Oil return pipe
6 posts • Page 1 of 1
Oil return pipe
I've just removed my mates engine running the standard t2.I need to remove the standard threaded oil return at the front of the block.
How do you remove the bugger as it just turns
- rs steve
Re: Oil return pipe
mine just twisted off , is it threaded by any chance??
- sparkyt
Re: Oil return pipe
yeah its a large threaded nut - it just turns
- rs steve
Re: Oil return pipe
its not threaded
its push fit
its push fit
- Ruishy1
Re: Oil return pipe
Ruishy1 :its not threaded
its push fit
its not a push fit its threaded mate the t3 escort ones are a push fit ....i think
- dangerousdave
Re: Oil return pipe
Right I thought I had one of these removed somewhere.
This is the piece that is fitted into the front of the block
In the pic above the bit to the left is obviously the threaded part that the oil return pipe connects to, the part to the right is not threaded, and just pushes into the block face. Hence why it's just turning.
You need to try to pry it / pull it while turning if you know what I mean. Get some WD40 on it and turn it backwards and forwards, You should be able to get it out
- RS Joe
