My RST - nearly come to that time... : Member's Gallery - Page 13 | Fiesta Forums
Postby FezzR on Sun Jul 31, 2005 5:44 pm
ill be suprised your head and pistons aint f**cked if its been firing at random times
FezzR
God Damn Lazy
God Damn Lazy
Postby andyhardy on Sun Jul 31, 2005 5:48 pm
All will be revealed - I have a spare head sitting waiting if it's really fooked, if the pistons are fooked then I'll have to call an end to Ford Fair.
Here's hoping it's not that bad! :oooh:
Postby Captain Tightpants on Sun Jul 31, 2005 6:38 pm
Good luck mate.
How did you get on with Jano?
Steve
Captain Tightpants
Postby andyhardy on Sun Jul 31, 2005 7:00 pm
I met Jano at Bruntingthorpe for TOTB qualifying and he let me borrow his Pectel monitor (hooked it all up for me as well) so I could find out what was going wrong with my car.
Everything was checking out fine (apart from not getting the last 3 degrees travel of throttle - I'm not too fussed about that but will be getting my throttle linkage modified to sort that out) until I hit a bump and the cam sensor went missing (showed up on the Pectel monitor).
Jano then told me it's a common problem with people running L8 Cossie management conversions and he then showed me the Cossie management setup on his XR3 Turbo - much much nicer and definitely works.
He put me onto Stu @ MSD to order the Cossie CPS and sent back my vernier pulley machined up with the bits I ordered the same day as he received my money order and pulley in the post :D
So yeah - he seems ok to me! :)
Postby MAD_Adamski on Sun Jul 31, 2005 7:13 pm
go for it andy!!!!!! your our hero :D
:bonkers:
MAD_Adamski
Postby andyhardy on Sun Jul 31, 2005 7:42 pm
adamski frst :go for it andy!!!!!! your our hero :D
:bonkers:
Thanks - I'll try my best for the FT massiv...
innit! 8) :lol:
Postby MarkRS2K on Sun Jul 31, 2005 8:09 pm
yeah hope you can make it :)
MarkRS2K
Postby MAD_Adamski on Sun Jul 31, 2005 8:11 pm
MAD_Adamski
Postby MAD_Adamski on Sun Jul 31, 2005 8:12 pm
MAD_Adamski
Postby heeman10 on Sun Jul 31, 2005 9:07 pm
I see you're still laughing at all your own jokes ad :rolleyes: :lol: ;)
Mandy - Good luck with it. I'll follow your lead and dismantle my car at the same time as you....lower arms time! Let us know the outcome, would be great if you could use it on the track :)
Postby andyhardy on Mon Aug 01, 2005 1:54 am
Thanks James Image
Postby Max M4X WW on Mon Aug 01, 2005 10:56 am
:lol: Look at thier little faces.
Postby heeman10 on Mon Aug 01, 2005 3:41 pm
:lol::lol::lol:
Postby andyhardy on Mon Aug 01, 2005 6:41 pm
Bit of an update for you today and it's all pretty much good news :D
I went to the post office and picked up the bits from Jano that he sent me back.
Vernier pulley is now machined down to help fit the spacer plate (something that wasn't done before and should really have been with the management conversion).
New bracket for holding the phase/cam sensor in place - has 2 spring loaded mounting points meaning the sensor can be raised/lowered to within 3 thousandths of an inch - which is nice :D
Laser cut pulley for correct timing markings. I need to speak to Jano tomorrow to find out exactly where the prongs should be as the old disc had obviously moved meaning we're a bit clueless about that at the mo.
The new cam/phase sensor should be arriving from Motorsport Developments on Wednesday - I need that for the MOT as the car will not tickover without it.
Simon took the head off the car today and luckily there hasn't been that much damage. 2 things were obviously wrong - timing had obviously caused one of the valves on number 1 to misshape and so Simon has now sorted all of that out - all the damage looks to be due to timing.
