MY fiesta si - engine mounted 23/10
156 posts • Page 2 of 5 • 1, 2, 3, 4, 5
Re: MY fiesta si - Update, pivot beam bushes
oh and the rust you can see on the arches... sills is all surface rust did grind it back to bare metal just to check after i did this
fifi
- ben17southport
wouldnt have bought the 3/8 drive sockets myself
i did this job myself about 2 weeks ago, my bushes come out easy with a hammer, and my flo flex bushes were the same, took some coersion to fit, perks of a polybush
oh btw, the design of the beam doesnt pivot, its a semi trailing torsion beam to be arsey
haynes words, not mine
how come? its a great socket set?
did you hit them from the inside though? and did you remove the hole beam?
fifi
- ben17southport
was during sill repair, beam was completely off, but still come out easy
3/8 drive isnt as strong as a 1/4, nor as handy/widely used
jonyb4 :3/8 drive isnt as strong as a 1/4, nor as handy/widely used
No it's stronger. 3/8 is bigger than 1/4
- rs220bhp
thank you rs220bhp...
try doing it with it on the car, can imagine its ten times easier with it off the car.
whole*
whole*
fifi
- ben17southport
you know i meant 1/2 inch drive
Re: MY fiesta si - momentarily shafted
Haven't updated on here in a while so i'll just let ya'll know what the 'situation' is.
ignition barrel is bummed... had keys cut to see if it was them (then again it could still be if they weren't done properly) but i'm putting it down to the barrel. was going to remove the barrel to get it rebuilt but i can't get it to the first click to remove...
so, i'm away for 2 weeks then when i return i will be bashing the f*ck out of the barrel to remove it and buying a whole new lock set/ignition barrel and keys so i can just swap over the chips and bobs your uncle.
if there's anything i'm missing i would appreciate it if someone could point it out thanks!
fifi
- ben17southport
oh bugger, this just Happend to my mates 3 series bmw, took him weeks to sort it all as he broke his immobilsier ring at the time of bashing the lock out, so be careful
yeah i dont want to bugger it up lol. had my new barrel and key arrive today (genuine ford items) and began drilling the lock out. need to finish it off tomorrow! joys
fifi
- ben17southport
Re: MY fiesta si - update 15/08/1012
right chaps. been a while since i last updated so ill keep it brief.
ended up drilling the ignition barrel out and replacing it with my new genuine item and it worked a treat. ran beautifully considering it had gone 2 months without being started.
i am now in the position where she is off the road for the 2.0l to go in!
temporary home...
my gearbox is at gears.tv atm getting rebuilt, checked and the du bearing replaced along with all the seals and gaskets.
i've have my rs2000's refurbed...
so i'm currently getting my rs2k calipers broken down to get them shotblasted and powder coated and awaiting my coilovers to be re thread.
so watch this space...
to end, a picture i took when i went camping the day before it came off the road...
thanks, Ben
temporary home...
thanks, Ben
fifi
- ben17southport
take a picture from the nearside for us
wheels look great
wheels look great
i do like this one quite alot! bring on more updates
- russ-RST
- Your car: fiesta rs turbo
how come jonny?
thanks smidy devil, hopefully should have some today
fifi
- ben17southport
Re: MY fiesta si - gearbox is fooked
right chaps, got a call of Andy yesterday at gears about the box. he said it'd be better to come in so he could show me so off i went this morning.
if you look closely, the bearing in the middle is too low, basically its been boared out too deep for a newer bearing so it will end up starving it of oil.
so it's getting a full rebuild now
fifi
- ben17southport
wont it just be best to get a replacement box, should get one for £30 easy, even a 1.6 box
You could IB5 it.
Or even MTX75 it if you know a welder and get some drive shafts sorted.
- DanFraser
i could jonny but what suprises would that hide?
plus i want an lsd, want it to last.
could dan but for the power ill be having i wont need it. maybe future yes but not atm.
fifi
- ben17southport
Re: MY fiesta si - engine out
thanks lou. glad you appreciate my hard work and wallet
yeah dalsy, im hoping its a minter when i finally finish her and get to drive her!
well today i finally got the engine out! was a very nerve racking experience. because of the confined space i had, me and my dad simply dragged the engine from underneath when the car was up in the air to save pissing around
the journey from the shed to the carport!
the situation
once i had it out it was ready to go and get my new rebuilt box
andy at gears.tv has done a great job by the looks of it! will be getting a new lick of paint
so yeah. now its just a clean up, get the new loom in a work my way up.
managed to get the pistons out of the calipers so they will be getting a refurb soon
thanks. Ben
the situation
thanks. Ben
fifi
- ben17southport
good work, biting the bullet is a daunting thing for most, first time dropping an engine?
why wouldnt an iB5 not suit your power? they mostly deal with 115bhp 1.8 escorts lol
so which engine is going in? 1.6, 1.8 or 2.0?
You really need to read Jony.
He didn't say an ib5 wouldn't suit his power, he said for the power he will have, an mtx75 isnt needed.
2.0 engine going in as stated a couple of replies ago too.
