newbie with 2.1 16v turbo q's
2 posts • Page 1 of 1
i was advised to use frst management on my zetec turbo which will be fitted to my series one.is it easy to fit?does it use the standard zetec crank pickup with a frst flywheel?i need an OFAB ecu apparently and i can use a 2i wiring loom with a few wire changes?does the ecu run the fuel pump and can i get a wiring diagram anywhere for it?sorry lots of questions but my cvh is about to go bang and zetec is the way forward any help would be greatly appreciated.
cheers kris
cheers kris
- kristech
