oil return for turbo what size is it?
4 posts • Page 1 of 1
ive ordered an oil return pipe not the hose bit but the bit that goes on the front of the block where the oil return pipe connects to.does any body no what size in diameter the pipe is so when i get it i can adapt it to go in my zetec block its for the turbo conversion.bits are coming from germany as ford said they dont stock it anymore .part number f1592381 odered to of them gonna use one on the back of my zetec block for the breather.im copying the cvh breather and oil pipe set up
- MK4 Rick
- Your car: Mk5 Fiesta
- j7aoc
Re: oil pipe
Not to sure what you mean but why would you drill the block don't think that's a good ideaturbonetic :so say it was 15mm for example and i died the metal pipe so it was then like a screw what size drill and tap do i need to screw this pipe into the block?
- j7aoc
