Ofab ECU - HELP!!!
4 posts • Page 1 of 1
Ofab ECU - HELP!!!
Hi all,
I would like to ask if the Ofab ecu is programmable or not and if yes where could i find the software. The reason why I'm asking is because I phoned a car setter and asked him to check if my car is running well like air/fuel ratio and so on. He told me that he can check but if there might be a need for setting something this cannot be done without a programmable ecu and software. If someone could help it will be much appreciated.
Thanks.
Thanks.
- russellffrst
- Your car: 1994 diesel
Re: Ofab ECU - HELP!!!
ofab/ofac ecu's can be chipped but not reprogrammed as in say a aftermarket ecu..the tuner will only be able to set the car up to the limits of the factory map without a chip
- FRSJON
Hi FRSJON,
Thanks for your reply. I read about chips but i wish to leave the engine as it is...Will go to the tuner to check if everything is running in order. Thanks again...
- russellffrst
russellffrst :Hi FRSJON,
its all good with out a chip,the car will just be set up to run the best it can for the fueling it has
- FRSJON
