My Zetec Turbo Build *Abandoned Project* : Member's Gallery - Page 2 | Fiesta Forums
Postby StreetDragster on Sat May 08, 2004 12:55 am
Thanks for the comments guys :D
Matt
StreetDragster
Postby Excursion on Sat May 08, 2004 11:13 am
Excursion :Nice work Matt, nice work. The mileage wasn't a guess :)
LOL I hadn't actually read that met, I just stare at the pics for ages :D You can usually tell from the varnish how many miles an engine has done.
Keep up the fantastic work!
Postby heeman10 on Sat May 08, 2004 3:58 pm
Excursion :You can usually tell from the varnish how many miles an engine has done.
You big gay Southerner :lol:
Postby JamieFRST on Sat May 08, 2004 6:27 pm
Excellent post :D Good reading and viewing!
JamieFRST
Keep It Tidy
Keep It Tidy
Postby DaveWRC on Fri May 21, 2004 12:41 am
hats off to you mate, im well impressed !!! Love to do this and use it in my next mk1 escort. Beyond me totally tho. Seems like a cost effective way to get real results.
DaveWRC
Your car: A
Postby SimonIce on Fri May 21, 2004 10:20 am
excellent progress. Looking forward to next update.
SimonIce
Postby MOONDUST FRST on Sun May 23, 2004 2:51 pm
Looking great matey :D
Just a couple of things to quiz you with, How are you fitting the the FRST water hose to the water pump as it hasnt been modded? Are you lowering the engine 10mm for clearence to stop the crossover hitting the bonnet? Unsure about this one but, Are you using an RS1800 sump so the zorst clears? i maybe wrong on that so might be worth asking other peeps :rolleyes:
Just tryin to help dude :lol:
MOONDUST FRST
Postby StreetDragster on Sun May 23, 2004 5:40 pm
Alright mate,
WaterPump Pipe
Measure this on thursday night and found out they were different diameters, not sure what i'm going to do about it just yet, probably some sort of hose reducer of something
Lowering the Engine
Yep, lowering it 12mm by using 12mm thick blocks of steel between the gearbox cradle and the chassis, and again at the suspension crossmember and chassis, i have 12mm longer high tensile M12 bolts to allow this
Sump
Using the 1800cc Zetec fiesta sump, dont think it came from an RS1800, but its defo from a 1800 zetec engined fiesta
If you have any tips please let me know :D
Matt
StreetDragster
Postby MOONDUST FRST on Mon May 24, 2004 4:32 pm
Ok mate was just tryin to point out probs earlier than later if ya get me :)
You can use a reducer but the best way by far is to get the cvh alloy outlet cut off and rewelded to the zetec one or if a local engineering firm can source a alloy hose tail to weld on that will do the less jubilee clips the better as less chance of leaks! Easier to do it now while the engines out :D
Let me know if ya come across any othe probs as i cant think of anymore at the mo :wink:
MOONDUST FRST
Postby StreetDragster on Mon May 24, 2004 4:43 pm
Great stuff, thanks for that, its a really good idea, i have a spare CVH water pump too which i can butcher, i'll speak to a local welder and let you (and everyone else know how i got on)
Matt
StreetDragster
Postby Project on Wed May 26, 2004 6:48 pm
No dramas, just use the Zetec bottom hose and t-piece the turbo water feed (which comes from the bottom of the rad) into the side entrance, then t-piece the turbo water return into the hot-crossover from the front of the thermostat housing. Stick with the Zetec water pump.
Make sure you use a proper FRST IAT sensor.
You should have a second breather port on the block as far away from the existing one as possible.
Fuel rail looks a work of art :D
Fan switch will need to be drilled and tapped into the hot side of the rad - I used a conical hole cutter to get it just undersize, then screwed the sensor in with a blob of silicone sealant. You can use a Mk6 Escort top hose instead if you'd rather as they also have the fan switch in them afaik.
Good luck with it all :)
Al
Project
fiftyoneCL
fiftyoneCL
Postby jdfiesta on Wed May 26, 2004 6:58 pm
what a fantastic thread! keep up the good work mate, best of luck with the engine.