Also - where the wiring loom for the engine goes onto the end stud on the inlet manifold it looks like I didn't do it up tight enough and it's worked loose causing an air leak! :rolleyes:
All is fixed now and I shall get the car up and running properly on Wednesday again - I should be picking the car up either tomorrow evening or Wednesday during the day :D
Oh yeah - and for the record absolutely no damage to any of the pistons or block :D
For once I have some good news about the Turbo!
Postby MotorcyclesFish on Mon Aug 01, 2005 6:46 pm
Ace. :D
MotorcyclesFish
Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
Postby andyhardy on Mon Aug 01, 2005 7:39 pm
Thanks dude :D
Postby heeman10 on Mon Aug 01, 2005 8:01 pm
Great news!! Now for some questions:
1. Which valve was out of shape? And in what way? Pics?
2. How did he "sort it"?
3. "All the damage" - what else was damaged?
4. Surely the engine should've been immaculately timed, having been to Grove??? Isn't that a pretty major issue that needs taking up with them Andy?
5. Pics of this place where the wiring loom bolts on? Not sure where you mean :-? Seems odd that a loom-securing bolt would go into a hole that would cause a leak if undone??
Very pleased to hear it's all pretty minor stuff, and that the good things are in the post or in your hands :D Keep us updated and get some damn pics up! ;)
Postby FezzR on Mon Aug 01, 2005 8:35 pm
did you replace the vavle?
much the same questions as sheman, GET SOME BLOODY PICS UP MOFO
FezzR
God Damn Lazy
God Damn Lazy
Postby Max M4X WW on Mon Aug 01, 2005 8:36 pm
Goot luck on sorting everything. :D
Postby MotorcyclesFish on Mon Aug 01, 2005 8:57 pm
heeman10 :Great news!! Now for some questions:
I *think* the conversion was bodged to hell by whoever put it in. :lol:
MotorcyclesFish
Postby FezzR on Mon Aug 01, 2005 9:20 pm
MotorcyclesFish :
the usual me would have laid into the supplier of andy's conversion big style as andy well knows, but i know who did it and it does seem such as shame its turned out like this, but only andy can work out how good/bad it was for what ever their arrangement was
FezzR
God Damn Lazy
God Damn Lazy
Postby heeman10 on Mon Aug 01, 2005 10:28 pm
Always a problem when buying someone else's work. I bought an Excursion-built engine in my Zetec Turbo, as I know he knows way too much for one human head, and felt confident in his abilities. Haven't been proved wrong yet, touch wood :)
Gadget's done a few of these, though I'm not sure if Andy's was one of the earlier or later evolutions of his Cosworth conversions. No-one's perfect, but that doesn't reduce the annoyance and cost when things go wrong, I for one can appreciate that!! (TDI, broken gearbox etc...) All we can do is hope it's fixed for good now, and await pics :lol:
Postby andyhardy on Tue Aug 02, 2005 12:20 am
The car was running ok with the conversion that Gadget carried out - and it has been quite some time since it's all been fitted that the problems have occurred.
The work Gadget has done was good generally and for the money I paid it's a really good job with alot of time that's gone into it (complete modifying of the loom etc.). You've got to remember that Gary doesn't operate as a proper trader, it's more for a bit of cash and because of that the price is cheap! He has helped me loads with getting the parts needed for running it and he managed a quicker turnaround on getting the conversion done than most garages I can speak of (whilst doing all of the work in the evening's after a full day's work!) so I won't have a bad thing said against him.
The problems I've been having do need to be sorted though and Jano Oddkidd has taken it upon himself to become the 'expert' at Cossie management conversions on CVH's and other cars etc. So when I bumped into him at Bruntingthorpe and he showed me exactly where my car was failing it made sense to get the parts from him to take a slightly different tack on the setup used on my car - very pleased I did too.
I'm pretty sure that it's the misfiring that's been happening with the car for such a long time now that has caused the valve damage that has occurred - so would be unfair of me to point fingers at Grove or Gadget, the car has run brilliantly for the majority of the time and the times put down at Brunters whilst everything was not 100% just show the potential the car's got :)
I didn't manage to get photo's of the head whilst it was all apart as I wasn't there at the time - I'll take pictures of the car and engine setup throughout the week though.
