Muz's Escort RS Turbo TRACK CAR. Lancia Integrale bonnet on
- muz
Re: Muz's Escort RS Turbo. 3 INCH DOWNPIPE + Custom cages Rollca
- muz
Re: Muz's Escort RS Turbo. Loooooads of work done 24/08/12
Wow! Glad you've still got this
That cage looks great!
- Smo
Looking good! As said, the cage looks awesome!
- - Danny Boy -
- Your car: Fiesta Si 2.0
one day it might turn the wheels on its own
- MAD_Adamski
wow good to see its still being built!
Excellent, Muz! As above I thought this may have stopped.
Nah, I may live 250 miles away from the car but I'm still finding time to do bits and bobs...
- muz
Excellent work mate, glad to see its still being built
- Dave G fsi
- Your car: Mk1 FRS and FRST
Welding looks good mate U using coilovers and how the fek did U get the cage in
- mikeymikeyp
U done away with the sunroof mate ?
- boeb
Cheers lads.
Yeah, Leda Group A coilovers. The cage I cut in half through the middle, put the one side in then the other, then welded it back together using internal sleeves. Was hard work, but worth it.
mikeymikeyp :Welding looks good mate U using coilovers and how the fek did U get the cage in
- muz
Don't usually like these Escorts, nor the RS Turbo's etc. But this is brilliant. Cage looks awesome
- EUFez
- muz
looking really good muz
some brilliant fabrication on that roll cage
- muz
Looks stunning
Will have to have a look through the full thread after my dinner
"If In Doubt, Flat Out"
"Old Fords Dont Die, They Just Get Quicker"
- Malin91
- Your car: mk2 Mondeo & 1.6 Xr2i
Well that was one way to kill time when xfactor was one, read the thread. This is bloody beautiful Where do you keep the keys at night
- Malin91
Cheers, mate.
Got the next fuel loom sorted with a built in relay. I still need to tidy the wires up but untill I know its wired in correctly they are just in loose.
Hopefully it will be ok wired in this way with the lift pump being piggy backed off the Bosch pump terminal. The relay and fuse are both 30 amp, all the wiring is brand new from the ECU back and the current draw on the tow combined is less than 30 amps.
Also squared the other sides wiring away
- muz
looking good murray you f**k bag xx
- Maxwell
- Your car: FRST - 2wd SAFF COS
oh yes!!
Awesome work, i completely forgot about this build!
- Ratspeed
ive just read this from the start brilliant work very well put together and thought out carnt wait to see it done
- Rs Adz
fantastic work dude coming together nicely
- xr2imetalhead
Love the work gone into this, epic
- Dave5300
So my box of fusebox bits has arrived from Polevolt.
Loom trunking, cable braid, battery cable for the kill switch, relay holders, fuse boxes etc.
I've decided to go with a different set of fuseboxes. 12 fuses on the Bluesea item was slightly limiting and because of the built in negative bus (which I don't really need) was also quite bulky given I don't have much available space where I want it all mounted, where the radio, cig lighter and ashtray were. It also has front mounted connectors so the wiring would be visible from the front and have to pass through holes in the panel. Again, not good.
Here's the panel with the available space marked out.
And here is the Bluesea.
Relay boxes mounted with space for 12 relays. No space left for switches etc.
New 8 fuse boxes giving me 16 fuses and much more space left for switches for fuel pumps, fan override, battery kill switch and extinguisher pull.
I'm also going to cut the middle mounts off and glue the two boxes together so they will fit inside the space.
I've worked out which circuits and relays I need.
High Beam R
High Beam L
Low Beam R
Low Beam L
Sidelight R
Sidelight L
Hazards and Horn
Radiator Fan
Wiper motor and washer pump
Taillights and Dash lighting
Indicators and reversing light
Fuel Pump - From Cossie loom
Ecu - From Cossie loom
Alarm fuse 1
Alarm fuse 2
Gauges and Collins Monitor
- Central Locking (not sure if I'm keeping this but might do because of the alarm)
- Electric mirrors (not sure whether to keep them or not)
and relays
I've simplified the existing Escort system as it uses 5 lighting relays for a dim/dip function which is pointless so going over to a simple 2 relay system.
High Beam Relay
Low Beam Relay
Horn Relay
Ignition Relay 1 - Escort loom
Ignition/ECU Relay 2 - Cossie Loom
Fuel Pump Relay 1
Radiator Fan Relay
Wiper Relay
Alarm Relay 1
Alarm Relay 2
Alarm Relay 3
High Beam R
High Beam L
Low Beam R
Low Beam L
Sidelight R
Sidelight L
Hazards and Horn
Radiator Fan
Alarm fuse 1
Alarm fuse 2
and relays
High Beam Relay
Low Beam Relay
Horn Relay
Fuel Pump Relay 1
Radiator Fan Relay
Wiper Relay
Alarm Relay 1
Alarm Relay 2
Alarm Relay 3
- muz
looks good mate one thing i wish i did when i started mine was make a new car loom..having nightmares connecting things to mine
- FRSJON
Panel is finished and ready to be installed and linked to the car loom.
Edges were all filed flat and 600 wet sanded to finish. All boxes fitted as well as a battery kill switch and a fire extinguisher pull. There's still plenty of room under the fuses to fit the switches for the horn, fuel pumps and fan etc when they arrive from Polevolt.
And my Sparco seat rails arrived so I can fit my seats.
- muz
Re: Muz's Escort RS Turbo. Fusebox dash panel finished.
looks muz, b good to see more updates
- fiestarsturboblack
- Your car: fiesta rs turbo
dont understand why the relays needs to be there though, but looks very good
Looks great, Muz!
Looking really good
- Dave G fsi
nice one mate,something i wish id done
- FRSJON
