noise
noise
Postby Jonezy on Mon Jul 17, 2006 6:46 pm
since drillin the arbox on ma 1.3 the egine is a little louder and much mietier than usual. the only prob is the amp seems to be picking up this noise. comes through the speaks as a wining and changes pitch as i rev the engine, is worse on startup but quietens dwn when engine is warm, the earth cable is still in place . any ideas
Jonezy
Postby Jonezy on Tue Jul 18, 2006 12:26 pm
any ideas the amp beta not be f**ked
Jonezy
Postby mattfiesta1987 on Wed Jul 19, 2006 10:30 am
you need a ground interference loop they about £10 and you plug it in the rca before they go into the amp, i had this wining problem and it gets louder when you rev the car it is because the rca pick up the interference.
hope this helps
matt
mattfiesta1987
Postby fiestamodder123 on Wed Jul 19, 2006 10:57 am
get yourself some good quality rca cables before you start buying ground loops ,i had the same prob on my si and i went and bought a rockford phosgate wiring kit and used the rca s from it and it solved the problem :D
fiestamodder123
Location: Mauchline (not the end of the world but you can see it from here)
Postby Jonezy on Wed Jul 19, 2006 4:05 pm
pg wiring used, wasnt cheap, the ground looop thing - cos ive got 2 rcas il need 2 of these loops then, cheers guys
Jonezy
Postby Jay on Wed Jul 19, 2006 11:34 pm
my dads disco was doing this cus one of the subs was earthing to the bodywork....
Formerly Jay246
Jay
Car: 1992 Ford Fiesta RS 1800
Postby Jonezy on Thu Jul 20, 2006 10:08 am
aahhh, il try that and see if its the sub,
Jonezy
