10 coats of lacquer now. Just have to leave them a few days to harden then flat and polish them.
Also spoken to the lads at AH Fabrications and having a bespoke intercooler and charge carrier set up comissioned for the car to work better with the inlet and exhaust manifold/turbo set up.
muz
Postby Brammer on Tue Mar 15, 2011 8:23 pm
Love looking at this project as it just getting better and better - keep up the good work :Q
Brammer
Your car: Sierra Cosworth