I know what i'll be reading when mine's getting done.
JJ
Is that the best you can do?
jdfiesta
Your car: V70 T5
Postby StreetDragster on Wed May 26, 2004 7:18 pm
Another good idea here to add to my list, so far i have the choice of the welding of the cvh hose outlet onto the zetec water pump, getting a reducing silcone hose from the zetec water pump to a hose joiner then interfacing it with the FRST bottom hose, or the new zetec bottom hose tee piece setup. I'll have a think, thanks very much for your comments and tips they are all greatly recieved.
The one that is usually screwed into the RHS of the FRST inlet manifold?? Conical and black, sometimes screwed into an adaptor? If so, yep, sorted, screwed into the back of the etec inlet manifold, right next to my aftermarket ACT gauge sensor.
Ah, didn't know i needed two, though one 16mm diameter one in the crankcase would be enough. Might have to think about that one quite hard, and maybe try and drill and tap it in situ (on the stand) with a magnet to assist in collecting swarf
Thanks! Doesn't look quite as good now, had to be 'tweaked' with a small hammer to clear the ISCV, but onyl a little bit, i have an adjustable FPR so the change in fuel pressure can be compensated for
I actually have just got back from the local hydraulics shop, he welded me a M22 nut onto a 32mm hose joinerand then drilled the hole in the centre of the nut out, so i can screw the fan switch into that
Al
Thanks! I need as much luck as i can get!
Thanks to all for their comments :D
Matt
StreetDragster
Postby Sphinx on Wed May 26, 2004 7:52 pm
I would say 'brilliant read' but i havent really read much, just stared at the pretty pics :lol:
I'll read it l8er :lol:
Good work m8, keep it up!
Postby Project on Thu May 27, 2004 2:41 am
StreetDragster :
Err, afaik (but I may be wrong) always screwed into an adaptor - if it's not, it's almost certainly an n/a sensor :) Confirm with Excursion or Snake ;)
Al
Project
fiftyoneCL
fiftyoneCL
Postby StreetDragster on Thu May 27, 2004 7:58 am
Cool, thanks, mine is screwed into an adaptor so i think i have the right one, Phew! :)
Matt
StreetDragster
Postby Andy.B on Thu May 27, 2004 8:08 am
To check you have the right one it should have a normal 2 pin clip releace plug for the sensor. NOT a big fat round white plug which is the N/A one.
Andy.B
Postby StreetDragster on Thu May 27, 2004 11:13 am
Cool, in that case its the right one, thanks!
Matt
StreetDragster
Postby Rolls on Fri May 28, 2004 9:26 am
yeah, i had a 2i one when i first did my zvh, and it caused me no ned of problems matey!!
gald to hear that its all being sorted though!!
top stuff, can't wait to get going on mine once uni's finnished!!!
Xr2T
Rolls
Postby StreetDragster on Fri May 28, 2004 10:00 am
Hi Everyone,
Just spoken to Dell @ Kent Cams (Uk Distrubuters of ARP) and my bolts that i need are out for delivery today, so hopefully i should be able to get cracking next week and get some more updates for everyone. Also, got some Fiesta Frenzy cams and valve springs to go in so i need to strip the head down again and put them in, plus i need to take a bit out the head for the cam lobe clearance.
Next week i'm hopefully going to have following done so if you need any specific pictures let me know BEFORE i do it-
Second Breather port made up and fixed into the back of the crankcase
Have spacer plates made up for the cradle and crossmember
Fit the standard FRST blue injectors into the inlet manifold for running in purposes as suggested by MSD
Fit the conrod bolts
Sump on
Strip down, build up the head and fit to the block, torque down and time up
Cam cover on
Inlet manifold attached
Mount cross over pipe somehow, maybe have dump valve take off welded onto it
Measure up and order breather tank
Measure up and order hoses for breather tank, water system, and fuel system.
Ready the car to take the engine, fit guage senders, run cabling, tidy up engine bay prior to engine fitment, clean everything.
Busy week coming up!
