Noisy alternator????
Postby RickyS on Fri Jun 21, 2013 8:48 pm
Just went out in the fiesta and a noise started that sounded like something dragging, had a look but nothing, noise seems to be worse when accelerating and turning left, put right hand lock on and go in circles managed to keep the noise and lift bonnet and it seems like coming from alternator. Any ideas??? Cheers
RickyS
Your car: fiesta rs turbo
Re: Noisy alternator????
Postby RickyS on Fri Jun 21, 2013 8:51 pm
When turning right i mean!
RickyS
Postby mikeymikeyp on Fri Jun 21, 2013 9:15 pm
take off the alt belt and see if it stops :) :)
mikeymikeyp
Postby jayrs on Sat Jun 22, 2013 12:26 am
As above lol
If the alternator is noises the bearing will be on its way out and a long rid of metal push against it and your ear on the other end will amplify any sound from it.
Any signs the fan blade of the alternator have been touching or rubbing anything inc the plastic shield?
Also another thing seeing as you said its noise when turning one way, are you sure it's not a inner cv joint clicking away?
Postby RickyS on Mon Jun 24, 2013 6:39 pm
Only just got round to looking at the car, and the alternator fan/blades are wobbling in and out causeing the noise, will it be a case of just tightening it up or just get a new alternator? As you may have guessed already i dont know much about cars so all help and advice is greatly appreciated.
RickyS
Postby mikeymikeyp on Mon Jun 24, 2013 7:29 pm
if the bolts just slack then u might tighten it but sounds more like the bearings
mikeymikeyp
Postby jayrs on Mon Jun 24, 2013 7:55 pm
I agree with above
Postby RickyS on Tue Jun 25, 2013 7:22 pm
Problem sorted was alternator bearing, got it fixed today and put back on and all is well, now just got to find where oil is dripping from! Oh the joys, cheers fellas!
RickyS
Postby jayrs on Tue Jun 25, 2013 10:16 pm
Glad ya got it sorted fella :)
Postby mikeymikeyp on Tue Jun 25, 2013 10:32 pm
not a hard fix bud is it zetec or cvh
mikeymikeyp
Postby RickyS on Wed Jun 26, 2013 6:45 pm
CVH, its not leaking from oil filter or sump plug, and doesnt seem to be leaking sump gasket, back of the engine somewhere.
RickyS
Postby jayrs on Wed Jun 26, 2013 10:02 pm
Check the oil Cooler
Postby FRSJON on Wed Jun 26, 2013 10:39 pm
also check the oil pressure switch/turbo oil feed
FRSJON
