OFAC Management
4 posts • Page 1 of 1
OFAC Management
Can these managements be re-mapped? i was always under the impression that you cant and only piggy-back chips were possible. I have heard that someone like Ahmed Bayjoo is able to re-map or internally chip the original ecu.
Im running t2 hybrid holding 16psi, beiges, kent cvh34 cam and a based cosworth 2wd intercooler. Im currently usinf a Superchips 195 chip but im looking for something that cane be mapped better...
any help much appreciated
Dan
Dan
- project_mistral
Re: OFAC Management
The chips that go onto the the J3 port of the ecu are remapped. This is the most common way of remapping an eec-iv because very few people can re-flash the original eprom within the ecu. Regardless of whether a chip or a re-flash is done, the skill of the tuner is what matters most.
- sailorbob
Re: OFAC Management
MSD say they can map ofac over a bar
- j7aoc
Re: OFAC Management
Chipping the 0FAC management is done using a piggyback chip .. (as you superchip is right now)
MSD chips can be spec mapped.. but a RR or livemap is also a possibility..
- Jur
