My big ZT thread > 15.4.08 25bhp/20lbft extra and track prep : Member's Gallery - Page 4 | Fiesta Forums
Postby heeman10 on Thu Feb 24, 2005 7:20 pm
Had a crack at polishing the fuel rail today, but ran out of time. The finish will be a bit better than this in the end, and I'll attempt the fuel pressure regulator and some other bits tomorrow, time permitting!
Before:
After:
Like I say, there's more to be done yet, but it looks pretty good I think :)
Postby RS_Rawli on Thu Feb 24, 2005 7:47 pm
bufty
:P
RS_Rawli
Postby MotorcyclesFish on Thu Feb 24, 2005 8:24 pm
You'd think he'd get the baxtered thing running first, wouldn't you? :rolleyes:
:lol: :lol: :lol:
MotorcyclesFish
Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
Postby heeman10 on Thu Feb 24, 2005 8:34 pm
Oi! :p I'm just trying to keep things moving forward while I can't work on the car itself!
Postby StreetDragster on Thu Feb 24, 2005 8:43 pm
Blinging!
StreetDragster
Postby disc on Thu Feb 24, 2005 11:34 pm
Hey guys, why don't you use some high flow side feed injectors from Nissan or Subaru? They are direct replacement in Zetec fuel rail and are pretty high flow - 370cc! Is your injectors (803 or whatever injectors used to match FRST ECU) are high impedance or low impedance? I just got Nissan 200SX injectors and fuel rail off Ebay for 32 quids for my ZT project! I hope there will be no problems with injectors, cause i'll use Megasquirt ECU - Megasquirt support either low and high impedance injectors....
Some pics:
Injector close up and regulator
Subaru side feed injector
Nissan SR20DET side feed injectors and rail 370cc 11 ohm
Nissan side feed boss detail
Sorry for my bad english...
disc
Your car: 1991 Orion ZetecTurbo 270BHP
Postby andyhardy on Fri Feb 25, 2005 3:37 am
Interesting stuff with the injectors - is there a reason why these aren't used then ZT guys?
Postby Andy.B on Fri Feb 25, 2005 4:23 am
They are in my ZT fuel rail :wink: you just need the right people to to tell you what to get..... :D
Andy.B
Postby StreetDragster on Fri Feb 25, 2005 11:07 am
They are in my ZT fuel rail you just need the right people to to tell you what to get.....
Yep!!! If i had know about these earlyer i wouldn't have gone through all the bollox's to get the end feed ones in!!
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Matt
P.S Cheers for the top info Disc! FRST management uses high impedance 16Ohm saturated injectors :)
StreetDragster
Postby mrviper on Fri Feb 25, 2005 7:55 pm
ahh f00k me where can i aquire some of thease ;)
now i can junk my home brew bodge job rail ;)
mrviper
Postby heeman10 on Fri Feb 25, 2005 9:40 pm
I'm fine with my current injectors and the FRST fuel rail for now thanks, but Stage 2 with this engine may well incorporate a different inlet configuration along with other hardware so I'll bear that in mind :)
Today's update:
Discs for the Wilwoods and my new ARB bushes turned up today
Egg used for scale purposes only :oooh:
Postby disc on Fri Feb 25, 2005 9:43 pm
disc
Postby disc on Fri Feb 25, 2005 9:48 pm
StreetDragster :
Matt
Andy.B: Do you have any pistures? Are this injectors are low or high impedance, cause I'm waiting delivery... According to internet they are 11 Ohm, but ... ?!?
disc
Postby Andy.B on Sat Feb 26, 2005 2:39 am
Cant say i do at the moment but i can say you wont be getting another set like mine as there is only 10 of these injectors in the UK and my house mate has the other 4 so there are two left as spares.
They are 16 ohm and directly compatible with EEC IV. The ones that you are using may not work with EEC IV as they are 11 ohm so it depends if the ECU will fire them.
Will get pix as soon as i finnish my TDI project. :D
Andy.B
Postby heeman10 on Sun Feb 27, 2005 6:32 pm
Andy - Not all injectors have to be found from the UK :p ;)
Postby heeman10 on Wed Mar 02, 2005 9:38 pm
I had another nip down to the workshop today to finish my fuel rail and try the pressure regulator and compressor housing. I didn't have high hopes for the compressor housing, but it's come ok. None look as good as they will once I've got home and gone over them with Autosol. The compressor housing won't buff up to a mirror finish, but still looks better than before.
Postby heeman10 on Fri Mar 04, 2005 7:31 pm
I'm now getting the hang of polishing a bit more. Got five hours' done this morning and early afternoon. Compressor housing is now finished, along with actuator and actuator bracket. Still working on the inlet manifold and charge carrier. Results:
I'm really happy with them :)
Also, my charge carrier was previously modified by Excursion to fit his conversion, as he was using power steering. This meant the pipes travelling over the cam cover got in the way of the hose going from the top of the charge carrier to the throttle body/ISCV. Excursion had the original take-off blocked off, and moved it to the bottom of the charge carrier, meaning this big long black hose travelled the long way round to the throttle body. I don't have PAS, and wanted to tidy it up, so I sawed off the modified take-off, drilled a hole ready to accept the original take-off position and shot blasted both areas ready to welding.
