My Escort Cosworth...
Postby Excursion on Sat Mar 25, 2006 1:32 pm
Love it mate, real nice! Idon't actually like that colour paired with stock rims, but that looks spot on.
The bad paint match where it's been de-locked detracts from it a bit though.
Postby mike_wall15 on Sat Mar 25, 2006 1:39 pm
Looks good Ad, not sure on the centre's being blue though :wink:
mike_wall15
Car: 2002 BMW M3
Postby MAD_Adamski on Sat Mar 25, 2006 3:25 pm
cheers guys :) ...
mark could be the fact that the car hasn't been finished off :rolleyes: :oooh: theres a touch of overspray in 1 or two places jamie didn't manage to give the car a buff or anything after the painted it and i needed the car he hasn't had the chance yet to finish it off :( my fault i suppose...
but gonna get him to check a couple of bits on it soon so will get him to sort it all then.
MAD_Adamski
Postby garyhurn77 on Sat Mar 25, 2006 6:12 pm
:o :o :o :o Love it Ad :o :o :o
garyhurn77
Postby TomRS1800 on Thu Mar 30, 2006 12:25 pm
Right all you brown nosing f*ckers you can stop bigging up the Bender and actually relalise its driven by a Homo!
:lol: :lol: :lol:
Just kidding
Rims look nice Ad but I must say with the standard front and rear arches it makes the doors look odd as in they dont look like they match up but thats because the picture is taken at an angle
The suspension set - up sounds top notch and the wheels look good (I personally would have them in Anthracite) Keep the clear side and fronts as amber just looks gash and far too standard for a semi modded car!
Keep up the good work you F*cktard :lol: :D
TomRS1800
Postby lazy_arse_pie on Thu Mar 30, 2006 5:11 pm
looks awsome on the new rims mate
lazy_arse_pie
Postby MAD_Adamski on Sun Jun 11, 2006 7:53 pm
hiya guys and girls, some of you may have realised i'd not been on much this is due to being real busy, the cossie has beenb playing up so been trying to fix it, been on my hols and working loads :o ...
well now the fiesta is coming on [ERRR] be on the road v soon goin tues to get the final runing bits sorted then its off for MOT :)
but here are some pics of the cossie today and some updates of it....
ok heres for whats been going on with it had a few sensors replaced due to playing up, i am now booking the car in for the autronic management in aug :) ... meantime the car will be fitted up with a foam filled std tank with uprated 023 pump and braided line.... also the best idea is to upgrade the fuel pump wiring so i have fitted the car up with a new relay wiring system... also bought a big wing sump for the size's and i have a new sump off to A+H for big winging then will sell the one i bought :) .... also aquired a small turbo head which is going off to a good friend who builds rally engine who is going to flow the head hugely for me :D ...
got a spec R grp A breather system coming too :aviator:
peace out Ad xx :D
MAD_Adamski
Postby MarkRS2K on Sun Jun 11, 2006 8:15 pm
been spending some money then :lol: :lol:
Looks mint mate
MarkRS2K
Postby MAD_Adamski on Sun Jun 11, 2006 8:20 pm
cost a bit yer :rolleyes: trying not to spend much just grab bargains :) and also the fuel pump etc was needed for my management upgrade in a few months :) :wink:
MAD_Adamski
Postby heeman10 on Sun Jun 11, 2006 11:14 pm
Finally, a photo that makes the car look as good as I think it is! (Top pic ;) ) Looks very nice indeed :) Is it running properly now with the new sensors? You didn't say :-? And which sensors have you had replaced now? Which sensor proved to be causing the probs?
Postby MAD_Adamski on Mon Jun 12, 2006 1:16 am
i replaced the lambda sensor first that made no major change so i spoke to mark shread he mentioned the air flow meter so i swapped that for a new one and it ran better :) .. so i then decided to remove the ecu to try to reset it, plugged it back in after a bit and let it get used to the sensors, current situ its running as it used to but is still a touch out idleing huge improvement tho the problem cud be the plugs tho as i have removed the type i had in b4 and threw them out and replaced them with NGK ones but i think the car runs better on the motorcraft items :rolleyes: ...
will see how she goes for a bit but just to be certain its not the fuel pump i'll be replacing the fuel filter and fitting my new tank asap, that [ERRR] then be good for 500bhp :) but i also have plans in the near future to replace all the fuel lines for braided and to run a swirl pot with a 044 pump too just to keep things nice and pressureised :D
as mentioned tho i am saving for the management change its much needed now i think due to these sort of problems :( so i shall book it in start of august but i need to sell my sm2 first as i am going for a different ecu as its easier for me to use on my engine :)
to be continued... :bonkers:
MAD_Adamski
Postby ant pittaway on Mon Jun 12, 2006 1:29 am
very nice mate, cant wait to see the cossie and the fez together! :)
ant pittaway
Postby andyhardy on Mon Jun 12, 2006 2:02 am
Looks great Adam! :Q
Postby muz on Mon Jun 12, 2006 2:06 am
I walked past it last Tuesday and it looked stunning. I glannced in the shop but I couldn't see you.
