New Castrol RS Oil
20 posts • Page 1 of 1
Now that the consistency of this oil has changed to 0W-40, is it still save for use in my Fezza RS Turbo?
- DuncanFRST
Use Mobil 1 Motorsport <IMG SRC="http://cgi.deep6.force9.co.uk/ubb/smilies/smile.gif"><br><br><br> <IMG SRC="http://cgi.deep6.force9.co.uk/ubb/smilies/smile.gif"> <br><br> <IMG SRC="http://cgi.deep6.force9.co.uk/ubb/smilies/smokin.gif"><br><br> <IMG SRC="http://cgi.deep6.force9.co.uk/ubb/smilies/biggrin.gif"><br>
- Andrew Malcolm
HEY RS BOY,IT IS PERFECTLY SAFE FOR YOU TO USE CASTROL RS 0W-40 IN YOUR FIESTA IN MY<br>RS1800 I USE IT FULLY SYNTHETIC PLUS <br>SLICK 50 FULLY SYNTHETIC USED BOTH TOGETHER<br>THEY WILL PRETECT YOUR ENGINE TO MAX ABILITY<br>THE BEST COMBINATION YOU WILL EVER FIND AND<br>AND IT DOESNT CAUSE LEEKS OR ANYTHING LIKE<br>THAT,REMEMBER ITS ALL ABOUT VESCOSITY,AND NO<br>DISRESPECT INTENDED TO OTHER OPINIONS ON HERE<br>0W-40 IS NOT TO THIN,IT JUST MEANS ON START-UP ITS GET TO ALL PARTS FASTER THAN OTHER OILS WHICH IS WHAT YOU WANT
- HAMMER26
Right - Mr Hammer your engine is a totally different design to the CVH- Zetecs are very oil tight in service and are designed to run with the thinner oils.<br><br>CVH engines however are not - ESPECIALLY ones with a turbocharger. Thin Oil - 0w-30 etc has been proven to do damage to the turbo unit and is not reccomended to be used. The oil film breaks down inside the hot bearing case and causes damage.<br><br>Your choice, but Id stick to 10-40 or 10-60
Wright mr.2000_16v_Turbo,all due respect to your opinion,let me explain something,i work<br>at fords research plant Essex and we have tested many type's of engines cvh zetecs etc<br>with different type's of oil and additives<br>and even in cvh engines with turbo's you can use the thinner oil's,the only reason turbo's<br>get damaged is because of bad maintanance by<br>the owners lack of understanding of turbo's.<br>There are standard turbo's and competition<br>turbo's,if you want to race everyone on the road stick a competition turbo on(although that may not be road legal),and the standard turbo's on most of the earlier ford's are just standard there not really meant for thrashing,and the only reason we used to get<br>oil film break down inside the bearing case<br>was because of thicker oils.Fully synthetic oils like 0w-40 have a greater vescosity which means they have a greater temperature<br>range and you wont get film breakdown<br>0w-40 is ok to use,but stick to what you feel<br>comfortable with
- HAMMER26
I think the reason that so many people recomend castrol RS and Mobil 1 motorsport and not mobil 1 0w40 is because Fiesta and some Escort Turbo's smoke on thin oil's, I've read untold posts on this subject from this board and RSOC board and this seems to be common!?<br>I don't know about the tech crap though!!<br>Paul R
- Paul R
Mr Hammer I work for the flow dynamics section of Garret AirResearch UK.<br><br>We have tested many oils in our turbocharger units and tests consistantly showed film breakdown at high temperatures. The thinnest oil we reccomend is 5w-30.<br><br>Im interested to hear when you tested a CVH engine with 0w-30 oil - If my memory serves me correct out contract with Ford to supply TO2 units ended in april 1992 (fiesta turbo-CVH). At that time 0w-30 oil was not commercially available - so why waste funds testing such an oil??<br><br>Viscosity has little effect on temperature range - as most industrial oils have to be very thick yet retain a very high operating range. The bonding structure of the oil is the governing factor - either synthetic based compounds or more common mineral based.<br><br>Secondly what is this 'competition' turbo you speak of? All units we supply to motorsport are based on standard models - only modifications are ceramic roller cartidge bearings instead of standard 270. Compressor blades are optimised for the particlar engine to optimise the boost island for the particular user.
Mr 2000-16v-turbo,<br>At work we have tested all sort's of engines,<br>and thousands of different components for<br>engines,and many different type's of oil's even before these oil's reach general sale,<br>i have even tested several concept car's and <br>driven them home to give a full annalysis on <br>the concept car.The first concept car i had the pleasure of testing was what was to be the XR2i 1600 ,but the concept car was the MK3 body shell with a 2 litre twin turbo charged engine with competition gearbox and it was four wheel drive and it was so powerfull it would have cost to much money to<br>produce for general sale,it was more powerfull and faster than the Escort Cosworth<br>i reached a speed of 156mph in it and it still had more room,but being a concept car it was chopped up into little pieces so know one could copy it.
- HAMMER26
Didn't expect to start an argument!<br><br>Why did Castol change the consistency of their oil then? Anyone know?
- DuncanFRST
At precisely 13:13 and 13 seconds on Friday 13th October... spooky eh? <br><br>erm... no idea really, use Mobil Motorsport!! <IMG SRC="http://cgi.deep6.force9.co.uk/ubb/smilies/smile.gif">
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
