Nick's ST : Member's Gallery - Page 13 | Fiesta Forums
Nick's ST
Re: Nick's ST
Postby Smo on Sun Aug 19, 2012 9:17 am
You beat me, Nick, but then I still had a full interior and a lot less power :bonkers:
Smo
Re: Nick's ST
Postby dontpannic on Fri Aug 24, 2012 4:52 pm
Another thousand mile weekend passed without serious incident. I did slip in the flooded wet roads and had a small encounter with a hedge, but no damage.
A couple of photos from the weekend, along with the second driver in his Golf GTI.
Re: Nick's ST
Postby Michael! on Fri Aug 24, 2012 4:53 pm
loe those golfs, and as per; your pictures.
how come you dont ha :) e centre caps?
ft-com-members-map-vt190192/
Michael!
Re: Nick's ST
Postby dontpannic on Fri Aug 24, 2012 5:21 pm
I was bound to lose them over the weekend so took them off to be on the safe side :)
Re: Nick's ST
Postby MK2 Jamie on Fri Aug 24, 2012 7:04 pm
Car's dirty, sort it out Burman.
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Nick's ST
Postby dontpannic on Sun Aug 26, 2012 8:54 pm
Had a rolling road day today with Kent Modified, Bark Mennett came along too with some very impressive power figures!
I made 156.4BHP. Up from a potential standard of 147, however, standard ST's have been tested as low as 140, due to the standard map. They over fuel loads from the factory which saps the power higher up the rev range. Peak power is at 5500rpm at which point it flattens off. The AFR is 10:1 which for peak performance needs to be closer to 13:1. The operator reckons that with a Bluefin map that should even out the AFR and bring a bit more power, combined with the current mods around 10bhp extra.
Still, I'm very pleased with the result, for an exhaust (with the standard restrictive flexi) and an air filter a 9.6bhp increase (perhaps slightly more) over standard isn't bad going really!
It also means that me keeping on the power after 5500rpm in its current state is pointless lol.
Re: Nick's ST
Postby hb69 on Sun Aug 26, 2012 9:12 pm
Shame i couldnt come too, after the trying to work out a route etc i ended up working anyway :lol:
Remember the peak rpm for combe. Bluefin are pretty cheap now, compared to how much they used to be anyway. They were £200 a month ago. They can also change the map for the mods you have, worth knowing.
hb69
Your car: Fiesta 1.1 LX
Re: Nick's ST
Postby MB7201 on Sun Aug 26, 2012 10:32 pm
It was making some nice noises on gear changes. It would be interesting to see what a manifold does :D
MB7201
Your car: Fiesta lx
Re: Nick's ST
Postby dontpannic on Sun Aug 26, 2012 10:37 pm
Hehe, can't wait to find out :lol:
Here's a vid - Mark, I'll post yours in your thread :)
http://www.youtube.com/watch?v=SXXvNVce ... r_embedded
Re: Nick's ST
Postby - Danny Boy - on Sun Aug 26, 2012 11:41 pm
Nice little power increase with just an exhaust! Bluefin mapping would be good too. Maybe it's something worth saving up for :D
- Danny Boy -
Your car: Fiesta Si 2.0
Re: Nick's ST
Postby jonyb4 on Mon Aug 27, 2012 6:02 am
thats cracking nick! these are very odd cars, some over produce by this much some under produce, very ood indeed
least you know you got a good one!
oh and FYI a perfect air fuel ratio is 14 parts air to 1 part fuel ;) (but its virtually unachievable without laboratory conditions)
Re: Nick's ST
Postby Smo on Mon Aug 27, 2012 9:19 am
I disagree, Nick - it's not pointless revving beyond 5.5k because you don't want to keep dropping too far below your peak power when you change up, you want to be revving high enough that your next gear is still well into the power band or you'll just bog down. I guarantee if you drove your 0-60 without going above 5.5k you would probably have struggled to get anything below 9s :)
And Jony, 14:1 would probably be far too lean for ultimate power - roughly 13:1 is probably more ideal in a naturally aspirated car, but then there are so many factors to take into consideration! It's not difficult to achieve any particular AFR, the problem is cylinder temperatures and resisting knock while trying to keep ideal ignition timing. The cylinder's mixing efficiency, ability to resist knock, compression ratio and flow will all affect this!
Smo
Re: Nick's ST
Postby - Danny Boy - on Mon Aug 27, 2012 10:28 am
The 'perfect' mixture 14.7 to 1. Anything less than that is considered a rich mixture and anything more is consisdered a lean one. But of course you cannot achieve that in the real world and that's really only scientific values with perfect conditions. But as Smo and Nick said, the more ideal mixture for an NA car is 13:1. Most cars will run at that, especially at higher RPM's to make the car as reliable as possible.