muz
Postby heeman10 on Mon Jun 12, 2006 2:30 am
Isn't it running at 300bhp or so at the moment? Biiiiiiig step up if you're looking at passing 350/400bhp as you know! :o I hope you're selling those fish like there's no tomorrow for a new turbo and the infamous Cossie transmission overhaul! :bonkers:
Postby chris-fiesta on Mon Jun 12, 2006 8:31 am
looking good m8, white wheels really suit it :Q
chris-fiesta
Postby purple_fiesta on Mon Jun 12, 2006 8:33 am
looks sweet on them wheels 8)
6 Point Safety Devices Cage.
purple_fiesta
Postby MAD_Adamski on Mon Jun 12, 2006 9:56 am
thanks all, and in reply james i am not going over 350bhp may not even go quite that far :) :P i just want a bit of extra grunt my T28 hybrid [ERRR] take it too as i dnt wanna change the turbo yet... so when the management is done next years plan will be to get a engine build under way and also get the underside speedlined :P
MAD_Adamski
Postby garyhurn77 on Mon Jun 12, 2006 4:30 pm
looking good fella! :D :D
a&h fabrication is the way forward 8)
garyhurn77
Postby MAD_Adamski on Tue Jun 13, 2006 12:12 am
thanks gary there awaiting you :wink:
MAD_Adamski
Postby Ghost on Tue Jun 13, 2006 12:43 am
good on ya knobby :P
Ghost
Postby Richard_xr2i1800 on Wed Jun 14, 2006 2:18 pm
Love it mate, all the right bits :D , hoping to get one of these next :)
Rich
Richard_xr2i1800
Postby MAD_Adamski on Sat Jul 15, 2006 12:49 am
ok few new bits :) fuel pump has been fitted up now so is ready for anything :D ....
just got my brand new A+H big wing sump :o weld quality is TOP as usual!!!!!!!
right next on the list as you may know my car is going in for a management change so i have now purchased a T34 STG3 with .48 housing for a better pickup :Q
nearly got all my bits for the conversion now so the car will be booked in the 1st or second week in sept :oooh: ....
then the car will be away for 1-2 weeks then come back with all the autronic goodies, and 340BHP :D
cheers Ad
MAD_Adamski
Postby adz on Sat Jul 15, 2006 12:58 am
u update at the most random times :lol:
that sump looks awesome, bet it was reflected in the price though. fair play though, doing everything properly 1st time round in both cars.
good man :D
adz
Postby MAD_Adamski on Sat Jul 15, 2006 1:51 am
randomness is my fortay :D
MAD_Adamski
Postby garyhurn77 on Sat Jul 15, 2006 10:46 am
love it ad!
a&h come good again they must love you down there, they make some money off you! but fair play they always seem to do a quality job, cant wait untill they get hold of my ka in a few weeks! :D
garyhurn77
Postby heeman10 on Sat Jul 15, 2006 12:18 pm
What boost will it be running? Sump looks nice :D
Postby MAD_Adamski on Sat Jul 15, 2006 12:29 pm
unsure on boost tbh james :oooh: mark just told me to get a good T34 with a .48 housing and he can get a strong 340-350bhp, i juts dont want my gearbox to fall out tho :rolleyes: ...
chances are my clutch will fry anyway :( so will have to run low boost till i get one :oooh: thats if i haven't got a uprated one in there :-? there was a recipt for a AP one but unsure if its still in there :-? ...
i'll wait and see :)
MAD_Adamski
Postby TomRS1800 on Sat Jul 15, 2006 1:46 pm
Still looks gay
TomRS1800
Postby MAD_Adamski on Thu Aug 03, 2006 5:49 pm
update time :)
some of you may know but here they are :devil:
decided as they were going very cheap to invest in these :D ... should work better than my old ones :wink: the bells and the brackets are off to the anodisers as they were a bit pooy so will be on the car in a week or 2 :devil:
MAD_Adamski
Postby Superal on Thu Aug 03, 2006 6:30 pm
Looking good :D
Most people would be happy with just one money pit :lol:
Superal
Postby rich_frst on Thu Aug 03, 2006 8:59 pm
just looked thru the whole post ad, very nice car mate, love this colour the most... the wheels suit it down to the ground!!!!! :Q :Q :wink:
rich :bonkers:
My ProjectS..
viewtopic.php?t=97195&start=0
rich
07834862431
rich_frst
Your car: mk1 sierra cos, mk2 escort est
Postby mike_wall15 on Thu Aug 03, 2006 10:15 pm
Poor physio sport :cry:
mike_wall15
Car: 2002 BMW M3
Postby MAD_Adamski on Thu Aug 03, 2006 10:17 pm
the physio sport should be honoured!!! :lol:
MAD_Adamski
Postby mike_wall15 on Thu Aug 03, 2006 10:21 pm
You need to stop spending Ad! Looks like you've got some lovely additions to put on over the next few months :Q
mike_wall15
Car: 2002 BMW M3
