NEW ON HERE? ADVICE PLEASE?
12 posts • Page 1 of 1
Hey i Have N reg Mk3.5 Fiesta si. i have a 1.1k budget to get this car resonabily fast and looking ok!! could i have some ideas please as ive only had this fiesta like a week and dont really know whats out there for this car.
the car needs a respray but i can live with out and neeeds a new drivers rear quater.
ive heard these cars are restricted? how do i remove this?
- r3d_fac3d
Re: NEW ON HERE? ADVICE PLEASE?
nah not restricted mate, is it the 1.6? if so you could drop the 2l mondeo engine and ecu with your loom and gear box for 130-140 bhp and have enough for a cheep repair
- dangerousdave
yea it is the 1.6, a ecu in? is that possible with my car? im sure this is carb :S efi???
- r3d_fac3d
the mk 3 1.6s was carb the old xr2 engines that needed using up but yours is a mk3.5 1.6si injection model mate its a simple swap really if you know a likle about it its pretty mch a straight forward swap!? a few lads on here have done it
- dangerousdave
oh ok nice.... btw im not sure mines mk3.5 lol how do i know? also what mk mondeo engine i need?
- r3d_fac3d
mk1 or 2 mondeo if its n reg it will be it has smaller mirrors and a flap on the petrol cap mate
EDIT: id go for mk 2 if possible as they have under piston oil jet !!
- dangerousdave
ok is it just the engine gearbox n ecu needed? all do i need the whole lump incl drive shafts??
ignore tht lol u alredy said but what about the cooling sys??
- r3d_fac3d
no mate use the si gearbox and drive shaft i do belive the cluch and flywheel on the 2l mondeo fits the si box straight up i would test fit out the car tho just in case if not you just put them off the si engine onto the 2l block you may need to open the bolts up on the flywheel but im sure its only the cvh's this is done on. as for the ecu it must be the DESK DEWY or DEEP ecu from the mondeo then its all plug and play mate
would ask someone who has actually done this but im 99% sure this is correct mate
- dangerousdave
ty mate!!! will try this do i not need a better cooling sys?
- r3d_fac3d
yours should be good mate, whip it in see how far you get....( if its not your daily driver)
- dangerousdave
r3d_fac3d how old are you
- Dazza
just turned 20 y?
- r3d_fac3d
