my XR2Tii project.. ..*BIG PIC*
Postby Richardson on Thu Dec 23, 2004 7:03 pm
Looks awesome, can't wait for it to be finished :D
Richardson
Postby STOKE7UP on Fri Dec 24, 2004 4:11 am
looks good a quality job
STOKE7UP
Your car: Depends what day it is
Postby Jur on Wed Dec 29, 2004 7:48 am
The car in primer/filler
The spoiler.. still sweet and smooth :-p
The front bumper.. finally in 1 colour .. now you can get an idea of what it will look like..
same for the rear (with contrast colour)
The boot.. in primer
The enginebay .. in primer..
the paint :-p
the boot .. in colour
The enginebay in colour (hmmz.. hard colour to 'catch' on photo
1 liter of paint was just enough to get paint in all the corners
Now the car is nearly ready to go to the bodyshop for it's final paintjob., just needs some sanding, removing of doors etc.
Doors, boot, bonnet, bumpers will be sprayed seperately
Jur
Postby Brycey on Wed Dec 29, 2004 12:41 pm
Mint :D
Cant wait to see it in the flesh.
Brycey
Postby andyhardy on Wed Dec 29, 2004 3:13 pm
Excellent work Jur!
Postby PhatJoe on Wed Dec 29, 2004 3:56 pm
lovin' it :bonkers:
PhatJoe
Postby Jur on Fri Dec 31, 2004 7:31 am
Nearly ready for the paintjob.. just needs the final touches ..
When front meets back
from the side
The smooth arches.. tested again .. no cracks :-p
Jur
Postby Brycey on Fri Dec 31, 2004 11:22 am
Leave it in primer white!
Thin coat of laquer,your sorted!
Brycey
Postby XR_Ben on Fri Dec 31, 2004 1:29 pm
:Q
Spolier looks mint, and i love the ZS & smooth boot look on mk3's :D
XR_Ben
Postby Jur on Wed Jan 05, 2005 9:50 am
Just have done the final things before respray .. sanded down the car with even more fine sandpaper
taken care of some spots .. sanded the mirors.. etc etc it's now 99,9% clean and smooth :-p
and .. Taken out the doors.. (what a job)
The top doorpins were pretty easy .. the bottom ones were HELL
Made ourselves a special tool (chizzle .. grinded a slot into it) .. the left bottom pin came out .. 10mm .. and broke off. )-: but was loose
The right bottom doorpin .. moved just 3mm .. and broke off.. and had to be pushed out the other way.. (and grind off using a small multi tool grinder (with a 1" blade)
The result..
Door left
Door right
sliding roof.. ehhhm .. sunroof.. ehhm .. wel hole
Hinges
Bend and broken doorpins
Jur
Postby reveller on Wed Jan 05, 2005 1:15 pm
I need to make some tool up to remove my door again they always snap :(
I need to get my mondeo spoiler to fit, gaps here there and everywhere it doesnt sit level :(
reveller
Postby Jur on Wed Jan 05, 2005 1:57 pm
reveller :I need to make some tool up to remove my door again they always snap :(
Jur
Postby Ghost on Wed Jan 05, 2005 2:25 pm
its alright, he's just telling you what he needs to do to his, as he is doing something like yours.
Jur, its looking sweet as, all of these cars going to FITP, makes me think about getting offa my arse and getting down there :D
Ghost
Postby reveller on Wed Jan 05, 2005 5:29 pm
Jur im going to try and blend my mondeo spoiler to my boot like yours, but if its a pain of a job ill just forget it and just have a standard spoiler. :(
I fitted my mondeo spoiler to the standard spoiler today and theres gaps all over the place :(
reveller
Postby Jur on Wed Jan 05, 2005 11:10 pm
reveller :Jur im going to try and blend my mondeo spoiler to my boot like yours, but if its a pain of a job ill just forget it and just have a standard spoiler. :(
well .. we grinded some away to make it fit. and filled the holes with polyester filler
Jur
Postby MAD_Adamski on Thu Jan 06, 2005 1:22 am
looking good as always jur :wink: hurry up and get that paint back on :D :P
MAD_Adamski
Postby andyhardy on Thu Jan 06, 2005 2:38 am
Sweet idea with the sunroof - is it going to be one which slides back over the roof?
I was thinking about getting one from the SportKa (like in the advert with the cat! :lol: ).
I look forward to seeing it at FITP in May :)
Postby Jur on Thu Jan 06, 2005 7:05 am
adamski frst :looking good as always jur :wink: hurry up and get that paint back on :D :P
it's back on (-:
Jur
Postby Jur on Thu Jan 06, 2005 7:07 am
andyhardy :Sweet idea with the sunroof - is it going to be one which slides back over the roof?
