My New Runaround Saxo VTS : Member's Gallery | Fiesta Forums
Postby mrorange2 on Wed Aug 15, 2012 12:03 pm
I have been looking for a better work car than the crappy escort i had so thought i'd look for another VTS.
Came across this one and thought! it ticked all the boxes cheap and nice low mileage. But it was cheap for a reason lol.
Its a 2000 VTS with a genuine 42k on the clock but had some very bad knocking at the front and rear plus some dents etc.
This is as i bought it:
The knocking at the rear i thought was the rear beam as the passenger side had some play in it however it wasnt just that :cry: the drivers side boot\rear arch had some rust in it so this needed sorting asap.
Better pics of it.
Then got some VTS alloys and did the front lower arms and CV boots also painted up the front inner arches as it would appear this car had some big alloys on at some point in its live as there are scuff marks on the inner arch so all painted up.
Some Pikey helped me out!
Still lots to do to it though to get it up to standards it needs:
Rear Axle replacing
Change Exhaust
Change Rear bumper
new drivers headlight as clips are broken
Oil temp sensor plug needs new one
new tyres
thats just for starters
Its all polished up now so this is how it looks now i don’t have a good camera so it doesn’t do it justice.
Comments welcome
2014 Fiesta ST3 & Mk6 Fez ST
mrorange2
Re: My New Runaround Not Ford
Postby bakewell001 on Wed Aug 15, 2012 12:38 pm
Looks like you've cleaned it up well.
I'm potentially on the lookout for one of these, or another 106 gti cheap. I know cheap with these generally means quite a few things wrong though!
bakewell001
Postby mrorange2 on Wed Aug 15, 2012 1:05 pm
bakewell001 :Looks like you've cleaned it up well.
Your not wrong there! i got this for £700 and i knew it needed the rear axle etc so i didnt pay much i was after something with low mileage all the suspension bits i can sort so i'm happy with it.
I wanted a 106 GTI but they cost so much more than the saxo and none with low mileage so it had to be a saxo for me plus i've had a VTS before.
mrorange2
Postby jonyb4 on Sat Aug 18, 2012 11:30 pm
Bloody saxos
Postby Ratspeed on Sun Aug 19, 2012 1:33 pm
I wondered when that pic would surface!
I thought it was for personal use for when you gave yourself a 'treat'
Ratspeed
Postby Choosey on Sun Aug 19, 2012 3:38 pm
Always liked these, especially with the ph2 alloys on there. Not bad for a little run around!
Choosey
If only I had an RS1800....
Your car: 2021 Jeep Wrangler
Postby FiestaBen on Sun Aug 19, 2012 7:46 pm
Love these little saxo's. Lovely little cars and bloody nippy too!
FiestaBen
Car: 1995 Vauxhall Astra
Postby - Danny Boy - on Sun Aug 19, 2012 9:55 pm
Cleaned up quite well! Looks much better on the vts wheels too!
- Danny Boy -
Your car: Fiesta Si 2.0
Re: My New Runaround Saxo VTS
Postby mrorange2 on Mon Aug 20, 2012 9:37 am
Cheers guys. Theres still lots to do on it yet before i can say i'm fully happy with it.
At moment it sounds like something on the rear is about to fall off lol it knocks and bangs like a ba**ard so found a rear axle close to me i'm going to get as well as some lowering springs and an exhaust.
mrorange2
Postby rs_fiesta on Tue Aug 28, 2012 10:26 am
I know Mark who has had the Saxosport exhausts made for these,made by Scorpion and exactly the same as the Peugeot sport exhausts made by magnex.My mate has just put one on his Saxo tour de coarse and loves it.
rs_fiesta
Postby hb69 on Tue Aug 28, 2012 7:09 pm
The Pugsport exhausts are amazing, 2" especially. A cheaper non stainless steel alternative is a 2" supersprint system, they sound almost the same
hb69
Your car: Fiesta 1.1 LX
Postby mrorange2 on Mon Oct 08, 2012 9:52 am
Thought i would update this i have been busy with sorting bits out for it and getting it to a good state and it drives so much better now than it did i'm actually enjoying it now.
