My XR2i and Zetec S projects - UPDATE 25/11/11
104 posts • Page 1 of 3 • 1, 2, 3
Finally bought myself an XR2i
52k on the clock and a solid floor. bodywork needs touching up in a few places but it'll give me something to tinker with over summer
And yes, the mudflaps are going
- sikora
- Your car: XR2i, Clio Trophy
Re: My XR2i
was just about to comment on those flaps
looks like a nice clean motor you have picked up there
- slaney21
- Your car: Zafira A SRI 2.216V
Re: My XR2i
Its a little untidy close up. I originally turned it down after viewing it but went back and bought it today.
It'll be driven for a week to discover any niggles it has, then taken off the road for a bit of work over the summer
Already discovered an annoying tapping noise coming from the drivers door/inner wing area when driven at high speeds
- sikora
Re: My XR2i
dont look a bad motor that mate, as long as the main bits are solid that what matters, extranl body can be touched up
Re: My XR2i
Looks quite nice in the piccys bud
Best colour choice too
- Ratspeed
Re: My XR2i
looks really nice mate, good find!
- Dave G fsi
- Your car: Mk1 FRS and FRST
Re: My XR2i
Yikes that was quick!
Looks good dan, good find!
- Dazza
Re: My XR2i
Don't look too bad
So glad those flaps are going, they are awful
It definately needs some blues
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
- sikora
Re: My XR2i
floors in the normal place.
as for that rear spring cup, ive never seen one rusted through like that
Re: My XR2i
Popped to the scrappy today and got myself some bits of floorpan:
Spotted this too :
Back at home, i dropped the fuel tank, cleaned it up and gave it a lick of paint:
What a horrible job that was to remove. First rear bolt came undone fine, thought to myself "whats all the fuss about with these bolts?" Then the second bolt went on me - passenger side too so i couldn't see what i was doing with the spanner holding the broken nut on the top The "quick release" fuel coupling was far from quick to release either
Spotted this too :
- sikora
- sikora
Re: My XR2i
nice one with the bits of floor mate, will be easier to do now.
what they charge for them 2 bits? just remember not to use the old number from the scrap car mate
the quick release fittings on the fuel lines are spot on mate, you just got to take the covers off to get to the little tab
i say covers, if you had the "ford tool" you slip it in and job done, if not, break the covers off, and when refitting twist a bit of wire round the fitting to keep the push fitting out.
anyhow, its coming alone nice mate
Re: My XR2i
jayrs :nice one with the bits of floor mate, will be easier to do now.
£10 for the plates which included them moving the car for me. Cut them out myself with an angle grinder. My VIN plate is quite rusty underneath so i may have to weld it on top of the clean one - that'll look good if i ever come to sell the car
I remember reading on here about breaking the white tab off the fuel quick release but i struggled to get it to actually release. Wasn't helped by eye full of rust as i wiggled the pipes
- sikora
Re: My XR2i
sikora :jayrs :nice one with the bits of floor mate, will be easier to do now.
thats a good price mate.
i would keep the bit of floor you cut out, and get a pic of the floor before, during and after, then you can back up the reasons as to why should anyone ask, not that they prob will, but after all, if its rusty its rusty.
when you break the covers off, push the pipe in a bit as if your pushing it back on, then hold the ring around the pipe against the fitting and slide it off, its easy once you have done it once you know how to do it
Re: My XR2i
Busy day today. Scabby bootlid removed and new one fitted . Had hoped to re fit the standard black spoiler but the RS one has been bonded on
Bumpers off too. Pretty tidy underneath rustwise, although i did find this:
I knew it'd had a slight bump on the front and that the n/s wing had been replaced, but, well thats a mess
Tidy rear panel:
And finally we towed it (due to no fuel tank) up some ramps so i can start on removing the rear beam and finish stripping the old underseal off
Hope to get the beam off tomorrow, bushes removed and all painted up ready for the poly bushes and anti roll bar
Tidy rear panel:
- sikora
Re: My XR2i
Jesus Mary and Joseph, what is that all about?
