Oil?? advice please!?
8 posts • Page 1 of 1
OK as you all know i've got a 1.6s,it's an 89' late F reg. now done 120k
What is the best oil to go for, a fully synthetic? What are the advantages? I work for Mobil so that will be my preferred brand!! and when i put it in, i take it i'll have to do an 'oil change' rather than just a 'top up' or is it ok to mix it with my current oil?? how often should i top-up the oil and how often for a change??
Cheerz In advance, Rob
- Rob1.6s
- Boy Wonder
Dont mix your oils, do a full oil and filter change
Check your oil every week and top up with the same oil that is in the engine.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
Funnily enough, i was just gonna ask the exact same question. Got some cheap $hitty oil in mine at the moment and i was gonna change it tomorrow, seeing as in the other thread it mentions the best oils to use. Anyway, nice 1!
- skiba_d
1.6S engines - I would go looking for some 10w50 or 10w40 - nice and thick, 'cos it's gonna be getting old now. If it's quite a noisy engine, go for higher numbers (thicker), if it's really quiet, go for 10w40. Always use fully synthetic. Run it up to quite a high temperature and drain the oil.
Keep a washing up bowl full of cold water and a large damp towel nearby in case you end up with a face load of 150C oil...
- Project
- fiftyoneCL