Matt
StreetDragster
Postby jdfiesta on Tue Jun 01, 2004 6:48 am
sounds like you;ve got a very busy week man. good luck though mate, topic is making fantastic reading!
JJ
jdfiesta
Your car: V70 T5
Postby LiamMc on Tue Jun 01, 2004 9:57 am
Looking good mate. Can i ask...who deals in the Focus Central stuff like the throttle bodies and your vernier pulleys?
LiamMc
Postby StreetDragster on Tue Jun 01, 2004 10:00 am
I had to get them from Focus Central whilst i was over there with work mate, and then bring them back in my suitcase
Matt
StreetDragster
Postby StreetDragster on Tue Jun 01, 2004 7:16 pm
EDIT: Please visit http://www.streetdragster.com for guide
More to follow, probably tomorrow
Matt
Last edited by StreetDragster on Thu Apr 28, 2005 11:42 pm, edited 1 time in total.
StreetDragster
Postby dannyboy on Tue Jun 01, 2004 7:27 pm
Good work, bet you cant wait for it to be finished. Is that a Sytec cossie fuel pump in the 5th picture down, have you had any trouble wiring it up, ive just received mine but the connections are different, the only way around it is to hard wire, but dont know how safe that would be.
Dan :D
dannyboy
Postby StreetDragster on Tue Jun 01, 2004 7:59 pm
Hi Dan,
In the 5th pic down its a power boost valve with -6JIC connection to match my rail, but the car does have a standard escort cosworth fuel pump in, the connections were different so i soldered the wires together, and used heatshrink to seal the joints, haven't had any problems so far.
Damn right i cant wait for it to be finished! I awant my car back!! :)
Matt
StreetDragster
Postby Hartza on Tue Jun 01, 2004 9:22 pm
StreetDragster :Next i had a fan switch adaptor made up to hold the standard FRST fan switch in the water flow into the radiator top hose. This is a 32mm diamter hose joiner, with a M22x1.5 nut welded onto it, and then the hole in the centre drilled and filed out so the water can get to the sensing element.
One way is to use 92-> Escorts (With Zetec engine) top radiator hose, it has factory build place for fan switch. It is bit too long for Fiesta, but you can easily cut it.
It cost me 25€ in local Ford dealer
Hartza
Postby StreetDragster on Tue Jun 01, 2004 9:58 pm
Cheers Mate, thats a great thing to know if anyone is going to try and do another zetec turbo following this guide, if i was to do another one i'd probably use one of those hoses, its alot of pi$$ing about to grind the welds back and everything on my adaptor
Thanks again
Matt
StreetDragster
Postby StreetDragster on Wed Jun 02, 2004 1:35 pm
Getting There Slowly
Matt
StreetDragster
Postby MADMATT on Thu Jun 03, 2004 9:42 am
good stuff mate
glad to see it all coming together
this is such a good post definatly should be made a sticky when its done :D
matt
Nothin more nothin less
MADMATT
Postby Ian C70T5 on Thu Jun 03, 2004 10:58 am
You put on there you use the 1800cc water pump because the 2000cc one spins the other way, this is not quite right mate
The 1800cc one has a different angled port so it fits in the car better, it wont spin a different way.
I used the Mondeo Zetec Alternator, this is an 90amp one, perhaps it might be worth looking into using that mate as its much much better..
Build does look like its going well mate, well done
Ian C70T5
Das Ist Kapput
Das Ist Kapput
Postby StreetDragster on Thu Jun 03, 2004 2:28 pm
Cheers Ian, points noted and i'll dig out my Zetec alternator and see about fitting that
Matt
StreetDragster
Postby XR on Wed Jun 09, 2004 2:48 am
Matt,
Just been reading the Whole thread matt.
Good stuff mate.
XR
XR
Postby StreetDragster on Fri Jun 18, 2004 4:52 pm
Matt
StreetDragster
Postby StreetDragster on Sat Jun 19, 2004 8:09 pm
Todays Installment......
Matt
Last edited by StreetDragster on Thu Apr 28, 2005 11:43 pm, edited 1 time in total.
StreetDragster