It's a manual topslider.. First it tilts upwards.. then it slides back for about 25 cm
Jur
Postby Jur on Thu Jan 06, 2005 7:35 am
In the paintshop ..
all ready for the paintjob..
Rear
After the first layer of paint..
Then a second coat.. and 2 clearcoats, a speak preview thru the windows
First glanceses of the complete car in it's new colour
The auxilairy parts :-p
Boot, which i think held exceptionally well .. due to all the different materials used
Front bib (with the red glow of a vauxhaul corsa standing next to it)
rear bib
mirror hoods.. well .. ehhm all but the base plate :-p
And then .. my camera cut out (drained batteries)
so no pics of the bonnet, doors, base plates or bonnet hinges..
Jur
Postby reveller on Thu Jan 06, 2005 8:46 am
Awesome colour mate,can i just ask you what this polyester filler your using is?
Do you have to mix it with a hardner paste? I guess it may be different in your country but over here its called P38 but i always find the slightest thing can crack it, and the filler is a brownish colour where yours is white? I was wondering if its any different? :)
reveller
Postby Jur on Thu Jan 06, 2005 9:00 am
reveller :Awesome colour mate,can i just ask you what this polyester filler your using is?
Own mixture of filler (brownisch .. or white) and polyester fibres + hardner..
doesn't crack ... but you have to let it harden out for a while.. before you're gonna do the paintjob..
and don't have the heater on to much after the paintjob ..:-D due to different expansion coëffients..
Jur
Postby reveller on Thu Jan 06, 2005 11:18 am
Ah so its just basic bodyfiller and glass fibres mixed together?
reveller
Postby Jur on Thu Jan 06, 2005 12:50 pm
probably not basic.. (as far as i know my father in law)
but probably it's somethine like P38
Jur
Postby Brycey on Thu Jan 06, 2005 12:52 pm
Looks mint mate,cant wait to meet n greet you at FITP :D
Brycey
Postby dan_turner on Thu Jan 06, 2005 10:43 pm
looking good mate cant wait to start the same little project on my FRST !!
i wish i could do bodywork myself though! it would make life easier and be a little lighter on the wallet too.
dan_turner
Postby Richardson on Thu Jan 06, 2005 10:55 pm
That colour looks awesome mate, can't wait to see pics of it with all the doors etc back on, and of course, finished pics :lol:
Richardson
Postby MAD_Adamski on Thu Jan 13, 2005 1:27 pm
HOW YOU GETTING ON NOW JUR??? :D
MAD_Adamski
Postby Jur on Thu Jan 13, 2005 1:54 pm
adamski frst :HOW YOU GETTING ON NOW JUR??? :D
Well .. after some day's off (my gf had a party due to her birthday past weekend) we went back on .. had some minor setbacks again (i won't mention that at this time.. cause it will be fixed soon)
But hooked up the doors again with new doorpins (those will not be produced anymore .. so stock will shrink soon ) .. shopped around on the local scrappy .. bought some door-seals for around 3 pounds 50 (-: that came of a 2001 fiesta.. so near brand new..
sprayed some parts of the door-'locks'.. and screws.
mounted the leccy window mech on one door .. and will soon mount the chrome handle again .. and line up the doorlock..
then the other door will be done..
after that we will repaint the frontwheel-suspension .. and put the front of the car in the protecting black tar stuff (undercar bodyshutz)
Mount the koni's back on.. and go the the back.. repaint the rear suspension .. put some PU's in .. and mount the koni's
put the engine back in .. before that .. put the loom + dash back in ..
but not finished yet :-p
Jur
Postby purple_fiesta on Thu Jan 13, 2005 3:45 pm
purple, the best colour :D
6 Point Safety Devices Cage.
purple_fiesta
Postby Jur on Thu Jan 13, 2005 3:46 pm
purple_fiesta :purple, the best colour :D
sorry .. it's Deep Violet ..:-p
Jur
Postby purple_fiesta on Thu Jan 13, 2005 3:53 pm
:rolleyes: purple :P
purple_fiesta
Postby Jur on Thu Jan 13, 2005 3:59 pm
well .. the purple of the MK3,5 and MK4 fiesta's is a different colour then the deep-violet on mine :-D
both i like.
the first is metallic.. mine is a perlscent colour
Jur
Postby purple_fiesta on Thu Jan 13, 2005 4:10 pm
i think the actual name of the colour of mine is fleurie red or somthing
purple_fiesta
Postby Bridger on Thu Jan 13, 2005 7:12 pm
Used to love your car before but now :o :o :o
Gotta be one of my favourite fiestas of all time, top job mate :wink:
Cheers Bridger :D
Image << SOLD <<
Bridger
