My big ZT thread > 15.4.08 25bhp/20lbft extra and track prep : Member's Gallery - Page 15 | Fiesta Forums
Postby heeman10 on Sat Jul 09, 2005 6:56 pm
These updates and things are all pretty random now, as the mechanical conversion work is over, just finishing touches and mapping remaining really, so these will probably be the last pics I post in this conversion-dedicated thread.
A pic of the holes in the rear passenger sill :o
It was on roll-on ramps when he found "the hole", so I couldn't see exactly where he'd been prodding. When I put it up on the four-pad ramps (ie full access under the car) I saw all that lot! Nasty! The pic above was taken after I'd ground off the worst, ready for him to weld this on:
The plate fully-welded on, after an interesting 15 minutes of sitting up in the car while he welded it from below, setting fire to the sill and my soundproofing every 4 seconds!! :aaah:
A random photo of my interior as it is now. ACT gauge should be repaired and returned around Monday or Tuesday, hence the hole in the dash:
And a quick snap of my GPS. This page can be set to show all sorts of things, I've found the ones on there now to be the most useful whilst on the move and not wanting directions :D
This hasn't been turned on in the Fiesta yet, only the Metro :lol:
Postby Ben_frst on Sun Jul 10, 2005 1:29 am
heeman10 :Image
you just welded it up :aaah: :aaah:
Ben_frst
Postby JamieFRST on Sun Jul 10, 2005 1:15 pm
How much was the GPS thing? and where did you get it :-?
JamieFRST
Keep It Tidy
Keep It Tidy
Postby heeman10 on Sun Jul 10, 2005 4:58 pm
Ben_frst :
heeman10 :Image
As the pics show, it has a patch welded over the holes...
Jamie - Don't know matey, was a birthday present :)
Postby Captain Tightpants on Sun Jul 10, 2005 8:36 pm
Oooh how exciting!!
Not long now!!
Steve!
Captain Tightpants
Postby heeman10 on Sun Jul 10, 2005 9:11 pm
Indeed Steve!
This morning's work - replacing all the inlet gaskets. So, inlet manifold, fuel rail etc etc all off for about the 200th time, old gaskets off, new gaskets on, with checks for any leakages or possible sealing issue causes.
The photo below shows, from top to bottom:
Old head-inlet adaptor plate gasket (1.8 Zetec)
New head-inlet adapator plate gasket (1.8 Zetec)
Old inlet-inlet adaptor plate gasket (FRST)
New inlet-inlet adaptor plate gasket (FRST)
Old top manifold half-bottom manifold half gasket (FRST, 2 off)
New top manifold half-bottom manifold half gasket (FRST, 2 off)
The metal gasket at the top is a later replacement for the green one beneath it, and is much better IMO. The black lines are raised rubber, which compresses to form a good seal, far superior to the green gasket's feeble sealing lines. The ports are also of slightly more generous proportions, and so it matches up to the adaptor plate better as well :)
I couldn't see any leaking points on any of the mating faces or gaskets, so I think all was well. Better to be safe than sorry though. I'd hoped this might cure the erratic idle and stuttering with over about 20% throttle, but it didn't. It did idle beautifully for about 20 seconds, then settled back into hunting, which was frustrating. I don't know if it will be a sensor issue (suspect CTS, TPS or ISCV) or fuelling, but that'll have to be sorted by MSD.
Nothing else to do till mapping now I don't think, just count down the days!
Postby Captain Tightpants on Sun Jul 10, 2005 9:38 pm
Arse, I bought one of those top fibreglass gasket thingys the other day, and I didn't get a nice new style metal one!! :cry:
Steve
Captain Tightpants
Postby heeman10 on Sun Jul 10, 2005 9:42 pm
Maybe it takes longer for you to get updated gaskets down there...takes a while for a Transit to get from Spain to Somerset! I'm sure yours will still work :D I really want to know what's going on with the idle :x I thought it was all sorted when it sat level for 20 seconds or so, then it began its usual up/down game :rolleyes:
Postby andyhardy on Mon Jul 11, 2005 12:58 am
If it's a stuttering at low throttle I'm 99% certain it will be the TPS - it could however be fixed with mapping (my low revs had to be mapped differently due to the way the Cossie throttle body has been mounted at 90 degrees to it's 'normal' way), I doubt it's that with your car seeing as the throttle body is in it's 'standard' position?
