OFAB ecu burnt out?
2 posts • Page 1 of 1
- blackbeautyzetec
- Your car: s2 black
Re: OFAB ecu burnt out?
As far as I can see, it there is no component damage, other than trace damage. This can be fixed by soldering a wire to replace the burned trace. Just follow from where it starts and where it ends and solder an insulated wire to the start and finishing point. You must do this wherever there is burned trace. If you can't solder or don't feel confident enough, better let it to an auto electrician or an electronics engineer. If I can judge from the area it is, it feeds with 5V the map sensor,TPS,CO pot... all are needed to run properly... do you make any pinouts change in the engine loom, or did you short circuit in any way? What ever repair you do, you must find the reason this happened and rectify it, otherwise you will damage the ECU again.Also you must check both sides of the PCB for damage,as they are double side printed.
My Ford Escort ride
My Ford Escort ride
- georgiocat
