OFAB and OFAC?
7 posts • Page 1 of 1
OFAB and OFAC?
Whats the difference? Is it just the map sensor and ecu? or is the actual wiring loom different? The reason i ask is mine is currently running OFAC and im swapping to OFAB and i need to know if i gotta alter any part of the loom or whtether its just a plug in jobbie
Any ideas
Any ideas
- MOONDUST FRST
as you said, the ecu and map sensor is different!
the engine loom is also different! map sensor has a different plug on it to the ofac type!
also im not sure if the sensors on the engine are specific to the type of ecu u have as well..... this may be a posibility!
also the chip for the ecu is also only for that type!
hope this has helped!
James
James
- xrsi
- XR(ustyAtTheMo)SI
- MOONDUST FRST
well in that case then YES!
the engine part of the loom is diferent and this detatches from the main (interior) loom in the engine bay by the means of a multiplug!
also then its the ecu and map sensor!
i take it you know that you can use a cozzie 3bar map sensor on ofab!!
- xrsi
- XR(ustyAtTheMo)SI
Where does the engine part of the loom disconnect then?
Basically i have 2 FRSTs one running OFAB and one on OFAC so all the plugs etc should be there was just unsure about wiring side of things as im just swapping them over
- MOONDUST FRST