- - Danny Boy -
- Your car: Fiesta Si 2.0
thanks for pointing that out danny
yes, 2.0l jony. until i go for more power in the future. this will do just fine. dont have time trying to find another so thats why chap
fifi
- ben17southport
the box ive just had rebuilt will cope with 185bhp so it will be more than suitable for the time being and if i want a little more power for the future.
fifi
- ben17southport
ib5's are stronger than the bc boxes Jony so why are you being a plank? he's just stated he's had it rebuilt by G.E.A.R.S which incase you didn't know is a very reputable company that know their s**t, if theyv told him
it will handle that, it will handle that
you should start reading the thread before you post on it...
progress looks good, always daunting whipping the lump
out first time once uv done it once itl
only take half hour the 2nd time keep the progress coming
- russ-RST
someones being hairy over a misunderstanding again
ive heard of a BC box handling more than 190bhp, all im saying
and ofcourse a iB5 is an upgrade, they have stronger web designs on the box casings, i just didnt READ the MTX 75 part... relax lol
smidydevil :ib5's are stronger than the bc boxes Jony so why are you being a plank? he's just stated he's had it rebuilt by G.E.A.R.S which incase you didn't know is a very reputable company that know their s**t, if theyv told him
Thank You smidy. seems like everyone is saving me the job of going through stuff here
was certainly a challenge but yes i hope you're right about it going in easier!
hopefully get some engine parts painted today but there wont be any major updates till next week!
thanks so far everyone.
and jony, the box before i had it i was told could handle 200bhp.Andy suggested its around 185bhp but im guessing thats as a precaution! i wont be going anywhere near those figures anyway so i dont need to worry
fifi
- ben17southport
Re: MY fiesta si - little update
chaps, put the engine on blocks yesterday to paint the sump and begin swapping the alt brackets over...
and also gave the gearbox a fresh lick of paint
also got a 4 branch ashley manifold and full ashley system with it. getting the standard 1.6 downpipe for the future as i know the issues that come with ashley manifolds (it hasn't been fitted on a car before btw).
tomorrow ill be painting the engine bay. sending off the calipers to get all the pistons, seals etc replaced and to have them shot blasted.
any commments welcome. ben
fifi
- ben17southport
Re: MY fiesta si - Update 20/09/12
Right chaps, bit of an update...
braided lines arrived today
flywheel
aux belt fitted
(the pas pipe will be bent to fit correctly, it must have been deformed in transit!)
new alternator next among the crap
mondeo servo in
comparison in size
also, after much delegation, i decided to swap the 1.4si piping with the 1.6si piping at the steering rack. thanks to Mark for advising me to swap the piping, didnt seem to difficult in the end, hence why i did it.
will update when my clutch alignment tool arrives! just need bolts for the side engine mount and ill be ready to get it in.
new oil filter on
side mount mocked up (had to grind a bolt off that had a nut attached within the chassis.
next bit is the wiring to the alt.
new alt
alt off the 1.4
second pic isnt very clear but there is different terminals for the wiring. i will go through my new loom to see where the cable is but im guessing it will be completely different hence the different terminations on the new one?
the ho inlet came with the fuel rail but not the plastic black bit with the wiring (not sure on the name), i know its a long shot but will i be able to use the one off the 1.4 inlet?
Also a massive thanks to Awol for providing the bolts i need for the inlet. nice one buddy!
and one final one for the record
calipers are also off at bigg reds getting shot blasted, painted along with seals and pistons so should get them back soon!
comments welcome guys, thanks
flywheel
aux belt fitted
mondeo servo in
comparison in size
new oil filter on
new alt
alt off the 1.4
fifi
- ben17southport
clutch alignment tool?! just use a ratchet handle end or something similar
take care bending that pas pipe back over the rocker cover, they snap very easily, ive had to replace mine before from moving it very little
and your flywheel could do with a skim, loads of heat spots on it
coming along VERY well mate, how you coping so far without your car?
keep it up wont be long now and you'll be enjoying a very fun fast ford
15mm copper tube and a roll of insolation is all you need to make your own clutch alignment tool
yeah someone recommended a lipstick with insulation tape round, but i know id f**k it up so thought id spend the money. thanks though Jay
fifi
- ben17southport
you carry lips sticks do ya mate just kidding.
na cant f**k it up fella, just dont put tape on the very end to locate it in the flywheel nice and snug, other wise you wont pull the fcuker out as the hole in the flywheel is bigger than the spines on the clutch plate
yes i made that mistake way back in the day and had to take the clutch off again to get it out
sorry jony never saw your reply!
yeah im going to heat the pipe up first buddy before i bend it already bent some cold and it went ok.
surely the flywheel will be ok without a skim?
doing alright though mate, pain riding my bike to work etc but apart from that its fine. but yes, looking very forward to the step up in power!
haha Jay, ive already got that reputation over on fsi.com, dont want it here too Joking!!!
knew i should of checked before i bought it lol! should be here tomorrow anyway so will get done either way
fifi
- ben17southport