- Danny Boy -
Re: Nick's ST
Postby jonyb4 on Mon Aug 27, 2012 12:22 pm
perfect as in no waste product such as carbon in the exhaust
Re: Nick's ST
Postby hb69 on Mon Aug 27, 2012 6:25 pm
stoichiometric....yeah i know stuff :oooh:
hb69
Nick's ST
Postby dontpannic on Mon Aug 27, 2012 10:03 pm
hb69 :stoichiometric....yeah i know stuff :oooh:
Woah! Who knew?
Re: Nick's ST
Postby filtra on Tue Aug 28, 2012 1:16 am
Why do these engines run so rich then? Is it to account for s**t fuel or something?
Looking good as always Nick!
Ex Fiesta RS Turbo owner :(
filtra
Re: Nick's ST
Postby dontpannic on Tue Aug 28, 2012 8:53 am
As far as I'm aware they've been restricted so much to keep them insurance friendly from new, hence why things like a cone filter and flexi pipe can release 10-15bhp straight out of the box.
If it turns out that installing a less restrictive manifold/flexi pipe, 60mm throttle body, and bluefin can affect the AFR that alone could get it up to 165bhp!
With a new inlet and cams, with a decent remap it could see anything from 180-190 without turbo/super charging.
That's how complicated and restrictive the standard air intake is.
Re: Nick's ST
Postby jonyb4 on Tue Aug 28, 2012 3:34 pm
the piece of s**t, throw it in the bin :D
i want one of these!
Re: Nick's ST
Postby Excursion on Tue Aug 28, 2012 3:34 pm
Good result Nick 8)
Re: Nick's ST
Postby dontpannic on Mon Sep 03, 2012 11:45 am
Various little bits and pieces to update, mainly videos tbh! :lol:
First up, went to Trax this weekend, and decided to try the 0-60 again. Was up against another ST and we got identical times of 7.55 seconds :lol:
Inside video:
Outside video: (thanks Pricey :) )
Also, from Ford Fair, a randomer videoed my 7.1 second run, which was cool, found it in the related videos of Priceys video lol:
As for other bits and pieces... ordered a new set of locking nuts - the key for my current ones are buggered, won't do up properly, and a flip blade key from fiestasi1800 on here :)
Re: Nick's ST
Postby hb69 on Mon Sep 03, 2012 8:38 pm
still stripped for saturday?
hb69
Nick's ST
Postby dontpannic on Mon Sep 03, 2012 9:25 pm
Not at the moment. Tempted though?
Re: Nick's ST
Postby hb69 on Mon Sep 03, 2012 9:29 pm
Do it
hb69
Re: Nick's ST
Postby trecoll on Tue Sep 04, 2012 9:15 am
Mines stripped ;)
trecoll
Re: Nick's ST
Postby dontpannic on Tue Sep 04, 2012 9:31 am
Oh go on then, I'll do it Wednesday :lol:
Re: Nick's ST
Postby Michael! on Tue Sep 04, 2012 9:44 am
mines stripped atm - probably added about 50bhp nick
Michael!
Re: Nick's ST
Postby dontpannic on Tue Sep 04, 2012 10:22 am
50? Do me a lemon, your underestimating. The 1.1 rear seats alone bog down to the tune of 75bhp.
Re: Nick's ST
Postby Michael! on Tue Sep 04, 2012 10:50 am
as much as 75? jesus, with my door cards stripped and roof lining i must be looking at 90-100 then? these valencias go on for ever, unlike your se :(
Michael!
Re: Nick's ST
Postby Minstral on Tue Sep 04, 2012 12:22 pm
hb69 :Do it
Coming from butler who has a car that is used just for track and won't strip it :bonkers:
Minstral
Your car: *
Re: Nick's ST
Postby dontpannic on Wed Sep 05, 2012 7:50 am
Its as good as any pic at the moment. I've installed my new tow strap. It's actually bolted to the towing eye bolt so is technically fully functional (although could flex the bumper if its actually used).
In fact, a parking attendant was so impressed with that and my exemplary parallel parking he took a photo of my car and left a note on the windscreen telling me that 'parking fine'. It's not my best bit of parking I must say, but it must be good enough to be warranted 'fine' by a warden :)
:lol: :lol: :lol: :lol: :lol: :lol:
Re: Nick's ST
Postby jayrs on Wed Sep 05, 2012 9:45 am
:lol: :lol:
Re: Nick's ST
Postby - Danny Boy - on Wed Sep 05, 2012 1:53 pm
Good job on the parking 'fine' award, only the best get them!
- Danny Boy -
Re: Nick's ST
Postby hb69 on Wed Sep 05, 2012 6:58 pm
Minstral :
hb69 :Do it
Mark ate breakfast on my back seat once, without them this precious moment would not have occurred, i leave them in, in the hope it happens again one day
On a side note, not a fan of those tow strap things
hb69
Re: Nick's ST
Postby jonyb4 on Wed Sep 05, 2012 8:05 pm
hb69 :
i agree, its a road car whats the point lol
going to cause loads of people saying why does your car have a tongue remarks
