Nick's ST : Member's Gallery - Page 8 | Fiesta Forums
Nick's ST
Re: Nick's ST
Postby mrorange2 on Mon Nov 28, 2011 4:52 pm
Out of interest how did you find the P Zero Neros? Also how did the PAS cope with the track day?
I'll have to save for some eibach i think then!! I was also thinking of getting one of them sony headunits but cant really justify they money when it dont do to much more than the standard one. Plus i think they look a little pants as well lol
2014 Fiesta ST3 & Mk6 Fez ST
mrorange2
Re: Nick's ST
Postby trecoll on Mon Nov 28, 2011 4:55 pm
I maybe wrong, but I thought Alpine had an interface to connect to both steering wheel controls and the screen?
trecoll
Nick's ST
Postby dontpannic on Mon Nov 28, 2011 5:49 pm
Unfortunately not the screen. Steering controls, yep, but the problem I have is that because the hole in the dash is bigger than double din it all looks a bit half arsed when you have to get fascia adapters etc. I'll probably warm to the idea at some point!
Tim - the P Zeros were a bit more slippery in the dry but that could have been that they were quite worn - in the wet it felt skittish and unstable. The T1R's have a lot more grip in the dry and in the wet, can't fault them really. The main difference is road noise though, the T1R's are so much quieter than the pirellis.
The PAS was whining a bit after the first track day at Lydden, but the fluid was fine, at Combe, there wasn't much of a whine at all and the fluid was still OK, but then they were only short sessions. I'd imagine a full day would require a fluid change though!
Defo put a little aside for the Eibachs - I can't describe how much of a difference it makes to the handling of it, it just sticks really well, I have full confidence in the corners.
Sent from  iPhone.
Re: Nick's ST
Postby mrorange2 on Mon Nov 28, 2011 5:54 pm
I currently have P Zeros on and i hate them just no grip at all i will take a look at some T1r me thinks then. Have you been tempted to add a PAS rad in? Mine is terrible soon as i give it some beans it whines like a lil baby think i need to change the fluid first.
Cheers for the advice mate will deffo move the eibach up my list now!
mrorange2
Re: Nick's ST
Postby jonyb4 on Mon Nov 28, 2011 6:00 pm
that cd pictured is the top o range one, apart from the 6 disc change version, broke one of them when I was working for halfords
Re: Nick's ST
Postby Minstral on Mon Nov 28, 2011 7:35 pm
jonyb4 :that cd pictured is the top o range one, apart from the 6 disc change version, broke one of them when I was working for halfords
yeah thats not the standard one nick my mu has that in hers and its that last limited edition model of the mk6 with all the extra's
a good unit
Minstral
Your car: *
Nick's ST
Postby dontpannic on Mon Nov 28, 2011 10:01 pm
Minstral :
a good unit
It was standard from 2008 onwards for the last runs, optional before that (came with the tech pack). Also came standard on the Zetec Blue.
I've not had any need to put the PAS rad in just yet, after the fluid boiled the first time then I flushed it out and refilled its been fine since although the pump has been noisy at times lol. I just let it cool down a bit between long blasts lol
Sent from  iPhone.
Re: Nick's ST
Postby jonyb4 on Tue Nov 29, 2011 2:25 am
how come they dont have a pas rad standard?
thinking about it though the fluid cant get that hot can it?
Re: Nick's ST
Postby andymac on Tue Nov 29, 2011 2:57 am
Sure it can, it's under a lot of pressure in use (pressure == energy == heat) and the system doesn't rely on a pressurised system to stop it boiling up (as your coolant system does).
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Re: Nick's ST
Postby mrorange2 on Tue Nov 29, 2011 9:39 am
jonyb4 :how come they dont have a pas rad standard?
As said yes it does its a design flaw really on the st no PAS rad and its also in a very bad position with pipes running close to engine so soo as you give it some beans it tends to boil the fluid.
mrorange2
Nick's ST
Postby dontpannic on Sun Feb 05, 2012 12:32 pm
Clio rear wiper:
Also re routed my cold air feed through and replaced the passenger fog. No pics yet of that.
Also in the process of wiring footwell courtesy lights:
Re: Nick's ST
Postby RS rob on Sun Feb 05, 2012 1:31 pm
mrorange2 :Out of interest how did you find the P Zero Neros? Also how did the PAS cope with the track day?
i've got the sony option
the fiesta's which come with the sony headunit
come with upgraded speakers and bluetooth connected normally
the sound difference with the sony option is alot better quality, warmer sound with good bass and mid-range
the g/f has the standard 6000 radio in her new grey z-s mk6.5
it sounds very flat in comparison and is on the list of things to do
i'm personally deciding wether to go for the ford accessory/pioneer upgrade on the speakers all-round
bit of a gamble wether they will be better or not
RS rob
Re: Nick's ST
Postby jonyb4 on Sun Feb 05, 2012 1:42 pm
love the little touches!