At 1pm I came back for lunch, only to find the Metro not looking too great:
Thanks chives :)
Went to a Mini specialist with a mate and picked up a rear screen, will have to fit it tomorrow. Patched up with brown tape for now:
My new pump turned up today. Included in the pic are my new drop links:
Postby musicdrummer42 on Fri Mar 04, 2005 7:37 pm
how the hell do you get them looking so SHINEY :aviator: ?
i've tried polishing up my strut tops, but no matter how hard i polish it only comes out with a dull shine :-?
VERY NICE project there too, keep up the good work :D
pete
musicdrummer42
Postby Max M4X WW on Fri Mar 04, 2005 8:00 pm
Sweet, You really should stop polishing everything though :lol:
Postby heeman10 on Fri Mar 04, 2005 8:11 pm
musicdrummer42 - Cheers :) I'm using a polishing machine like the pro's, not just a rag and polish, which I fear may be the difference between our methods!! :lol:
Max - No :p
Postby Andy.B on Sat Mar 05, 2005 6:34 am
heeman10 :Andy - Not all injectors have to be found from the UK :p ;)
I never said they did all i said was my set came from a person in the UK. The injectors them selfs are very well traveled :wink: :wink: :P
Anyway nice polishing :D :D
Andy.B
Postby heeman10 on Thu Mar 17, 2005 3:51 pm
Not many updates coming in at the moment, but I go home early next week, so can begin the loom swap, from the standard diesel to XR2i loom, which will be a bit of a job! Radtec hope to have finished my second intercooler by the end of the week, and the radiator hopefully won't be too far behind it. I've asked for a radiator 70mm longer than standard - not huge, but it's another 15% of cooling area on top of the standard one :)
Updates:
As I've said, the take-off on the charge carrier needed moving back from its modified position (to fit Zetec cam cover with PAS pipes) to the standard position. This way I eliminate the need for a big long hose going up to the throttle body, and can use the standard Ford hose (or silicon equivalent).
As it was, with the take-off at the bottom:
Take-off pipe removed and re-positioned in newly-drilled and filed-down hole, clamped in position ready for welding:
And as it is now. Not very tidy, but that can be sorted at a later date:
Modified hole welded up:
Postby dannyboy on Thu Mar 17, 2005 7:22 pm
Coming along well James, I did the loom swap on mine last weekend and it was alot easier than I thought, I was dredding it for ages :lol: It only took me 3 1/2 hours to take out all the interior , strip out the old alarm, label the new loom up and swap it over. The interior loom divides into two parts so you should only have to take out half.
dannyboy
Postby heeman10 on Thu Mar 17, 2005 10:32 pm
That sounds great! Cheers for that Danny, bit of a spirit lifter there :D So does the loom split into things like fuel pump, central locking, windows etc...and leave all the stuff the bolts into the chassis with earths etc? 3 1/2 hours sounds very nice tho :D Did you do those two or three pin swaps too? Does this mean you're close to having it up and running? :)
Postby dannyboy on Thu Mar 17, 2005 11:07 pm
Stuff like fuel pump, interior light, fog light switches, ignition connectors etc were on the part I took iirc. If you want I can dig out the list I made.
Its not far off running, getting the bodywork sorted next month so has to be done for then.
dannyboy
Postby heeman10 on Thu Mar 17, 2005 11:10 pm
Go on then, I won't be home for 5 more days, so it'll give me something to think about before I get back to the car :) I had a quick flick through, the entire loom seemed to be there, but I'll see what you come back with. Sounds like Mr Dannyboy could be up and running before June then! :D Hope to see you at some events in summer perhaps then :)
Postby dannyboy on Thu Mar 17, 2005 11:33 pm
Leave it with me, ill get some pics of what ive done on my loom aswell :D
dannyboy
Postby heeman10 on Thu Mar 17, 2005 11:37 pm
Good man Image
Postby MotorcyclesFish on Fri Mar 18, 2005 12:04 am
heeman, you are going to be SO pissed off the first time you blow a seal and piss oil all over your shiny bits... :lol: :lol: :lol:
MotorcyclesFish
Postby heeman10 on Fri Mar 18, 2005 12:05 am
Thanks for cursing my life's quest :)
Postby TomRS1800 on Fri Mar 18, 2005 12:09 am
Nice work their James
Don't fancy shining up a few bits on the Pulsar do you?
TomRS1800
Postby StreetDragster on Fri Mar 18, 2005 9:09 am
Looking good James, any good at polishing helmets ? :lol:
StreetDragster
Postby RS_Rawli on Fri Mar 18, 2005 10:03 am
MotorcyclesFish :heeman, you are going to be SO pissed off the first time you blow a seal
wont be the first time ive heard
:oooh:
RS_Rawli
Postby Captain Tightpants on Fri Mar 18, 2005 11:52 am
:lol: :lol:
Captain Tightpants
Postby RS TURBO S2 on Fri Mar 18, 2005 11:53 am
disgusting
looks good tho (not the seal)
i am doing a zetec turbo on my S2
(cudn't afford a festa when i got it now spent too much on it to sell it!!)
going for OFAB until i can affotd after market management
and found this stuff ...
http://www.enginemanagementsystem.com/ecuspecs.htm
wot do you lot reckon.
cost is about 500 but no uk dealers yet but some of the dealers wud ship to uk but wud anyone map it??
RS TURBO S2
