OFAC Management
10 posts • Page 1 of 1
OFAC Management
Am i right in saying that the maximum boost you can run on OFAC management is 20 psi.
- JohnnyT2
ECU has OFAB or OFAC on the top (by the connector). Also on the bottom sometimes but it can be fiddled with.
OFAB has a suppressor (small black box) on the loom by the ECU connector.
- Project
- fiftyoneCL
As has already been mentioned, the standard pressure capability of the system is 2bar for OFAB and 2.5bar for Ofac however...
This is NOT whats limiting your boost. Its the small injectors and crap fuel pump, allied to tiny intercooler and an engine bay thats too small for a turbocharged lump.
Boost limits are not your problem im afraid, its the engines capability to accept and deal correctly with it..
Best Regards,
Stu
Best Regards,
Stu
- stu@mdevelopments
