Need some vital advice on my FRST (PLEASE)
7 posts • Page 1 of 1
I have recently fitted a fiesta rs turbo engine into my xr2i its running a T3 on standard boost standard injectors standard ofab ecu most things on it are standard and i am having fueling problems.
it will tick over sweat as a nut then a split second after you open the throttle the engine bogs down and pops some times. i did initialy try a T2 but that was the same i have come to the conclusion that it is under fuelling.
i am currently an apprentice mechanic my self and have checked (as far as i know) everything
any suggestions at all will be welcome
thanks
thanks
Onto my 6th MK3 Fiesta and think this ones a keeper
- TarmacTerrorist
Mine did something similar shortly after I got it and that turned out to be the Throttle Position Switch. Did you carry across the full FRST engine management?
no just ecu loom and map sensor is there a difference between the throttle position sensors from the 2i to the turbo??
- TarmacTerrorist
no, the TPS is the same.
could be a map sensor fault though.
what inlet manifold are you using? it might have a 2i air temp sensor in it
yes it has the 2i air temp sensor. woud that make a difference???
- TarmacTerrorist
Yes it will make a big difference as the air(boost) being passed over it in a turbo application will be a lot higher
