My Zetec Turbo Build *Abandoned Project*
sounds like a good guy to know
john
He is, but can he can be annoying when he starts to take over your garage with his stuff, got a nice dremel though!
hi John, welcome to the forums
Matt
- StreetDragster
http://www.StreetDragster.com has now been updated with a build guide
Please visit and let me know what you think, check out the rest of the site too!! Although its not all finished yet
Matt
Matt
- StreetDragster
StreetDragster :www.StreetDragster.com has now been updated with a build guide
Matt
I like the site Matt - the car features are a good read!
- andyhardy
I don't see a build guide Just a very short piece about your car with two pictures and writing about what you plan to do with it.
sphinx :Just been looking through your website and i'm loving the snakes names 'Zetec' and.......'Dave'
LOL Yep, the one that died was called Zoltan, then we had Zetec, so Dave was funny, then Zoltan died and now Zetec sound stoopid
Car wise, new gearbox, clutch, and quickshuft is in. Going to take some getting used too to drive it but the clutch is surprisingly smooth compared to the AP.
And the diff gives some, erm, interesting, driving habits
120miles to go
Matt
- StreetDragster
Interesting driving habits? Explain.
I can still see some mistakes Matt, I think you only skim-read what I sent you! Good build site though, pictures make allll the difference
Well, the clutch makes moving off a bit more digital than the AP, but without judder. The quickshift obviously makes gearchanges quicker, but also have to be more precise with the stick, and its a bit notchy, but in a good way. The diff appears to make the car pull a bit once a bit of power is applied. I'll only be able to test it properly though once its on boost.
Just needs a bit of getting used too. Taking the car out for a long drive tomorrow so i'll give a better report then.
All your corrections where put in i think
Matt
- StreetDragster
StreetDragster :All your corrections where put in i think
Was that a joke? "Where" instead of "were" was one of the things I changed a few times, so I wonder if you're just being ironic saying that I'm just a nit-picking git, I'm sure it's fine for the non-pedantic folk reading your site!
Nope, i definately altered it, i'll check it against the copy i have a work to see were the differences are, i may have uploaded the wrong text
- StreetDragster
- StreetDragster
Looking good
Are you not worried that people will see the Area Six logo and think it's one of Ian's engines? I'd have got a "Streetdragster Race Engines" or something on there, blow your own trumpet a bit.
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
- mrviper
The lights are the cleanest bits on it!!!
Looking good
Cheeky bugger, you know where it is when your at a loose end, i have bucket and a sponge
Looking good
Cheers Ade, Narr, not worried, i'd rather be wearing a Ian Howel banner than one of my own, shows a level of pedigree
im impressed my tht mate
Cheers Mate
so what sort of power are you expecting after mapping then
No idea mate, as long as it drives great with a healthy bit of power and i'll be happy Got an RR session on saturday though so i'll find out what it actually has then, 300bhp woul dbe nice
Matt
- StreetDragster
Sundissential, didn't know you were into that scene Matt
Have been for a long time mate Not quite as much into it now as i would like to be, but i love a bit of hard house
how did the mapping go mate
Well, as my friend John said yesturday, 'These things are sent to test us'
Basically, dropped the car off in the morning, i've had no problems with it at all, but whilst i was stood there chatting to Kenny about its setup and stuff it started a little leak from its bottom rad water hose.
Great, so luckily Kenny had some pipe the right size and that was repaired and we left.
Then, at 15:45 i got a phone call about Kenny having problems setting the base idle as my Zetec throttle body has no idle adjustment screw, its done via management, but the FRST management (Which they are live mapping) requires one. So it was time for emergency improvisation.
Luckily, next door to MSD is a fabricators called 'Simply Steel' and the bloke there is a god send. What Kenny/Me/John/Mike worked out, is that the insert from a bleed valve could be used as base idle adjustment, if the boss on the top of the TB was threaded and a hole into the turbo side of the throttle flap drilled.
Then a hole from the engine side of the throttle flap could be drilled to join the two holes together, and the bleed valve thing would regulate the air flow, and thus, the base idle speed.
Which was all great, but the holes weren't quite drilled out enough so i'm going back this morning to eremove the TB and get the holes drilled out further.
A massive thanks so far to MSD and Simply Steel, they were both there until 18:30 last night solving this problem and they didn't have to.
And they haven't even started to put the car through its paces yet! Worried!
Lets See What Today Brings!
Matt
- StreetDragster
i thought there was going to be some bad news then but building a bleed screw is far from the end of the world
glad to see someone using eec-iv and fingers crossed it being mapped properly
you've got me thinking now weather things like ISC could be added by adding code to to the eec-iv
- FezzR
- God Damn Lazy
Sounds like a novel way to work around things Good luck with today, you know the car has a lot of potential
Just finished a new nightmare.
Basically, whoever had my turbo before me had access problems and rotated the actuator on the turbo housing. This slipped through the net when i installed the turbo and only showed up today when kenny couldn't get stable boost. So i've been working from 18:00 until now to fix it.
Basically, as the actuator got rotated, the radiator needed moving forward, so the slam panel needed modifying, then the intercooler needed moving forward, then the bumper needed recutting.
Absolute total ballache, and i have now lost my stealthy look as i have had to remove the fog/driving lamps for intercooler clearance, and the bumper cut isn't the tidiest, it can be tidied up later but may be a mess for FITp, if the car makes it down there!!
If they have any problems mapping it tomorrow then its not going
Fingers and toes crossed this time
Matt
Matt
- StreetDragster
- mike_wall15
Car: 2002 BMW M3
Yep, the major problem is time really, it could be tidied up but i won't have time before FITP, so if its tatty at the show, no cheeky comments!
Matt
Matt
- StreetDragster
Sorry to hear about all the problems Matt - I think everyone who's done a conversion like this or less of one (like mine) hits loads of problems like this that never even hit the radar when planning the project out in the first place!
You can join me with having a scruffy looking turbo at FITP - I doubt mine's gonna even get a clean at this rate!
- andyhardy
