oil cooler advice
13 posts • Page 1 of 1
oil cooler advice
Am looking into buying an oil cooler in the not so distant future!
whats the best size to have for one?? ie rows.
want the widest possable one tho!!
and yes it is sort of nessicery as it will be used to fill the bottom hole in the cozzie bumper and also have the oil temp gauge sender pit in line with it to save tapping the sump!!
any advice would be great!!
James
James
- xrsi
- XR(ustyAtTheMo)SI
Cooling the oil too much is a as detremental as having it above 80 degrees.
Make sure you've got a thermostatic take off plate to keep the temps reasonably even.
1.6 turbo? try a 13 row half width. or 7 row full width.
Are you sure you need one? what oil temps are you getting?
- excursionv2
not sure yet as i aint had the car on the road!
but yeah, want a cooler as it will have the oil temp gauge sender in the line followed by a thermostat to control the flow to the cooler but will continue to feed the sender no matter what!
- xrsi
- XR(ustyAtTheMo)SI
Are you already using the oil to water cooler that is standard on the FRST? The oil temperature sender can be put in the line to this. Don't think you'll really need a large oil to air cooler unless the car is at high revs all the time.
John
John
Quantum H4 2.1 ZVH Turbo - FOR SALE
Group4 Escort MkII 2L 16v
- Quantum John
ummmmm...........
dont think there is one as std on an frst!!!
where is it and what it look like as ive got no connections for one!!!
- xrsi
- XR(ustyAtTheMo)SI
xrsi - the oil temp gauge should be in the sump not in the oil cooler pipe if it was fitted there would only be reading when the wax stat was open which isnt what you want
Rob - that's enormous for a 1600 2i mate - that's ott mate tbh, check your cooling system, what oil temps are you getting?
- excursionv2
Is there not a big danger of mounting an oil cooler in the front valance area in that a large stone could puncture it and you will rapidly lose oil pressure.
Maybe a better place to put one would be in front of the front wheel, cut the arch liner to suit, and protect with stout mesh?
- Project
- fiftyoneCL
like a said loosing oil is bad!
and expensive! like when insane managed to dump all his oil on the motor way and cook his turbo!
and like the ppl carrier at my garage that lost its sump plug leaving it with melted big end bearings nackered crank, knackerd cam, and lots more
- FezzR
- God Damn Lazy
Al - there is going to be tight mesh infront of it! will still eb able to see it through it tho!!
excursion - the oil temp would be regulated by a thermostat that recurculated (in line with the coolers 2 pipes after a temp sender holder in line) so it would continually read!!
and yes, oil loss is very bad!!
- xrsi
- XR(ustyAtTheMo)SI
daz :i have a large oil cooler that would fit nicely in the front of a cossie front bumper.
i'll stick a pic up later.daz
for sale???? if so how much or where u got it from so i could get one if its not to steep!!
- xrsi
- XR(ustyAtTheMo)SI