Postby heeman10 on Mon Jul 11, 2005 10:09 am
It's not stuttering at low revs, no. If I press the throttle more than about 15-20% it doesn't want to accelerate. I've never tried it for more than about half a second, maybe one second tops. The main problem is the idle, as I'd say that's more likely to be a sensor issue than a mapping issue, but I can't be sure. I think I'll get a price from Ford for new TPS, IAT and CPS. Could do with a new ISCV too, just to be sure, but they no doubt cost a fortune and I like my shiny one!
Postby jammy86 on Mon Aug 01, 2005 9:34 pm
Very nice indeed, Well done :)
JAmes
jammy86
Your car: KaRST
Postby MotorcyclesFish on Mon Aug 01, 2005 9:46 pm
heeman10 :It's not stuttering at low revs, no. If I press the throttle more than about 15-20% it doesn't want to accelerate. I've never tried it for more than about half a second, maybe one second tops. The main problem is the idle, as I'd say that's more likely to be a sensor issue than a mapping issue, but I can't be sure. I think I'll get a price from Ford for new TPS, IAT and CPS. Could do with a new ISCV too, just to be sure, but they no doubt cost a fortune and I like my shiny one!
Have you checked PCV, brake servo and dizzy advance hoses from the manifold to make sure they're done up tight and not perished etc.? If the brake servo's knackered it could leak back into the manifold, leaning the mixture out until it stutters.
Pull a plug and show us what colour it is, that'll be a start. :)
MotorcyclesFish
Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
Postby heeman10 on Mon Aug 01, 2005 10:24 pm
You serious Grant? It was mapped and back in my hands ages ago! Runs like a dream and doesn't do anything wrong now, other than spin its wheels when I want to go faster! :lol:
jammy - Fanx :D
Postby Poom on Wed Dec 14, 2005 4:49 am
Just sat and read all of this! It is sexual! It really is!
ps. Where do yuo get all your money? :lol:
Poom
Postby mdjxr2i on Thu Dec 15, 2005 12:51 am
i was wondering that.....bank of mum and dad! no student loan can cover this!
ImageEDIROL USB AUDIO INTERFACE FOR SALE
mdjxr2i
Postby Xr_Dub on Thu Dec 15, 2005 12:59 am
james how many miles did u cover before u got ure car mapped mate?
Postby heeman10 on Thu Dec 15, 2005 1:58 pm
Poom - It was an emotional trip I can tell you! :D
Atif - I drove no more than 50 miles before driving the 50 miles down to MSD. I had a MAP sensor failure so I couldn't use more than 2psi without it stuttering anyway.
And for the nosey/rude buggers asking, my parents haven't given me any money since I was 18 at school! Go poke your noses in someone else's business :p
Postby NeoMagic on Thu Dec 15, 2005 2:37 pm
No leccy windows :o
NeoMagic
Postby heeman10 on Thu Dec 15, 2005 3:15 pm
Nope, not something I'm bothered about :)
Postby Andi on Fri Dec 16, 2005 2:33 am
Poom :Just sat and read all of this! It is sexual! It really is!
Look how upset he gets when asked...
*cough*rent boy*cough*
Andi
Postby heeman10 on Fri Dec 16, 2005 1:10 pm
Well I prefer not to ask you where you get your money because I don't enjoy learning the intimate ins and outs of the life of a professional fiddy kiddler Andi!
