OFAB stage one question
3 posts • Page 1 of 1
Hello people.I have a question,and since I take a lot of different answers here in Greece, I thought to ask in the specialists forum I run my Escort on OFAB management,with a Superchips stage 1,(or stage 0?! from what some dealers said to me),at 160Hp.My question is...does stage one only removes,(or raises to 12 psi),the boost limit,or it does changes too to the maps?12 psi is the continuous boost or overboost?Since I am not sure on the boost,i run my engine on 10 psi just for ease of mind.I would like to set it to where it should be according the stage's specifications,but since my engine is somehow old now,no one is working on it on management aspect,so I end nowhere...Engine has a Garrett T25,stock injectors and cossie fuel pump.Thank you all for your time.
My Ford Escort ride
My Ford Escort ride
- georgiocat
Re: OFAB stage one question
hello my old configuration was
OFAB p0
t3 turbo pressure 17.41 psi
injector golf g60
SPARK PLUGS Champion qc57c
and now
OFAB p1
iw204 injector 306 s16 bv6
OFAB p0
injector golf g60
and now
OFAB p1
- steeversturbo
- Your car: fiesta rs turbo
Hello.Thank you for your reply.So,if you running that kind of boost,chip just removes boost limit...considering the fueling is fine and depending the engine's condition the chip does the rest?First time I've heared 17 psi from stage 1.Eitherway i just want it at around 12,so i'll set the actuator and keep an eye on the wideband...
My Ford Escort ride
My Ford Escort ride
- georgiocat
