OFAB - OFAC
13 posts • Page 1 of 1
OFAB - OFAC
When buying a chip I take it you have to state which management your using?
so OFAB chips won't work with OFAC?
does anyone know...
does anyone know...
R.I.P Rob...
"The Teenage Chicks Love The Car"
- TrekkieFRST
- Location: Kings Lynn Drives: Honda Prelude Sex Appeal: 52.30% Loves: Stuff!!!
yep ya have to know which one you need before ya buy one!
ofab and ofac arent interchangeable!
easy way to tell is buy the map sensor! if its a 2i type one its ofac and if its cozzie type one its ofab!
- xrsi
- XR(ustyAtTheMo)SI
Oh I know I'm OFAC...
if you wanna run higher PSI you cannot fit the cossie 3bar map sensor can you??
if not what do you fit instead?
R.I.P Rob...
- TrekkieFRST
you can allready run high boost on ofac
if you want to run more than ofac can do in a cvh then your daft
a zetec turbo should run happy on ofac 18 psi or so is plenty
if you can afford an engine that will run that much boost then you can afford an aftermarket management system ie pectel
- MadcatCraig
- BANNED SELLER
I dind't know...I read everywhere that if you wanna run say 15 psi you should fit a 3 bar...they just don't consider OFAC owners
R.I.P Rob...
- TrekkieFRST
wait there tho!!
i thought that the frst was a 2bar one? ie could run up to 2 bar?!? thats 24psi!
so why do u need a 3bar to run 15?
confused..... dont know that much bout these!!
- xrsi
- XR(ustyAtTheMo)SI
I think your right about it being a 2 bar sensor so it wouldn't matter...I don't know that much myself so have to go on what I read...not as much on OFAC but I think I understand now
R.I.P Rob...
- TrekkieFRST
xrsi :yep ya have to know which one you need before ya buy one!
sorry to butt in on the post but.....
as quoted if the OFAC is the same type i.e. frequancy type map as the 2i would one of those work on the ofac frst??? or are the pressures different?
just strugglin to find an ofac map at a good price i.e. not ford dealer price
- RS TURBO S2
I thought the Xr2i Map sensor could olny deal with Negative pressures, so when you came on boost i.e. positive pressure, it'd get confused?
R.I.P Rob...
- TrekkieFRST