where did you get the light from? like to do that myself
Re: Nick's ST
Postby RS rob on Sun Feb 05, 2012 1:43 pm
looks like a boot lamp from a mk3 or mk5 to me,
fairly cheap and still available in fords
RS rob
Nick's ST
Postby dontpannic on Sun Feb 05, 2012 2:15 pm
RS rob :looks like a boot lamp from a mk3 or mk5 to me,
same part numbers. Boot lights for foci, fiestas, mondeo, fusion etc :)
Re: Nick's ST
Postby hb69 on Sun Feb 05, 2012 5:39 pm
Clio rear wiper ftw
hb69
Your car: Fiesta 1.1 LX
Re: Nick's ST
Postby - Danny Boy - on Sun Feb 05, 2012 6:00 pm
Why didnt ford come with a clio rear wiper as standard? Looks perfect
- Danny Boy -
Your car: Fiesta Si 2.0
Re: Nick's ST
Postby hb69 on Sun Feb 05, 2012 6:31 pm
axle spacers next?
hb69
Nick's ST
Postby dontpannic on Sun Feb 05, 2012 6:48 pm
hb69 :axle spacers next?
milltek first :)
hb69 :Clio rear wiper ftw
Took me fudgekin ages to get it off the clio in the scrappy until I had a brainwave lol. Well worth it though!
Re: Nick's ST
Postby dontpannic on Mon Feb 06, 2012 9:10 am
RS rob :the sound difference with the sony option is alot better quality, warmer sound with good bass and mid-range
I think that's more down to the speakers themselves rather than the stereo for the most part - my mate has a Zetec Blue with the Sony stereo with the upgraded speakers (I have the 6000CD and upgraded speakers) and there's not a lot in it.
Re: Nick's ST
Postby trecoll on Mon Feb 06, 2012 9:22 am
dontpannic :until I had a brainwave lol
Undo the nut first? :P :lol:
Looks good, mine came with something OK looking from the factory though :Q :bonkers:
trecoll
Re: Nick's ST
Postby Dave G fsi on Mon Feb 06, 2012 2:56 pm
Looking good :aviator:
Dave G fsi
Your car: Mk1 FRS and FRST
Re: Nick's ST
Postby dontpannic on Sun Feb 12, 2012 12:01 am
Properly crap photos, but you can just about see what's going on here.
They light up perfectly, fading in and out with the interior light, no wiring visible and all joints properly soldered with heat shrink :)
Plans for tomorrow - wash it:
and properly sort out the cold air feed. Its currently wedged in with some insulating tape to keep it in place but I intend to get a slightly larger diameter pipe to hook up properly.
Re: Nick's ST
Postby Dave G fsi on Sun Feb 12, 2012 12:24 am
Interior lights look good mate :aviator:
Car looks, erm, filthy :lol:
Dave G fsi
Re: Nick's ST
Postby jonyb4 on Sun Feb 12, 2012 1:51 am
as above mate good stuff!
was worried they sat a bit too low down but your chuffed with them :)
Re: Nick's ST
Postby Minstral on Sun Feb 12, 2012 8:48 am
those are indeed rubbish photo's
Minstral
Your car: *
Re: Nick's ST
Postby Smo on Sun Feb 12, 2012 2:03 pm
Can't believe I parked behind that filthy state yesterday...
Smo
Nick's ST
Postby dontpannic on Sun Feb 12, 2012 7:22 pm
You love it, Si :P
Some better pics from todays progress
Applied ST150 decals...
Tidied up wiring for the footwell lights and got some better photos...
And sorted out as best I can the cold air feed fog light...
Re: Nick's ST
Postby Dave G fsi on Sun Feb 12, 2012 7:24 pm
Looking really good there mate :aviator:
Dave G fsi
Re: Nick's ST
Postby jonyb4 on Sun Feb 12, 2012 10:36 pm
not really a fan of them nor the ones they use on ST170's
but its looking low on the back!
shes looking fine mate
Re: Nick's ST
Postby Ratspeed on Mon Feb 13, 2012 8:37 pm
Liking that mate, especially the intake :Q
Ratspeed
Nick's ST
Postby dontpannic on Tue Feb 14, 2012 12:14 am
Cheers guys. Will get some decent clean photos up at some point lol :)
Re: Nick's ST
Postby EUFez on Wed Feb 22, 2012 4:44 pm
Get rid of the stickers and ST grille badge and slam it on Cossies! :devil:
EUFez
Re: Nick's ST
Postby dontpannic on Wed Feb 22, 2012 4:54 pm
EUFez :Get rid of the stickers and ST grille badge and slam it on Cossies! :devil:
Undo my personal touches and make it impractical and the same as everyone elses? :lol:
Nah, I'll pass :lol:
Re: Nick's ST
Postby Minstral on Wed Feb 22, 2012 5:04 pm
best wheels on a mk6 imo cossie's. looks epic
Minstral
Your car: *
