My 1.8 is soon to be a 2.0
3 posts • Page 1 of 1
My engine is being modified to a 2.0 by using the bottom end of a 2.0 mondeo engine. Is this all ok?! Do I need to get a different gear box, clutch etc? I don't know much about engines, but the boyfriend thinks its all going to be ok. Once its all in, I will then get it tuned.
- Kat
Just use the bare block, pistons, crank etc, and use the ancillaries off your 1.8 (oil pump, sump, flywheel etc) as the mondeo block is not a straight swap-oil pump comes out at the wrong angle, sump is different, water pump operates in the wrong direction!!..
- snake
- Trainee Burger Flipper
- Your car: ford
