Need speed guage little cog thingy
Postby MadcatCraig on Fri Jul 06, 2001 12:24 am
I need the little cog thingy from a fester that came with 15" wheels mine originally had 13"s and so me speedo is out. Ford want an arm and a leg to put this f00ker right and i was told i just need a special cog to go on side of gearbox.
Im not mechanically minded someone put me straight.
MadcatCraig
BANNED SELLER
Postby JJ on Fri Jul 06, 2001 12:22 pm
Ok, no Mk3 Fiesta ever came with 15" wheels as standard. What size tyres are you running on those 15s? They should be 195/45x15s. If they're 195/50x15s your speedo will under-read due to the larger diameter of the 195/50 profile tyre. Fit the right tyres and your speedo will be accurate again!
:devil:
JJ