Changed the rear axle for a fully refurbished one and powerflex bushes
Changed the front springs for koni 35mm loweing springs while doing this i changed the strut top mounts and bearing.
Now it drives great and no banging etc so very happy but i still have a long list of bits to sort.
Needs paint working sorting rear drivers side has milky laquer and chips in it, rear drivers side had dint and very deep scratches then there are very bad scratches all over the car.
Exhaust needs be to change and new rear bumper sourced and fitted
Exhaust blowing from where manifold joins downpipe
Needs New Lower Gearbox Mount
Going to change the linkages for steel ones
Need new rear tyres
Splice in new plug for oil temp sensor
Passenger side electric window goes down but only intermittantly comes up
Need to change the speakers rears not working and fronts are shocking
Few Piccys after a gave it a quick clean at weekend sorry for piccy took on my phone.
Exhaust waiting to go on!
Comments welcome
mrorange2
Postby heeman10 on Mon Oct 08, 2012 9:04 pm
That looks shiny as fook! Does the Saxo have adjustable rubber stops under the leading edge of the bonnet? If so, looks like the one on the driver's side needs winding down a bit :)
And oil temp sensor? That's a bit swanky!
P.S. Piece of French crap etc, obviously :)
Postby mrorange2 on Tue Oct 09, 2012 9:36 am
heeman10 :That looks shiny as fook! Does the Saxo have adjustable rubber stops under the leading edge of the bonnet? If so, looks like the one on the driver's side needs winding down a bit :)
Cheers James it looks better in the flesh! I had the bonnet popped as i was just about to fill the washer fluid up.
Yep an oil temp sensor its french so as all ways it didnt work but turned out the plug is fooked so got another one just need to chop it in.
mrorange2
Postby Ratspeed on Sun Oct 14, 2012 5:48 pm
You know my thoughts mate.
its s**t :lol:
Ratspeed
Postby mrorange2 on Sun Oct 14, 2012 7:46 pm
Cheers matty your just jealous!
mrorange2
Postby jonyb4 on Mon Oct 15, 2012 12:11 am
first time he uses the forum in 2 months he takes the piss
Postby ben17southport on Mon Oct 15, 2012 9:46 am
like this a lot. the wheels looks spot on. my mate got a saxo for his birthday. very impressed by the way it drives and the way it pull, even for a 1.1! been trying to talk him into getting vts alloys but he wants vtr's instead!
fifi
ben17southport
Your car: Ford Fiesta mk3 Si
Postby mrorange2 on Tue Oct 16, 2012 8:51 am
ben17southport :like this a lot. the wheels looks spot on. my mate got a saxo for his birthday. very impressed by the way it drives and the way it pull, even for a 1.1! been trying to talk him into getting vts alloys but he wants vtr's instead!
I hate VTR alloys the VTS ones just look so much nicer and not a common as the VTR ones.
If he has a 1.1 you might want to check if he has 3 stud.
mrorange2
Postby ben17southport on Tue Oct 16, 2012 9:20 am
no its 4 stud mate, tried flogging him my ford multispokes :P
but yeah you're right. much cleaner looking
fifi
ben17southport
Postby Evolution-VII on Tue Oct 16, 2012 11:44 am
This car is amazing!
It's a shame that we never had this car in Brazil... :rolleyes:
I would love to drive one...
Evolution-VII
Your car: Fiesta Mk3 2.0
Postby Ratspeed on Tue Oct 16, 2012 8:47 pm
Evolution-VII :This car is amazing!
you'd be dissapointed :lol:
Ratspeed
Postby mrorange2 on Tue Oct 16, 2012 9:17 pm
Ratspeed :
Haha cheer matt i didnt know you liked it so much lol.
Its soooooooo much nicer to drive now im starting to enjoy driving it now just need to get the exhaust and gearbox mount done and ill be happy.
mrorange2