I'll be picking it up on Wednesday in the morning :)
Postby MarkRS2K on Tue Aug 02, 2005 8:23 am
glad its coming along :)
MarkRS2K
Postby Max M4X WW on Tue Aug 02, 2005 12:01 pm
Monday :-?
Postby andyhardy on Tue Aug 02, 2005 2:50 pm
I meant Wednesday...
Postby andyhardy on Tue Aug 02, 2005 10:21 pm
I spoke to Simon during the day today and he said the Turbo was ready to be picked up so I picked the keys up off of him and went over to Eastbourne to drive it back.
The new phase sensor plate isn't in the right position and neither is the old cam sensor as it's not meant for use with the bracket I now have. The new sensor is arriving tomorrow (hopefully) from MSD, once I have that I'll be able to stick it on and find out from Gadget, Grove and Jano Oddkidd where the timing plate should actually be located.
The car ran like an absolute bag of poo on the way back and it really doesn't seem to be much different from when the engine was taken apart before, so it would seem that the cam sensor plate moved position during the day at Bruntingthorpe or the mapping itself just isn't right.
The pistons seem to show that the car is running incredibly rich and runs fine when the engine is cold but as soon as the temp gauge reaches about quarter of the way up the car starts misfiring and generally misbehaving with the tickover.
Having done so much to the car to try and fix the never-ending problems it's really hard to find anything mechanically or electronically that's wrong with the car, so I'm going to have to take it to Grove Garage next week (if they're free at all) to let them check through it all.
Sadly this means that I'm probably not going to be taking the car on track at Silverstone this weekend - it's just not worth damaging the engine again with it running the way it is :(
Looks like I've got a really tall order ahead getting the car through an MOT - I highly doubt that the emissions will be safe :(
Here are some photos of the car as it sits at the moment for those that are interested :)
Postby Andy.B on Tue Aug 02, 2005 10:33 pm
Andy catch me on MSN now. :P
Andy.B
Postby FezzR on Tue Aug 02, 2005 10:36 pm
cambelts looking nice and worn,
CAMBELT COVER!!!!!!!!!!!!!!!!!!!!!!!!! :P
FezzR
God Damn Lazy
God Damn Lazy
Postby andyhardy on Tue Aug 02, 2005 10:36 pm
Am doing so now mate :)
Postby andyhardy on Tue Aug 02, 2005 10:42 pm
FezzR :cambelts looking nice and worn,
Finally got a new cambelt cover - will put it on when the car is running properly again, no point until then (it's not going anywhere at the mo!).
:P
Postby heeman10 on Tue Aug 02, 2005 10:46 pm
That bracket looks good :) Sounds as though Grove need to run it all through properly, get the timing and fuelling right...give it a proper setup really, like the first time, or at least like it should've been done :-? Hard to tell how much of the running issues are down to them really. It's totally possible though Andy. Mine takes full throttle and high revs etc with no issues (I'm now confident enough in it to use both!), idles well and emissions are fine, and the fuel consumption's a great surprise :) All that's on crummy EEC-IV, so on Cossie stuff you should be laughing when it's re-done with a decent bracket etc :)
Postby andyhardy on Tue Aug 02, 2005 10:53 pm
Thanks dude - hopefully it will be sorted by getting the timing of the plate correct tomorrow and fitting the new sensor.
I sooo hope to hear the knocking of my door in the morning - could really do with some good fortune for a change!
Postby heeman10 on Tue Aug 02, 2005 11:01 pm
Yeah, you should be enjoying it, should be a good clean runner when you've set it all up :) Let us know, as always! :D
Postby andyhardy on Tue Aug 02, 2005 11:06 pm
If it doesn't run right in time for Trax then I have to put it away again for another winter - haven't got the time or money for fudgekin around with it any more this year!
