My Red FRST (before we started pulling her apart)
16 posts • Page 1 of 1
Hi all i have been told to get some pics up here for you to see,
this is my car before M.O.T and 2 pages of failures, also before we started pulling her apart and found all the rust and fibre glass, passenger rear arch was mostly fibre glass oh the joy.
it started fine here but didnt run well as the turbo was knackered.
http://www.flickr.com/photos/63834277@N ... hotostream
- Gavlaahh23
- Your car: Fiesta RS turbo 1991
Re: My Red FRST (before we started pulling her apart)
Dude use the img button above the text box to insert your piccys on the thread its alot easier for other users so see them that way.
Car does look ok in the pics. Shame it was hiding so many gremlins. How much did you pay for it if you dont mind me asking??
- niracka
- Your car: E46 M3
2 pages, fcuk me, what did it fail on?
hahaha its needed welding all along both outer sills,
the drivers side iner sill had to be rebuilt.......... we pulled the trim off and discovered all the passengers rear arch was mostly fibreglass so we cut out and replaced that......... so all the interior had to come out.
the rear brake hoses were bulging under pressure so we replaced them.
the washers didnt work so we got a pump off a mk4 from a scrappie......
the brakes were imbalanced due to old pads and a clip missing from the calliper on the drivers side and the calliper had seized a new calliper was put on there. the threads went in the carrier on the passenger side so i got a carrier from a scrappy.
we also replaced the front flexi hoses as they were cracked.
the turbo was knackered so i got a new unit from midland turbo in nottingham after sending my old one to them.
then the downpipe snapped ( an old thing the previous owner had knocked up ) i got a stainless built by longlife £50 but they could not guarantee it would fit as i could not get the car to them..... its about half a centimeter out so im hoping they maybe able to sort that when i can get the car to them, i made it fit and it doesnt blow
then the altenator belt snapped so i replaced that.
both side repeaters wouldnt work or brake lights or main beam on passenger side. i got the repeaters going and the brake lights to flicker haha but no go with the main beam, tried bulbs fuses and relays.........
i cant remember if anything else with out looking at the failure sheet.
but the good news is i put it in the garage with only the lights left and they rang me earlier and its fooking PASSED woo hoooo. so i can pick it up tomorow.....
my rad has a leak so im looking for a new one and i havent seen a FRST that runs well but im pretty sure mine needs setting up properly. it boosts a bit but doesnt pressurise enough to dump hard.
so yeah i saved her haha, gona get a mate to paint it soon...... i have a holiday coming up maybe after that.
does anyone know a good place to get it set up? or can anyone on here do it?
- Gavlaahh23
Just try to find someone who does live maps in your area they should be able to help but as for a specialist I wouldn't know. I'm sure someone on here will be able to help you thaugh buddy.
ollie
ollie
- niracka
- Your car: E46 M3
nice one fella, i will give it a go. this sites quality fair play ive learnt loads snooping around on it and your all proper helpfull.
nice one people
nice one people
- Gavlaahh23
Yea man its a real good place for finding info on allsorts of good stuff and also a good place to make friends with people and have a little friendly banter
- niracka
- Your car: E46 M3
thats a fair bit there, but i would of said nothing short of normal wear and tear.
the main beams though, have you tried cleaning up the earth point where the brown wires bolt to the body, if there corroded it cuases all sorts of wierd things to go on
the garage who did my m.o.t fixed my lights for me, they did however say they are not sure how long it will last as they are not the best at electrics.... so i will check that out J.
had it out on the road today
it isnt boosting right tho..... seems to be there but doesnt boost well..... boost gauge sits on the minus side of the gauge untill you rev it then it only goes half way on the gauage which isnt even 0.2 of a bar........
also when it got warm it would not tick over kept stalling......... which made junctions bloody fun on the way to work hahaha
any ideas? again thanks for all your help
gav
gav
- Gavlaahh23
I know its hard but try not to use it all the time till it gets sorted otherwise you may be a looking at a BIG bill to fix it. Its sooo hard to try and help someone with a problem like this without actually seing the car.
Ollie
Ollie
- niracka
- Your car: E46 M3
yeah i know what you mean,
the worst thing is its the only car i have on the road
and ive got my fkin misses moaning that im always working on my car and when im not she has to run me around hahaha, women never help nowt....... id be hapy if she f**cked off fora few weeks and left me to get it sorted hahaha
- Gavlaahh23
Is be happy if mine f**cked off forever n just left me to it!
Does it sound like the turbo is boosting? Fix be u got a split boost pipe or something similar leaking ur boost off. Did u check for play in turbo shaft?
- niracka
- Your car: E46 M3
hahahahaha
i just put some redex injector cleaner in my tank when i filled up..... sooooo it was a different kettle of fish then
the boost guage hit 1 bar an all sorts hahaha
best £6 i spent for ages
the alternator belt snapped then tho, its the second time its snapped one, so i dont know why its doing that.
hhhhmmmm have to get another tomorow i hope.
- Gavlaahh23
hmmm thats interesting then. I would get it looked at by a garage if it goes titts up again thaugh mate as its just one of those cars its best to be sure. any other mk3 i wouldn't be too fussed about but its a turbo and only the best will do
- niracka
- Your car: E46 M3
got the belt on, took her fora spin, seems to be running nice, got her boosting to 0.6 bar at the moment as the turbo is new...... exhaust is rattling gona take it to longlife see if they will sort out the downpipe they made for me as the exhaust is sitting on the bracket underneath the engine and makes hell of a vibration.........
i was quite happy went up the mountain fora quick spin........... then it started to rain and my fking doors are leaking, theres a gap at the top as if someones tried to get in it..... as its been stored in the garage it had never been in the rain before so i never knew........
so its gona have new doors before its painted...... theres a Si in a local scrappie ive been pulling bits off...... will these doors fit my FRST? hope so hahaha
- Gavlaahh23
Just incase your still after one RSgeorge is selling a frst rad. Go to general car discussion forum its in there.
Ollie
Ollie
- niracka
- Your car: E46 M3
