MWSTEWART | 500+ BHP Project | 10/04/2024 : Member's Gallery - Page 35 | Fiesta Forums
Re: MWSTEWART | 500+ BHP Project | Rebuild 23/02
Postby AndyKam on Thu Feb 23, 2012 4:45 pm
This isnt a Ford Fiesta its an Excursion Fiesta :wink:
AndyKam
AndyKam
Your car: 1991 Red FRST
Postby rsturbonutter on Thu Feb 23, 2012 5:03 pm
AndyKam :This isnt a Ford Fiesta its an Excursion Fiesta :wink:
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
rsturbonutter
Your car: Fiesta RS turbo
Postby jayrs on Thu Feb 23, 2012 5:36 pm
nice, always wondered about a bonded screen on a mk3, but never something i looked into
Postby Dave G fsi on Thu Feb 23, 2012 9:08 pm
Excellent work mark, inspiring to say the least! :Q :Q :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby Smo on Thu Feb 23, 2012 9:25 pm
Amazing work, I love how perfect everything looks! The bonded screen looks so much more modern :)
My Popular Plus has the same sound deadening behind the dash - I assumed all MK3s and 3.5s did! I don't think it helps much on mine :lol:
Smo
Postby Max M4X WW on Thu Feb 23, 2012 10:39 pm
Smo :My Popular Plus has the same sound deadening behind the dash - I assumed all MK3s and 3.5s did! I don't think it helps much on mine :lol:
So does mine, presumed they were all the same!
Postby Excursion on Thu Feb 23, 2012 10:44 pm
Thanks guys :D 8)
Sound deadening is Mk5. Mk3.5 won't fit mine now :)
Postby andymac on Thu Feb 23, 2012 11:19 pm
Much more of this and you won't be able to fit your head in the car :lol:
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby jonyb4 on Fri Feb 24, 2012 1:56 am
im speechless mark!
amazing work :Q
Postby DanFraser on Fri Feb 24, 2012 9:36 am
andymac :Much more of this and you won't be able to fit your head in the car :lol:
Sound proofing or head size?
DanFraser
Your car: Ford Fiesta SI 1.6
Postby andymac on Fri Feb 24, 2012 2:00 pm
:wink:
andymac
Elite Pie Master
Elite Pie Master
Postby fuzzymonster on Sun Feb 26, 2012 5:57 am
Mark, re your headlight logic switch, since the mods you're making to the right hand wiper of the switch are to make it stay connected in all three positions, why not short it out? A wire link on the board between the solder joints at the top for C and E would hardwire 'dip beam trigger' to '+ve when on dip', so the dip element would always be live when the headlight switch on the end of the stalk was on, which is what your trace mod for that side (in pink) achieves. Correct me if I'm wrong.
I figured out the states of the standard switch.
...which enabled me to modify it to suit my needs.
fuzzymonster
Postby AW0L on Sun Feb 26, 2012 10:55 am
fuzzymonster :Mark, re your headlight logic switch, since the mods you're making to the right hand wiper of the switch are to make it stay connected in all three positions, why not short it out? A wire link on the board between the solder joints at the top for C and E would hardwire 'dip beam trigger' to '+ve when on dip', so the dip element would always be live when the headlight switch on the end of the stalk was on, which is what your trace mod for that side (in pink) achieves. Correct me if I'm wrong.
that would work, but it would be a link on D & E not C & E as you mentioned... but your idea would make for a better connection and would eliminate the worry of wear on the join ideas previously suggested...
AW0L
Postby andymac on Sun Feb 26, 2012 2:22 pm
Mentioned something like this a couple of pages back. :wink:
andymac
Elite Pie Master
Elite Pie Master
Postby fuzzymonster on Sun Mar 04, 2012 12:20 pm
lol AW0L, it is C and E I was talking about, D isn't connected to the solder joints, I meant a bridge between the two last blobs of solder on the bottom row, C/F and E (Contact points C, E and F would then all be connected). If you follow the traces, in its unmodded condition, D connects to a hole in the board :)
fuzzymonster
Postby Excursion on Sun Mar 04, 2012 12:31 pm
Thank you guys :D
Postby Michael! on Mon Mar 05, 2012 9:44 am
Should be awards for things like this
Mind=blown
ft-com-members-map-vt190192/
Michael!
Postby jonosi on Thu Mar 08, 2012 12:30 am
just been catching up on the progress and i must say fookin awesome stuff :D
love the colour now (same as mine :Q ) cant wait to see the finshed project
jonosi
Your car: Ford Focus 1.6 Ti-Vct
Car: 2005 Ford Focus
Postby AW0L on Fri Mar 09, 2012 7:14 pm
hey Marc, any updates to grace us with, we are all dying for more....
AW0L
Postby Excursion on Mon Mar 12, 2012 12:09 pm
AW0L :hey Marc, any updates to grace us with, we are all dying for more....
Thanks guys.
I don't have anything worthwhile to add at the moment as I don't want to make the post any more OTT than it already is in terms of detail :) I'm slowly working through the shell replacing every single last plastic clip and metal fastening, and the vibration damping material is being applied to all surfaces. I'm also wiring up auto lights and wipers from a Mk3 Mondeo.
I'll provide an update after the 23rd when I have the interior back from Aldridge.
Postby DanFraser on Mon Mar 12, 2012 4:59 pm
Excursion :
Thanks guys.
Please have detailed pics of the auto wipers and lights mod!