Postby jayrs on Thu Dec 29, 2005 1:25 am
great post mate, just spent las 2 hours going over it whilst doing over things.
great job mate, gives me some deatils to watch for when i do my ZT in the new year.
well, some probs ive seen might be putting me off, lol
Postby MAD_Adamski on Thu Dec 29, 2005 1:39 am
still a shed :P
MAD_Adamski
Postby heeman10 on Thu Dec 29, 2005 1:50 am
Cheers Jay! It's definitely an "Oh, I can do that" or an "Argh! No chance" thread :lol: Hope it was useful then! :D
Ad - Least mine keeps water out :p
Postby javablu on Thu Dec 29, 2005 1:55 am
http://www.funny-games.biz/pictures/car ... ed-van.jpg
need some of them wings to keep it on the ground no doubt. :D
javablu
Postby jayrs on Thu Dec 29, 2005 1:55 am
yes mate, if ya wanna take the time to put a list ( not 15 pages lol) together of all the probs im gunn find then please do so.
you have done things that i wouldnt though mate.
didnt know the engine had to be lowered though :oooh:
Postby MAD_Adamski on Thu Dec 29, 2005 1:58 am
heeman10 :Ad - Least mine keeps water out :p
hey mine does but has tape over it :lol: :rolleyes:
glad you got some done tho mate :) , i'm still waiting on my hoses :rolleyes:
MAD_Adamski
Postby heeman10 on Thu Dec 29, 2005 1:58 am
javablu - It wouldn't even fit under the bridge on the 0-60 strip at Silverstone with that lot on!! :lol:
Jay - Some things you wouldn't do? Do tell :) I think this thread is enough of a list probably :lol: My charge carrier had already been modified by Ian Howell to sit low down on the Zetec cam cover, so in theory it shouuuuuld've been ok, but I lowered it the extra 10mm to be on the safe side. After the mission I had finding a good FRST bonnet I didn't want to dent it!!!
Postby heeman10 on Thu Dec 29, 2005 1:59 am
adamski frst :glad you got some done tho mate :) , i'm still waiting on my hoses :rolleyes:
Got some what done? :lol: What you on about? Bloody hoses :x
Postby MAD_Adamski on Thu Dec 29, 2005 2:04 am
got some bits done on your car you homo!!!! i never have time :lol: popped home all i got was fed and told to visit people!!!!
MAD_Adamski
Postby heeman10 on Thu Dec 29, 2005 2:06 am
This thread only got bumped because people have been reading it recently, I haven't added anything to it since about August 10th! :p Get your hoses and get it finished, this is taking the wee.
Postby jayrs on Thu Dec 29, 2005 2:10 am
ah mate without going through 15 pages again can say much, lol
the down pipe from turbo i would do different, love the front cooler, but TBH, most of the "i wouldnt do's" would be cost related, i love the intercooler, but would prob stick with the pace i got.
but really, untill i do it i cant really say, but then i dont have to do as much work as youve done as my cars already a FRST so thinkgs like loom etc are already there.
plus im running the 195 chip set up with bieges etc
the thing thats making me think shall i or not is the set up cost, live map aint cheap, and i would have to come from isle of wight to somewhere to have it done, traving would cost me £100 plus on top.
only really got a bout 3K to spend on car and its being resprayed and got to get some leather to do the inside up.
might stick with the cvh and rebuild that, cant make my mind up, lol
Postby heeman10 on Thu Dec 29, 2005 2:22 am
£3k would have been nowhere enough to do mine, but as you say, some things are already done. You say the travel costs would be £100+. Top and bottom boost hoses plus a TPS comes to £115 odd. Dump valve = £110. If you can remove any of that stuff from the equation by having it already or sourcing it cheaply, you'll make up the travel costs!
Postby jayrs on Thu Dec 29, 2005 2:25 am
very tru mate, i got all sort of stuff on mine, samcos, injectors, fuel pump etc, juts engine building and setting up that will cost, but the engine from scrappy is only £50 so maybe mate, still looking through guide like yours etc trying to get as much info as poss to make my mind up.
Postby heeman10 on Thu Dec 29, 2005 7:03 pm
Cool. There's a big ZT guide on the front page apparently, about to go and check it out myself now :)