Looks tidy mate, glad the mudflaps have gone!
- EUFez
Re: My XR2i
- sikora
Re: My XR2i
Just picked up some Flo-Flex poly bushes. 2x Rear beam bushes, 2x front ARB bushes and 4x rear ARB bushes
£35 for the lot
If anyones interested, they should be making some front wishbone bushes in the next 3-4 weeks
http://www.floflex.com
£35 for the lot
- sikora
Re: My XR2i
damn that silss bad mate.
there is drain pipes from the sunroof that drain water into the sill, one in front and one behind the door shut, if that makes sense (A and B piller)
Re: My XR2i
those bushes. are they selling them for that price on that site for a while?
wouldnt mind some
wouldnt mind some
- slaney21
Re: My XR2i
slaney21 :those bushes. are they selling them for that price on that site for a while?
wouldnt mind some
It did work out a few quid more buying them from their shop. I worked it out nearer £30 online
- sikora
- sikora
Re: My XR2i
Just plate it mate, common areas to go - Mine has it and Im going to pop a plate on it
- Dazza
Re: My XR2i
Not done much to the XR recently. My fund was greatly reduced by the purchase of Green Day concert tickets too
However i picked up a 3" Magnex cat back exhaust from a member on here
Got a a pair of 16v door looms and multiplugs too as i'd like to try and relocate the window switches to the doors. Just a case of finding a pair of door pockets with the switch holes but in light grey. Will also need another set of 16v door multiplugs so i can add extra pins to the ones i've got
Made a start on making my lower arms camber adjustable too. Flo Flex should have some front bushes made by now so i'll get them ordered soon and then i can remove the rubber ones and seam weld the arms.
We'll hopefully have the shotblaster set up in work soon so i can get the subframes, S brace and ARBs, along with the lower arms blasted ready for painting - maybe even powdercoated if the price is reasonable
- sikora
Re: My XR2i
Time for an update!
Not alot of work done as such due to not being able to get up to the car with this damn weather. Had started cutting out some of the rot on the inner arch and footwells.
Got quite a few parts picked up recently though:
15" Escort GTi alloys
Si ream beam with new brake shoes, cylinders and braided hoses
Polybushed arms. will remove the bushes to put in my adjustable arms
New front panel, wings and sills. Didn't think to check if they were mk3 or mk3.5 wings though, so might cause a problem using standard side repeaters Anyone know if the front panels are mk3/mk3.5 specific too?
My stock seems to be building up now
- sikora
Re: My XR2i
front panels are all the same
take a pic of the repeater holes and i tell ya what type they will take
clark
clark
- knuckles
- Your car: Fiesta Rs turbo
Re: My XR2i
Definatley not the same shape hole as in the picture of the wings you put up in your project thread.
- sikora
Re: My XR2i
Needs better mirrors.
Re: My XR2i
heeman10 :Needs better mirrors.
agreed
you have mk3.5 wings then fella - rounded lamps fit them
- knuckles
Re: My XR2i
Bought some G Max shocks and springs from someone on here.
Cleaned up and after a lick of paint. Needs another good coat as this spray paint is quite thin.
Decided to repaint the fuel tank as well. I didn't have my grinder when i first painted it so didn't prep it very well. Few months outside and it'd started to rust again. Subframe and crossmember have also been stripped back, treated with rust convertor and painted
- sikora
Re: My XR2i
Bit of a change of plan with this. Was planning on doing the welding and underseal, then put it on the road in about a month, mainly because i miss driving a car. However it makes sense to do all the bodywork and get it painted while its already in bits, rather than have to strip it again in the future.
Going to clear the garage where i've been painting in so i can fit the car in there. Should be enough room to work in it in there
- sikora
Re: My XR2i
Sounds good mate!
painted parts look good too
- Dave G fsi
Re: My XR2i
good progress mate, the rot on this is nearly as bad as mine, i had to fabricate the entre floor and lower arm mount point on mine. its in here somewhere aw3k's xr2i thread
- AW3K