DanFraser
Postby jonyb4 on Tue Mar 13, 2012 2:52 am
be interesting to know, if its relatively easy it could catch on
Postby Excursion on Tue Mar 13, 2012 10:42 pm
Now that the vibration damping process is well under way the sound deadening work can start. I'm using 'Luxury Liner Pro' made by Second Skin, it is a Mass Loaded Vinyl product that comprises a layer of foam to absorb the various frequencies and a dense Vinyl layer to decouple the foam layer and reflect sound back through the various deadening materials. The egg carton type material in the background is a soft foam product which sticks behind trim to alleviate vibrations and trim rattles.
The rear quarter areas are now vibration damped and sound deadened.
O/S door vibration damped and sound deadened. Thanks to my Dad again for giving up a lot of his time to help with this stage.
Now the O/S sound work was finished I could build up the rest of the door. The lock barrel and central/deadlocking motor was first.
New door pins, check strap and door ajar switch fitted with a stainless screw.
New window motor/regular fitted.
I have these bags of closed cell foam made from recycled car parts, which are used to fill voids in the shell to further reduce noise and drone.
Some trim fastenings in the car make use of spire clips which slot into punched rectangular holes in the shell, and then the screw passes through a circular punched hole. The photos probably make more sense than my explanation! The fastenings aren't great as they mean only around 1mm of material is available for the screw to grip, and so to improve on this I have removed the spire clips altogether and fitted M5 Rivnuts in the circular hole.
I'm replacing the standard speaker cable with Van Damme Blue Studio Grade cable, and I've chosen Audison Sonus RCA interconnects. Both cables have a good reputation for high sound quality.
New Wiper arms and Wipers fitted. I'll swap to Bosch Aerotwin blades later on.
I've decided to get another rear bumper painted, this time one with parking sensor holes and a modified exhaust cut out area.I've cut the exhaust area from a scrap bumper which will be used to extend the length of mine so that I can fit a twin tail pipes that are similar in size to the S3 8P.
Re: MWSTEWART | 500+ BHP Project | Rebuild 13/03
Postby AndyKam on Tue Mar 13, 2012 10:55 pm
Amazing :)
AndyKam
AndyKam
Postby jonyb4 on Tue Mar 13, 2012 11:09 pm
very expensive stuff!
Postby Dave G fsi on Tue Mar 13, 2012 11:47 pm
Excellent progress, all looking very good :aviator:
Dave G fsi
Postby - Danny Boy - on Wed Mar 14, 2012 6:51 pm
Twin tailpipes will be different!
Looking good!
- Danny Boy -
Your car: Fiesta Si 2.0
Postby Excursion on Wed Mar 14, 2012 9:12 pm
Cheers guys :-)
Postby rsturbonutter on Wed Mar 14, 2012 11:36 pm
Have you thought about a rear diffuser or do you think it will look too modern. Either way awesome work fella
rsturbonutter
Postby Dave5300 on Thu Mar 15, 2012 8:33 pm
unbelievable :Q
Dave5300
Postby RS EDDIE on Thu Mar 15, 2012 11:17 pm
Bang on Marky boy!!!! The best fiesta ever imo!!!!! Absolutely stunning attention to detail and propper good work by yaself and old man!!!!
A credit to ya both!!!! :Q
RS EDDIE
Postby dijsil on Sat Mar 17, 2012 4:52 pm
Excursion :New window motor/regular fitted.
from where did you buy them?
dijsil
Postby russ-RST on Sat Mar 17, 2012 6:24 pm
Lovely work as always, I need to get me the tool to put them riv nuts in as those clips are a pain in a$$ and aren't very strong lol just thinking though with all this sound deadening it will ride and sound lovely but thee must be a fair extra bit of weight in there??
Either way loving the updates :Q keep em coming :)
russ-RST
Your car: fiesta rs turbo
Postby Excursion on Sat Mar 17, 2012 8:22 pm
Thanks Dave and Edd!
Have you though about a rear diffuser or do you think it will look too modern. Either way awesome work fella
Thanks mate! I'm trying to keep the exterior pretty standard but I have thought about one for the bumper recess , but it will depend on how the underbody airflow management works out. I need to have a play around once the Focus subframe is in :D
Window regulators and motors were from Ford. Left side is FINIS 1049971 £174.56, right side is 1049970 £174.56.
Lovely work as . always, I need to get me the tool to put them riv nuts in as those clips are a pain in a$$ and aren't very strong lol just thinking though with all this sound deadening it will ride and sound lovely but thee must be a fair extra bit of weight in there??
Cheers :) Weight gain is actually a very positive part of my build and something that will improve performance, which is I know contrary to popular belief! The Mk3 is in relative terms a very light car to begin but cricually it also lacks any significat aerodynamic downforce, so when the power starts to creep up much above 250, then traction and grip can really start to suffer and the original benefit of increasing the power can quickly become a negative. This is compounded if more weight is taken out! The larger engined Mk3's are also more unbalanced due to the heavier engines, and that extra nose weight is apparent when comparing a Zetec car to a HCS car. The extra weight in my car is low down in the shell which will increase tyre loading without adversely affecting the handling, and the extra at the rear will go towards addressing the imbalance. There will be a full corner weighting and geo session once I'm done :D My goal is to create a car that can sustain speed.
If you've got the time then this interview with the Nissan GTR designer is worth a watch, and explains why weight is so important for performance: very http://www.pistonheads.com/doc.asp?c=52&i=20819
Postby Max M4X WW on Sat Mar 17, 2012 8:27 pm
My car will be too light :( at the rear
