My RST - nearly come to that time...
I did ask if he could do it there and then for me but he's inundated at the moment with no helper monkey about!
It's ok though - I spoke to Simon and he's going to weld it back up for me (he knows exactly what bracket it is) tomorrow evening over at his workplace just after he finishes work - I'll be on fire duty inside the car
Car's booked in for it's retest on Thursday afternoon - so all going well I'll be turbocharged again!
- andyhardy
Yep it's a fairly minor bracket, will just need welding at the two ends Fire duty...not something I ever want to have to do again!
Good luck getting it all ready for trax mate, I'm well aware of your luck with this car so I've got all my appendages crossed that it finally comes together for you.
PS get back on msn at some point, your rants/essays on local history and the idiocy of old people are sorely missing from my life at the moment....
- MotorcyclesFish
- Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
Cheers guys - it's not that bad at all really, when he said it failed on just 1 thing I thought he was going to say it was the emissions!
I've got the emissions readings here:
CO: Limits <= 3.5 % vol, actual value = .84% vol
HC: Limits <= 1200 ppm (parts per million) vol, actual value = 26 ppm (parts per million) vol
Well chuffed with that - I don't think that's far off the results needed for a car equipped with a CAT!
One good thing is that I haven't had to tax the car for the month of August
Grant - I'll be on MSN tomorrow dude, have some happier things to talk about for once
- andyhardy
Nice readings. The joys of having a car properly mapped! So it'll be good to go again on Thursday morning at the latest? Bonus! I still have no gearbox cradle, and no reply from the guy...four days before I have to make the 250 mile trip to Silverstone and the whole front end's all bare! Argh!
What guy and what's he done with the gearbox cradle?
Friday morning is when the car will be ready, just got to get it cleaned up and the motorised touchscreen all in properly, not much at all really
It's funny - I took it to a different garage before (for the MOT attempt before Ford Fair) and both mechanics at the garages have said 'you've spent a hell of alot of money and effort on this car!' - I'm like 'err yeah' as I don't want to disclose too much about what it's got although it's quite hard explaining the difference between a plate LSD and a Quaife one (using gears instead)
- andyhardy
Yeah...they always ask me "Oh, so what car does a Zetec Turbo come out of then?"
I had to modify my cradle for the Deflex mounts. I can't fit the Vibra-technics mounts with the modified cradle, so someone was sending me a normal cradle. Have only just thought....think I'll just put the Vibra-technics rear mount on and leave the Deflex front mount on for now...what a dumbass!!!!!! Right...off to work I go!! Can have it back on the ground and running in the morning, Bob's my uncle!
When booking my accommodation for Trax, I was asking about the woman if parking was secluded etc because I'm picky about parking etc....then she got on to ask what cars we have (I'm staying with Scort and Libs on the Saturday night just near the track) and I had to reply "A Fiesta and a Ka" and she laughed We know our cars were worth that time and money....I think Plod on Mandy
Ahh right - gotcha, hope you get it sorted out mate, putting it back together as you said sounds like a plan!
Getting the brakes sorted on the Escort tomorrow morning (finally!) so I'll have 2 fully functioning cars! Can't remember the last time I had one car that ran properly tbh!
It's all fun and games!
- andyhardy
I would send you one through the post but...
1) I don't have a spare one at the moment!
2) I doubt it would reach you after our last attempt at sending alternators via Royal Mail! Did you ever get that 1.1 one back?
Get it fixed mate - I'm sure someone on here will have a suitable replacement!
- andyhardy
nope that was lost and gone forever.
i got a granada one fitted just need to find a belt
also got myself a slightly bigger battery
590 amps and 60 amp hours should be better than my 300 something amps one and its 38 ah
still need to update this sig
- ~Tony~
Cool - you can get adapters to connect the loom up to round topped connector batteries, I had to get some to hook up my Mondeo V6 battery recently
- andyhardy
will eventually get a racing spec battery and fit that somewhere in the bay.
will need the current space for an air filter
- ~Tony~
Another bit of an update for you guys
Got the Escort's brakes fixed today - turns out the cause of the problem was actually the wheel hub nut coming loose! Christ knows how that happened - but it's fixed now and I have working brakes again.
As for the Turbo - got the welding of the bracket done a short while ago, but we also found another (relatively small) problem with the car. Where the reverse light switch has broken on the gearbox it's actually letting gearbox oil through, so I've got to get a new one of those tomorrow and get it fitted as well as top up the gearbox oil - bloody car never stops breaking!
Anyway - retest is later in the afternoon, so job's a good'un!
- andyhardy
How has the reverse light switch broken to do that?? Bit concerning Jack up the front of the car, take out the current one, top up the oil through the switch hole while the car's tilted back then bung the new switch in. 10 minutes My gearbox has leaked 100ml, apparently through the end casing. The bolts all took a bit of a nip up, so I don't know if that means they forgot to torque them all up after building it?
Good luck tomorrow...hope you got to sleep ok in the end. A fat glass of Baileys did the trick for me at about 6am in the end Spent about half an hour in the pouring Cumbrian rain this afternoon and now have a gearbox cradle Will get the ratchet clicking away tonight and build up as much as I can in the dark. Hallelujah! Hopefully we'll yet again share "a good day" tomorrow dude
Had quite a productive day today - got the in-dash screen now mounted properly in the car
I've also set up the stand for the dash mounted screen so that I can show off the carputer at work to people whilst standing at the boot of the car
Cleaning the car tomorrow and doing a last few minute tweaks
- andyhardy
Awesome! If you fit one in mine for <1,000,000 dollars I'd like one of those! I want it to be able to recite catchy film quotes and offend police officers
radio down at the bottom same as me L M A o
im u need me atal add me on msn im ford_rs@hotmail.com
wtd..
all pannels 4 a mk3 fiesta e.g. wings arches and repairpannel filler cap rs2000 breaks and alloys
- hammy_fiesta
andyhardy :No - it has a camp voice and a confidence problem just like KITT
My mate's alarm has a mental voice when you ring it up and talk to it. Sounds like an enraged Korean.
Your screen needs huge bars flashing "NOOOOS" and then "DANGER IN INLET MANIFOLD". Actually given your car, that's quite feasible...
- MotorcyclesFish
MotorcyclesFish :My mate's alarm has a mental voice when you ring it up and talk to it. Sounds like an enraged Korean.
Good luck getting to Trax tomorrow in one piece tomorrow Mandy, fingers crossed eh?!
Well - I made it to Trax ok and on time for once!
I didn't get to take any pictures at the show myself but Jamie took one of my car which looks really good
I took the car out for a quick spin this evening and managed to get some camcorder footage. Unfortunately I didn't check the viewfinder before recording so the camera is zoomed in a bit meaning that the anti-shake didn't work! Oh well - I'll have to replace this video with something better next time
You'll need the DivX codec to view this file - right click and save target as (36Mb):
Fiesta RST running again at last! DivX - 36Mb
Enjoy!
Enjoy!
- andyhardy
Right - I've added a new video now in place of the previous one above!
The mount is still playing up a bit so the camera gets really shakey over bumps - looks like I'm going to have to invest in a proper one like heeman10's
Right click and save target as - 27.3Mb (DivX codec needed):
Cleaning out the cobwebs!
Enjoy!
Enjoy!
- andyhardy
