Mysterious oil leak
Mysterious oil leak
Postby Project_XR2i_Trackcar on Sat Apr 13, 2013 8:26 pm
My 2i has developed a leak. It's been leaking since summer last year (car is in storage, fecking huge heated hanger). I've moved it around the hanger about 3 times and each time I end up with an oil patch under the near side hub.
I've never had a leak until about 2 trackdays after changing the gearbox. I suspect it's coming from this as I've never had a leak from the engine before. The sump is good, with a good seal. The gearbox is a new BC stage 2+ with quaife and my drive shafts are new reconditioned.
I've been working on the car today. I haven't touched it for about 4 months, the patch is massive.
Couple of factors:
Patch always starts under the hub.
No signs of a drip.
Really can't see much of a run from anywhere.
Drive shaft inner cv and boot was slightly oily, very light though.
The car was level and I took the fill plug out. Oil flowed out. There's plenty in there, maybe too much if anything. Now settled/level.
Engine oil level is fine.
My thoughts were its coming from the diff, via the drive shaft.
I've taken the drive shaft out. The oil seal looks fine.
Any suggestions before I put it all back together.
Renault Sport Megane 250 Cup
Ford Fiesta XR2i 2.0 trackcar
Your car: Xr2i
Re: Mysterious oil leak
Postby FRSJON on Sat Apr 13, 2013 8:57 pm
well the first thing id check would be is it engine/gearbox oil..brake fluid ..if the cars not moved and that patch has appeared then surely it cant be coming from too many areas :-?
FRSJON
Postby Project_XR2i_Trackcar on Sat Apr 13, 2013 9:16 pm
Brake fluid.
Fcuk.
I never thought to check. What a bellend :lol:
Ill check tomorrow.
Gearbox and engine oil were fine.
Your car: Xr2i
Postby snake on Sat Apr 13, 2013 10:13 pm
Sniff the floor lol, gearbox oil smells and so does brake fluid. Only needs a slight donk on the driveshaft seals for them to leak, or if they have been pushed into the box too far they can leak.
snake
Trainee Burger Flipper
Your car: ford
Postby Project_XR2i_Trackcar on Thu Apr 18, 2013 9:25 pm
It isnt the brake fluid. Checked the level and its fine. The drive shaft has been out for 5 days now, the diff hole is bunged up with a rag. The damper is also out so the hub/disc is resting on a bubble wrapped wheel. No signs of leakage on the bubble wrap.
I'm inclined to think it was leaking at the CV and running along the shaft until it dripped off, which happened to be at the hub. Possibly knocked or ill fitted (by myself, I hasten to add).
Will pop it back in later, and see what happens.
Your car: Xr2i
Postby FRSJON on Thu Apr 18, 2013 9:37 pm
Project_XR2i_Trackcar :It isnt the brake fluid. Checked the level and its fine. The drive shaft has been out for 5 days now, the diff hole is bunged up with a rag. The damper is also out so the hub/disc is resting on a bubble wrapped wheel. No signs of leakage on the bubble wrap.
id be surprised if it would make it past a cv gaitor without the car being used as each corrugation of the gaitor would act as a drip....are all the cars in that garage yours? not a mate messing with your mind ? :lol:
FRSJON
Postby Project_XR2i_Trackcar on Thu Apr 18, 2013 9:42 pm
My thoughts too. Hence why I'm stumped.
There's a load of oily gunk on the lower arm. It could be collecting and moving down that, to the hub/ball joint.
No to the pranks. The other motors belong to lads away on Ops etc. My car has my rank, name and contact details on the dash. I'm a WO1 so I doubt many would have the balls to play that kind of a prank on me.
Your car: Xr2i
Postby jayrs on Sun Apr 21, 2013 6:53 pm
My first thought when reading the first post was, what is leaking, oil, gearbox oil etc,
As you have stated the brake fluid is ok my thoughts turned to gear box oil seeping out the seal onto the lower arm and running down, then read you found gunk on the lower arm, so I reckon that's the problem.
What's does the leak smell of? You know gearbox oil when you smell it, it's one of the mankest things I have smelt, it like the devils piss I reckon it's so bad :lol:
Postby Project_XR2i_Trackcar on Sun Apr 21, 2013 7:36 pm
Smells like oil.
I'm aware that gearbox oil has a distinctive smell but its new oil, ie 1k miles max.
Gearbox appeared over filled. Sweating???
Your car: Xr2i
Postby jayrs on Sun Apr 21, 2013 8:01 pm
Even new gearbox oil stinks, gets ya right at the back of the throat, taste like crap too (don't ask lol)
When you say smells like oil your need to be a bit clearer fella, you mean engine oil?
Postby Project_XR2i_Trackcar on Sun Apr 21, 2013 8:14 pm
Dunno, will sniff tomorrow. Will sniff oil direct from diff too.
Your car: Xr2i
Postby FRSJON on Sun Apr 21, 2013 8:28 pm
what about the breather pipe on the end of the gear box ?
FRSJON
Postby Project_XR2i_Trackcar on Sun Apr 21, 2013 8:47 pm
Not checked. Ill check :lol:
Your car: Xr2i
