noise!!
10 posts • Page 1 of 1
noise!!
just drilled the airbox on ma 1.3 mk3, sounds much meatier but how the hell do u shut that tapping tappety thing up, ruins the noise, tightening the tappets or somthing ive heard but what are the settings for them
- Jonezy
Hi.
Yes the tapping noise will most certainly be the tappets (valve clearances) Ive done my clearance on my fiesta 1.1, -
Fiesta 1.1 1989> = 0.2mm inlet 0.3mm exhaust
Fiesta 1.3 the same except when there is a sticker on the rocker cover =
0.5mm exhaust.
Only set the exhaust to 0.5mm when it says so though, these have a
hardened cam follower set that require the larger gap.
Also, wait for the engine to cool down before you set these, & there is a way to do Ford engines - look it up, or ask here.
Daz.
0.5mm exhaust.
Daz.
- Terror
Why is that? Surely you can make it sound a little less obtrusive?
Anyone know what engine i have? It's a 1.1 Mk3.5, I think it's HCS, but not sure.
- richard_p88
richard_p88 :Why is that? Surely you can make it sound a little less obtrusive?
it might quiten a little but the hcs makes that noise,
there was a thread on hear on how to quiten them, but it involved grinding something in the engine (cant remember what), but thats asking for trouble
- John_D
not sure if this new sound is positive, sound like the exhaust is blowin but not if ya get ma drift, the eb=xhaust is band new btw. under hand acceleration this sounds really wierd from inside the car or is this cos im used to the useual, clater it made?
- Jonezy
Yo...
Mine is a 1.1 HCS engine, in a J reg fiesta, mine also sounded really bad, I did my clearances & it did make mine alot quieter, after youve done the adjustments once, your supposed to do them again, about 2 weeks after the first adjustments, after the second adjustment it should be o.k.
daz.
daz.
- Terror
